Topic: Question about compatibility of product. (Read 764 times) previous topic - next topic
Ufoguy
I want to build a datalogger project and am going to use Jermey Blum's tutorial on datalogging as reference. My question is wether the product in this link http://store.extremeelectronics.co.in/MicroSD-TF-Module.html will work with his tutorial. Likewise I also want to know if all SD card modules can be connected using same method or does every one have a different method (Both hardware and software wise) .
If you want to meet a beautiful nurse you must be patient.
Osgeld
if the adapter (which is out of stock btw) uses SPI interface and has a 5 to 3.3 volt level shifter then they will work the same with the SD library or other typical arduino configurations
http://arduino.cc/forum/index.php?action=unread;boards=2,3,4,5,67,6,7,8,9,10,11,66,12,13,15,14,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,86,87,89,1;ALL
Ufoguy
It does have 5 to 3.3v shifter and the description says it brings out all the SPI pins. Thanks.
