Topic: help for the program for water tank (Read 10424 times) previous topic - next topic
mkbutan
if(a=0&&b=0&&c=0&&d=0)
I know it is in a comment, and you didn't post it between CODE TAGS, but those are assignments, and will ALWAYS be false.
Good luck with "printf"
thanks
sir but I did not understand what are you trying to say pl explain
"THE LIFE IS VERY SMALL TO LEARN ELECTRONICS"
                           ??????°?i??
                           AND
                           yes
                           PROGRAMMING
AWOL
..using "=", not comparisons which would use "=="
mkbutan
#32
Jan 07, 2013, 08:19 pm Last Edit: Jan 07, 2013, 08:26 pm by mkbutan Reason: 1
i have put one FUNCTION (Display) in the code's
but still not functional
is there any way by which we can convert BCD to DEC code's and can be printed out as output
I know its wrong please help me to make it right
thanks
[ the CODE's is for 'C' not for 'ARDUINO' ]
#include<stdio.h>
#include<conio.h>
void display(int z) // function declared Display(int z)
int main(void)
    int a,b,c,d;
    int x0,x1,x2,x3,x4,x5,x6,x7,x8,x9,x10,x11,x12,x13,x14,x15;
    x0=00;
    x1=10;
    x2=20;
    x3=25;
    x4=30;
    x5=40;
    x6=50;
    x7=60;
    x8=70;
    x9=75;
    x10=80;
    x11=90;
    x12=100;
    x13=0;
    x14=0;
    x15=0;
    printf("Enter the Val of A,B,C,D\n");
    scanf("%d,%d,%d,%d",&a,&b,&c,&d);
    printf("Val of a,b,c,d,%d,%d,%d,%d",a,b,c,d );
    display(int z)
    getch();
   void display(int z) //Function CALLED
   if(a==0&&b==0&&c==0&&d==0)
   printf("%a,%b,%c,%d is 00% EMPTY",x0);//0000=00
   if(a==0&&b==0&&c==0&&d==1)
   printf("%a,%b,%c,%d is 10%",x1);//0001=01
   if(a==0&&b==0&&c==1&&d==0)
   printf("%a,%b,%c,%d is 20%",x2);//0010=02
   if(a==0&&b==0&&c==1&&d==1)
   printf("%a,%b,%c,%d is 25%",x3);//0011=03
   if(a==0&&b==1&&c==0&&d==0)
   printf("%a,%b,%c,%d is 30%",x4);//0100=04
   if(a==0&&b==1&&c==0&&d==1)
   printf("%a,%b,%c,%d is 40%".x5);//0101=05
   if(a==0&&b==1&&c==1&&d==0)
   printf("%a,%b,%c,%d is 50%",x6 HALF);//0110=06
   if(a==0&&b==1&&c==1&&d==1)
   printf("%a,%b,%c,%d is 60%",x7);//0111=07
   if(a==1&&b==0&&c==0&&d==0)
   printf("%a,%b,%c,%d is 70%",x8);//1000=08
   if(a==1&&b==0&&c==0&&d==1)
   printf("%a,%b,%c,%d is 75%",x9);//1001=09
   if(a==1&&b==0&&c==1&&d==0)
   printf("%a,%b,%c,%d is 80%",x10);//1010=10
   if(a==1&&b==0&&c==1&&d==1)
   printf("%a,%b,%c,%d is 90%",x11);//1011=11
   if(a==1&&b==1&&c==0&&d==0)
   printf("%a,%b,%c,%d is 100% FULL",x12);//1100=12
   if(a==1&&b==1&&c==0&&d==1)
   printf("%a,%b,%c,%d is 100% ALARM",x13);//1101=13
   if(a==1&&b==1&&c==1&&d==0)
   printf("%a,%b,%c,%d is xXx",x14 );//1110=14
   else(a==1&&b==1&&c==1&&d==1)
   printf("%a,%b,%c,%d is XxX",x15);//1111=15
                           ??????°?i??
                           AND
                           yes
                           PROGRAMMING
robtillaart
one day long ago in FORTRAN someone invented the array. In C++ it is written as
int x[16] = { 0,10,20,25,30, ....,0,0,0}
everywhere where you state x3 you should use x[3] (and that for all values of 3 ;)
The other trick to consider is the else keyword
void display(int z)
  if (a==0 && b==0 && c==0 && d==0)  // spaces are free
    printf("%d, %d, %d, %d is %d %%", a,b,c,d, x[0]);
  else if (a==0 && b==0 && c==0 && d==1)
    printf("%d, %d, %d, %d is %d %%", a,b,c,d, x[1]);
  else if (a==0 && b==0 && c==1 && d==0)
    printf("%d, %d, %d, %d is %d %%", a,b,c,d, x[2]);
  else ...
//etc
As you want to handle all 16 possible combinations of bits you can combine the values a,b,c,d into one integer by using bit math to create an index to the array declared above.
void display(int z)
  int index = a*8 + b*4 + c*2 + d;
   printf("%d, %d, %d, %d is %d %%", a, b, c, d, x[index]);
please read the tutorial pages about arrays in C for more info.
Rob Tillaart
AWOL
That's not a function prototype.
This is:
void display(int z); // function declared Display(int z
mkbutan
thanks for giving me the kick start idea
but i am getting this error in Line #13 and #22
( I am using Code::Blocks 10.05 )
\4-16v1.c||In function `main':|
\4-16v1.c|13|error: syntax error before "void"|
\4-16v1.c|22|error: syntax error before '{' token|
    ||=== Build finished: 2 errors, 0 warnings ===|
the code's are as
I know its still wrong but please help
thanks
#include<stdio.h>
#include<conio.h>
int main(void)
     int a,b,c,d;
     int x[16] = {0,10,20,25,30,40,50,60,70,75,80,90,100,100,100,100}
     //printf("Enter the Val of A,B,C,D\n");
     //scanf("%d,%d,%d,%d",&a,&b,&c,&d);
     //printf("Val of a,b,c,d,%d,%d,%d,%d",a,b,c,d);
     getch();
    void display(int z)
    if(a==0 && b==0 && c==0 && d==0)
    printf("%d,%d,%d,%d is %d%% EMPTY",a,b,c,d,x[0]);//0000=00
    printf("%d, %d, %d, %d is %d %%", a,b,c,d, x[1]);//0001=01
    printf("%d, %d, %d, %d is %d %%", a,b,c,d, x[2]);//0010=02
    printf("%d, %d, %d, %d is %d %%", a,b,c,d, x[3]);//0011=03
    printf("%d, %d, %d, %d is %d %%", a,b,c,d, x[4]);//0100=04
    printf("%d, %d, %d, %d is %d %%", a,b,c,d, x[5]);//0101=05
    printf("%d, %d, %d, %d is %d %%", a,b,c,d, x[6]);//0110=06
    printf("%d, %d, %d, %d is %d %%", a,b,c,d, x[7]);//0111=07
    printf("%d, %d, %d, %d is %d %%", a,b,c,d, x[8]);//1000=08
    printf("%d, %d, %d, %d is %d %%", a,b,c,d, x[9]);//1001=09
    printf("%d, %d, %d, %d is %d %%", a,b,c,d, x[10]);//1010=10
    printf("%d, %d, %d, %d is %d %%", a,b,c,d, x[10]);//1011=11
    printf("%d, %d, %d, %d is %d %%", a,b,c,d, x[12]);//1100=12
    printf("%d, %d, %d, %d is %d %%", a,b,c,d, x[13]);//1101=13
    printf("%d, %d, %d, %d is %d %%", a,b,c,d, x[14]);//1110=14
    printf("%d, %d, %d, %d is %d %%", a,b,c,d, x[15]);//1111=15
                           ??????°?i??
                           AND
                           yes
                           PROGRAMMING
AWOL
#36
Jan 07, 2013, 09:20 pm Last Edit: Jan 07, 2013, 09:25 pm by AWOL Reason: 1
Can you see a closing brace in main?
I can't
(The error message line numbers are dead accurate)
Then there's the confused scope rules
mkbutan
I can't
Line #5 {
Line#19 }
do you mean anything else
pl explain
                           ??????°?i??
                           AND
                           yes
                           PROGRAMMING
AWOL
Most C implementations don't permit nested functions (personally, I think they're quite a good idea), so your braces are misplaced, hence the error messages.
PaulS
It looks to me like you are just splattering code around without a clue as to what you are doing.
main does not terminate correctly.
display has a body, even though it is NOT a function declaration.
getch() returns a value that you discard. It won't work on an Arduino, anyway, since the Arduino doesn't have a keyboard.
printf() won't work, because the Arduino doesn't have a console.
You have no clue when to use { and }, and when not to.
mkbutan
sir post #32 and #35 says I am Using 'C' but not ARDUINO
My project is for ARDUINO First let me learn to program in 'C' after that I will Program the same in ARDUINO
I am new to programming I have just learnt 'C' Programming Language that to from YOU TUBE and from net surfing and Book's
                           ??????°?i??
                           AND
                           yes
                           PROGRAMMING
mkbutan
#41
Jan 07, 2013, 09:48 pm Last Edit: Jan 07, 2013, 09:52 pm by mkbutan Reason: 1
\4-16v1.c|23|error: syntax error before '{' token|
error on line #13 and #23
#include<stdio.h>
#include<conio.h>
int main(void)
    int a,b,c,d;
    getch();
   void display(int z)
                           ??????°?i??
                           AND
                           yes
                           PROGRAMMING
PaulS
#42
Jan 07, 2013, 09:50 pm Last Edit: Jan 07, 2013, 09:53 pm by PaulS Reason: 1
Does that compile? Does it do what you want? Did you have a question?
     int a,b,c,d;
Local variables are not initialized. These contain whatever junk was in memory.
Now, what do you suppose index equals?
AWOL
Line 7 missing semicolon.
Can I ask what you're trying to do, and why doesn't it involve an Arduino?
PeterH
It's perfectly fine to learn C++ on its own if you want. In that case I suggest you start with a C++ development environment available on your operating system, and find a C++ forum and/or tutorials to help you learn. There are plenty of both about. I don't think it's reasonable to expect contributors on the Arduino forum to deal with general C++ issues that are not related to Arduino.
