tinyFAT.h - Arduino library support FAT16 on SD cards
Copyright (C)2010-2011 Henning Karlsen. All right reserved
You can find the latest version of the library at
http://www.henningkarlsen.com/electronics This library has been made to easily use SD card with the Arduino.
If you make any modifications or improvements to the code, I would appreciate
that you share the code with me so that I might include it in the next release.
I can be contacted through
http://www.henningkarlsen.com/electronics/contact.php This library is free software; you can redistribute it and/or
modify it under the terms of the GNU Lesser General Public
License as published by the Free Software Foundation; either
version 2.1 of the License, or (at your option) any later version.
This library is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
Lesser General Public License for more details.
You should have received a copy of the GNU Lesser General Public
License along with this library; if not, write to the Free Software
Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
#ifndef tinyFAT_h
#define tinyFAT_h
#if defined(__AVR__)
#if defined(ARDUINO) && ARDUINO >= 100
#include "Arduino.h"
#else
#include "WProgram.h"
#endif
#include "HW_AVR_defines.h"
#else
#endif
#define NO_ERROR 0x00
#define ERROR_NO_MORE_FILES 0x01
#define ERROR_FILE_NOT_FOUND 0x10
#define ERROR_ANOTHER_FILE_OPEN 0x11
#define ERROR_MBR_READ_ERROR 0xF0
#define ERROR_MBR_SIGNATURE 0xF1
#define ERROR_MBR_INVALID_FS 0xF2
#define ERROR_BOOTSEC_READ_ERROR 0xE0
#define ERROR_BOOTSEC_SIGNATURE 0xE1
#define ERROR_NO_FILE_OPEN 0xFFF0
#define ERROR_WRONG_FILEMODE 0xFFF1
#define FILE_IS_EMPTY 0xFFFD
#define BUFFER_OVERFLOW 0xFFFE
#define EOF 0xFFFF
#define FILEMODE_BINARY 0x01
#define FILEMODE_TEXT_READ 0x02
#define FILEMODE_TEXT_WRITE 0x03
#define SPISPEED_LOW 0x03
#define SPISPEED_MEDIUM 0x02
#define SPISPEED_HIGH 0x01
#define SPISPEED_VERYHIGH 0x00
struct _master_boot_record
byte part1Type;
unsigned long part1Start;
unsigned long part1Size;
struct _boot_sector
byte sectorsPerCluster;
uint16_t reservedSectors;
byte fatCopies;
uint16_t rootDirectoryEntries;
uint32_t totalFilesystemSectors;
uint16_t sectorsPerFAT;
uint32_t hiddenSectors;
uint32_t partitionSerialNum;
uint16_t fat1Start;
uint16_t fat2Start;
float partitionSize;
struct _directory_entry
char filename[9];
char fileext[4];
byte attributes;
uint16_t time;
uint16_t date;
uint16_t startCluster;
uint32_t fileSize;
struct _current_file
char filename[13];
uint16_t currentCluster;
uint32_t fileSize;
uint32_t currentPos;
uint8_t fileMode;
class tinyFAT
public:
_master_boot_record MBR;
_boot_sector BS;
_directory_entry DE;
unsigned long firstDirSector;
byte buffer[512]; // the buffer cannot be any smaller, SD cards are read/written in blocks of 512 bytes
tinyFAT();
byte initFAT(byte speed=SPISPEED_VERYHIGH);
byte findFirstFile(_directory_entry *tempDE);
byte findNextFile(_directory_entry *tempDE);
byte openFile(char *fn, byte mode=FILEMODE_BINARY);
uint16_t readBinary();
uint16_t readLn(char *st, int bufSize);
uint16_t writeLn(char *st);
void closeFile();
boolean exists(char *fn);
boolean rename(char *fn1, char *fn2);
boolean delFile(char *fn);
boolean create(char *fn);
void setSSpin(byte pin);
private:
_current_file currFile;
int DEcnt;
boolean _inited;
uint16_t findNextCluster(uint16_t cc);
char uCase(char c);
boolean validChar(char c);
uint16_t findFreeCluster();
extern tinyFAT file;
#endif
As previously stated, tinyFAT is fully self-contained....undependent on SD library?
Regards,
G
