Topic: Could you burn a bootloader to a atmega 2560 with this? (Read 796 times) previous topic - next topic
To_noob_to_be_true
http://www.jameco.com/webapp/wcs/stores/servlet/Product_10001_10001_2157790_-1
And if not could someone give to a link to a tool that can burn a bootloader to atmega 2560?
Osgeld
http://arduino.cc/forum/index.php?action=unread;boards=2,3,4,5,67,6,7,8,9,10,11,66,12,13,15,14,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,86,87,89,1;ALL
nickgammon
Does that definitely handle the +64Kb memory boundary?
Please post technical questions on the forum, not by personal message. Thanks!
More info:
http://www.gammon.com.au/electronics
retrolefty
As they name the product "USBtinyISP" I suspect it suffers the same +64KW (not bytes) limitation that adafruit's USBtiny programmer does. However that is just logical speculation on my part.
Lefty
nickgammon
I stand corrected. The limitation is at 128 Kb which of course affects the Atmega2560. This is because you program the flash in words, and at the boundary of 64 K words (128 Kb) the extra instruction "load extended address byte" needs to be sent to the processor.
More info:
