Loading...
Pages: [1]   Go Down
Author Topic: Connect more arduino  (Read 1208 times)
Offline Offline
Newbie
View Profile
Hello, i'm new in the community, i search information about creating a kind of network with more arduino. I use "arduino Mega2560" for the master (or the server?) and arduino uno for the slaves.
I think about ethernet, with ethernet shield, but it's expensive because i have to use one shield for each arduino and a ethernet switch
I need a full duplex connection, for send information from the master to the slaves and receive status and other information.
The rs495 is good, but isn't full duplex.
Excuse for my english if there are some errors, but i'm italian.
Bye, Marco
Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
Hi Marco,
a cheaper solution with reasonable performance is to use I2C :
- http://arduino.cc/en/Tutorial/MasterWriter + http://arduino.cc/en/Tutorial/MasterReader -
you can extend it to 126(?) devices.
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
California
Offline Offline
Edison Member
View Profile
Bye, Marco
The million dollar question is how far apart are the devices?
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Quote
So is one of my Arduino boards, but it's not nearly as polite and understandable as you are.  smiley-wink
Lefty
Logged
nr Bundaberg, Australia
Online Online
Tesla Member
Scattered showers my arse -- Noah, 2348BC.
View Profile
WWW
Quote
It can be full- or half-duplex, it's just a matter of how you do it.
How many slaves? How far apart?
______
Rob
Logged
Rob Gray aka the GRAYnomad http://www.robgray.com
Offline Offline
Newbie
View Profile
Hello.
I answer at all yours questions:
The max distance between the boards is 5 meters, but it have to work at longer distance, like 10 / 20 m
Number of boards is not up to 10.
I can't use I2C because the cables are near motors (for the noise (electrical noise)).
Can i use ethernet connection for more arduino, without any PC?
Thanks, Marco
Logged
Online Online
Tesla Member
View Profile
WWW
Quote
I think so, but I thought you wanted full-duplex.
RS-485 will do full- or half-duplex and cost a lot less.
______
Rob
Logged
Offline Offline
Newbie
View Profile
maybe i use rs485... connecting the control pin of the MAX485 to an output of arduino, i can control the direction of messages (TX or RX).. Is it right?
Maybe is the better choice...
Thanks, Marco
Ps: now i do some experiments... smiley
Logged
UK
Offline Offline
Sr. Member
View Profile
NRF24L01+ 2.4GHz 2Mbs modules can be bought in a low power version from China for around £1.30 each. The high power versions, with external antenna, cost about £7.50 each.
Used with the NRF24 and NRF24 Network libraries from maniacbug they may be suitable for your requirements.
The low power ones are certainly cheap enough to buy a few to try out.
Logged
Offline Offline
Brattain Member
View Profile
Thanks, Marco
If you use but one twisted pair then only half-duplex is possible and a need to switch converter chips from send to receive mode is required in your software. However if you run two twisted pairs then true full-duplex is possible and the converter chips are 'hardwired' to send and receive modes.
Lefty
Logged
Pages: [1]   Go Up
Print
Jump to:
