Topic: display.print() does not accept \r ??? (Read 7061 times) previous topic - next topic
nickgammon
I note in their library this bit of code:
Code: [Select]
void Adafruit_GFX::setTextColor(uint16_t c) {
  textcolor = c;
  textbgcolor = c;
  // for 'transparent' background, we'll set the bg
  // to the same as fg instead of using a flag
Sounds like you are in transparent mode.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
guix
#16
Dec 19, 2012, 09:28 pm Last Edit: Dec 19, 2012, 09:29 pm by guix Reason: 1
I've looked into both libraries Adafruit_GFX and Adafruit_HX8340B and I can't see anything related to a function named "print", how is it possible that display.print or println can be used? Is there a magic trick? I would like to understand.
usgine2003
So you are saying that drawing just ORs the new pixels over the existing ones? Strange. Well you will have to find a "clear rectangle" function then.
Yepp...That's exactly what it does...
I will take a picture this evening.
usgine2003
Code: [Select]
  textcolor = c;
  textbgcolor = c;
I will try to set the text color BLACK (or whatever the background is) and write the spaces...
nickgammon
It is derived from Print:
Code: [Select]
class Adafruit_GFX : public Print {
public:
nickgammon
Use this function:
Code: [Select]
void Adafruit_GFX::setTextColor(uint16_t c, uint16_t b) {
   textcolor = c;
   textbgcolor = b;
Set different text and background colours (eg. white, black). See what that does.
usgine2003
Code: [Select]
  textcolor = c;
  textbgcolor = c;
RIGHT ON TARGET!
I just defined a color for both BG and FG and voila' the characters now are perfectly dispalyed!
THANKS!
