Loading...
Pages: [1]   Go Down
Author Topic: NRF24L01 and ethernet work together problem.  (Read 923 times)
Offline Offline
Newbie
View Profile
http://www.elecfreaks.com/203.html
http://www.homebrew-tech.com/arduino/brewing-arduino-announcement/arduinor3testingethernetshieldr3
hallo my project is using the ie to control the LED at another arduino using NRF24L01.
did any one have an example? now i am able to create a web server and NRF24L01 send data. but when i combine them together, the NRF24L01  not working at all. anyone can help??? please and thank
Logged
Offline Offline
Newbie
View Profile
is that because of the arduino cannot share the ICSP pin?
if yes, any solution ?
Logged
Miramar Beach, Florida
Offline Offline
Faraday Member
View Profile
Normally, it is because the programmer cannot share (edit: fails to manage) the slave select pins until the individual libraries take over. That would include the uSD if you have a memory card in the ethernet shield slot.
Quote
Maybe. Post your code.
« Last Edit: December 19, 2012, 09:47:38 am by SurferTim » Logged
Offline Offline
Newbie
View Profile
Quote
[/quote]
i haven start combine the code together, now what i test is i use this code to send out the data. but when i combine the arduino ethernet circuit, it not function, any extra code i need to add in?
yes, i am going to use the sd card function in my project.
Code:
#include "NRF24L01.h"
#define TX_ADR_WIDTH    5   // 5 unsigned chars TX(RX) address width
#define TX_PLOAD_WIDTH  32  // 32 unsigned chars TX payload
unsigned char TX_ADDRESS[TX_ADR_WIDTH]  =
  0x34,0x43,0x10,0x10,0x01
}; // Define a static TX address
unsigned char rx_buf[TX_PLOAD_WIDTH] = {0}; // initialize value
unsigned char tx_buf[TX_PLOAD_WIDTH] = {0};
  SPI_DIR = ( CE + SCK + CSN + MOSI);
  SPI_DIR &=~ ( IRQ + MISO);
  //  attachInterrupt(1, _ISR, LOW);// interrupt enable
  init_io();                        // Initialize IO port
  unsigned char status=SPI_Read(STATUS);
  Serial.print("status = ");
  Serial.println(status,HEX);     // There is read the mode鈥檚 status register, the default value should be 鈥楨鈥?
Serial.println("*******************TX_Mode Start****************************");
  TX_Mode();                       // set TX mode
  int k = 0;
  for(;;)
    for(int i=0; i<32; i++)
        tx_buf[i] = k++;
    unsigned char status = SPI_Read(STATUS);                   // read register STATUS's value
    if(status&TX_DS)                                           // if receive data ready (TX_DS) interrupt
      SPI_RW_Reg(FLUSH_TX,0);
      SPI_Write_Buf(WR_TX_PLOAD,tx_buf,TX_PLOAD_WIDTH);       // write playload to TX_FIFO
    if(status&MAX_RT)                                         // if receive data ready (MAX_RT) interrupt, this is retransmit than  SETUP_RETR
      SPI_Write_Buf(WR_TX_PLOAD,tx_buf,TX_PLOAD_WIDTH);      // disable standy-mode
    SPI_RW_Reg(WRITE_REG+STATUS,status);                     // clear RX_DR or TX_DS or MAX_RT interrupt flag
// Function: init_io();
// Description:
// flash led one time,chip enable(ready to TX or RX Mode),
// Spi disable,Spi clock line init high
void init_io(void)
  SPI_PORT&=~CE; // chip enable
  SPI_PORT|=CSN; // Spi disable
  SPI_PORT&=~SCK; // Spi clock line init high
 * Function: SPI_RW();
 * Description:
 * Writes one unsigned char to nRF24L01, and return the unsigned char read
 * from nRF24L01 during write, according to SPI protocol
unsigned char SPI_RW(unsigned char Byte)
  unsigned char i;
  for(i=0;i<8;i++)                      // output 8-bit
    if(Byte&0x80)
      SPI_PORT |=MOSI;    // output 'unsigned char', MSB to MOSI
      SPI_PORT &=~MOSI;
    SPI_PORT|=SCK;                      // Set SCK high..
    Byte <<= 1;                         // shift next bit into MSB..
    if(SPI_IN & MISO)
      Byte |= 1;                // capture current MISO bit
    SPI_PORT&=~SCK;                    // ..then set SCK low again
  return(Byte);                    // return read unsigned char
 * Function: SPI_RW_Reg();
 * Description:
 * Writes value 'value' to register 'reg'
unsigned char SPI_RW_Reg(unsigned char reg, unsigned char value)
  unsigned char status;
  SPI_PORT&=~CSN;                   // CSN low, init SPI transaction
  status = SPI_RW(reg);             // select register
  SPI_RW(value);                    // ..and write value to it..
  SPI_PORT|=CSN;                    // CSN high again
  return(status);                   // return nRF24L01 status unsigned char
 * Function: SPI_Read();
 * Description:
 * Read one unsigned char from nRF24L01 register, 'reg'
unsigned char SPI_Read(unsigned char reg)
  unsigned char reg_val;
  SPI_PORT&=~CSN;                // CSN low, initialize SPI communication...
  SPI_RW(reg);                   // Select register to read from..
  reg_val = SPI_RW(0);           // ..then read register value
  SPI_PORT|=CSN;                 // CSN high, terminate SPI communication
  return(reg_val);               // return register value
 * Function: SPI_Read_Buf();
 * Description:
 * Reads 'unsigned chars' #of unsigned chars from register 'reg'
 * Typically used to read RX payload, Rx/Tx address
unsigned char SPI_Read_Buf(unsigned char reg, unsigned char *pBuf, unsigned char bytes)
  unsigned char status,i;
  SPI_PORT&=~CSN;                   // Set CSN low, init SPI tranaction
  status = SPI_RW(reg);            // Select register to write to and read status unsigned char
  for(i=0;i<bytes;i++)
    pBuf[i] = SPI_RW(0);    // Perform SPI_RW to read unsigned char from nRF24L01
  SPI_PORT|=CSN;                   // Set CSN high again
 * Function: SPI_Write_Buf();
 * Description:
 * Writes contents of buffer '*pBuf' to nRF24L01
 * Typically used to write TX payload, Rx/Tx address
unsigned char SPI_Write_Buf(unsigned char reg, unsigned char *pBuf, unsigned char bytes)
  for(i=0;i<bytes; i++)             // then write all unsigned char in buffer(*pBuf)
    SPI_RW(*pBuf++);
 * Function: TX_Mode();
 * Description:
 * This function initializes one nRF24L01 device to
 * TX mode, set TX address, set RX address for auto.ack,
 * fill TX payload, select RF channel, datarate & TX pwr.
 * PWR_UP is set, CRC(2 unsigned chars) is enabled, & PRIM:TX.
 * ToDo: One high pulse(>10us) on CE will now send this
 * packet and expext an acknowledgment from the RX device.
void TX_Mode(void)
  SPI_PORT&=~CE;
  SPI_Write_Buf(WRITE_REG + TX_ADDR, TX_ADDRESS, TX_ADR_WIDTH);    // Writes TX_Address to nRF24L01
  SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH); // RX_Addr0 same as TX_Adr for Auto.Ack
  SPI_RW_Reg(WRITE_REG + EN_AA, 0x01);      // Enable Auto.Ack:Pipe0
  SPI_RW_Reg(WRITE_REG + EN_RXADDR, 0x01);  // Enable Pipe0
  SPI_RW_Reg(WRITE_REG + SETUP_RETR, 0x1a); // 500us + 86us, 10 retrans...
  SPI_RW_Reg(WRITE_REG + RF_CH, 40);        // Select RF channel 40
  SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x07);   // TX_PWR:0dBm, Datarate:2Mbps, LNA:HCURR
  SPI_RW_Reg(WRITE_REG + CONFIG, 0x0e);     // Set PWR_UP bit, enable CRC(2 unsigned chars) & Prim:TX. MAX_RT & TX_DS enabled..
  SPI_PORT|=CE;
« Last Edit: December 20, 2012, 08:24:12 pm by terrancelim » Logged
California
Offline Offline
Edison Member
View Profile
I doubt you have italics in your original code.
Edit your post and surround your code with [CODE] and [/CODE]
Logged
Pages: [1]   Go Up
Print
Jump to:
