Loading...
Pages: [1]   Go Down
Author Topic: Ethernet Standard CS modification  (Read 194 times)
Offline Offline
Full Member
View Profile
I am using a Mega2560 with a board redesign and i wanted to change the standard chip select pin 10 to another pin.
Where on the Ethernet library can i do this?
Thanks
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Which library, which ethernet shield?
Logged
Offline Offline
Full Member
View Profile
The Arduino Ethernet Shield and respective library (Ethernet.h).
Logged
Offline Offline
Full Member
View Profile
In the case of Arduino UNO the SShardware pin is used for selecting the W5100 chip to comunicate.
In the case of the Arduino Mega the PB4 (pin 10) pin is used to select the W5100 chip to comunicate.
In the Mega case i cannot find the reference in the core Ethernet library to the PB4 (pin10). I need to find this or the way they do this so i can modify this port and use the one in my specific design.
Does anyone know?
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
<your install>/libararies/Ethernet/utililty/ws100.h has the relevant code I think, the macros
initSS, setSS and resetSS use direct port manipulation.
Create a copy of the Ethernet library, rename the class and alter those macros?  Doesn't look as simple
to do as it ought to be alas.
Logged
Offline Offline
Full Member
View Profile
Perfect.
Thanks MarkT
I tested it and it worked.
I tried to find it myself, but seems like lacked the persistence smiley
Logged
Pages: [1]   Go Up
Print
Jump to:
