Loading...
Pages: [1]   Go Down
Author Topic: Speech Recognition with BitVoicer, Arduino and a Microphone  (Read 1168 times)
Offline Offline
Newbie
View Profile
In this project I use BitVoicer’s speech recognition features (http://www.bitsophia.com/BitVoicer.aspx), one Arduino board and one electret microphone (https://www.sparkfun.com/products/9964) to control a few LEDs.
This project is similar to the one in my first post (http://arduino.cc/forum/index.php/topic,133051.0.html), but now I use audio streaming to send audio to BitVoicer.
The following fritzing schematic shows how I wired my Arduino board:
I’m also adding a few pictures and a YouTube video of the project running.
Unfortunately, the sketch I wrote for my first post is no longer supported by the new version of BitVoicer. Here is the new sketch:
Code:
#include <BitVoicer11.h>
//Instantiates the BitVoicerSerial class
BitVoicerSerial bvSerial = BitVoicerSerial();
//Stores true if the Audio Streaming Calibration tool
//is running
boolean sampleTest = false;
//Stores the data type retrieved by getData()
byte dataType = 0;
//Sets up the pins and default variables
int pinR = 3;
int pinY = 5;
int pinG = 6;
int lightLevel = 0;
  //Sets the analog reference to external (AREF pin)
  //WARNING!!! If anything is conected to the AREF pin,
  //this function MUST be called first. Otherwise, it will
  //damage the board.
  bvSerial.setAnalogReference(BV_EXTERNAL);
  //Sets up the microcontroller to perform faster analog reads
  //on the specified pin
  bvSerial.setAudioInput(0);
  //Starts serial communication at 115200 bps
  //Sets up the pinModes
  pinMode(pinR, OUTPUT);
  pinMode(pinY, OUTPUT);
  pinMode(pinG, OUTPUT);
  //Captures audio and sends it to BitVoicer if the Audio
  //Streaming Calibration Tool is running
  if (sampleTest == true)
    //The value passed to the function is the time
    //(in microseconds) that the function has to wait before
    //performing the reading. It is used to achieve about
    //8000 readings per second.
    bvSerial.processAudio(46);
  //Captures audio and sends it to BitVoicer if the Speech
  //Recognition Engine is running
  if (bvSerial.engineRunning)
//This function runs every time serial data is available
//in the serial buffer after a loop
void serialEvent()
  //Reads the serial buffer and stores the received data type
  dataType = bvSerial.getData();
  //Changes the value of sampleTest if the received data was
  //the start/stop sampling command
  if (dataType == BV_COMMAND)
      sampleTest = bvSerial.cmdData;
  //Signals BitVoicer's Speech Recognition Engine to start
  //listening to audio streams after the engineRunning status
  //was received
  if (dataType == BV_STATUS && bvSerial.engineRunning == true)
    bvSerial.startStopListening();
  //Checks if the data type is the same as the one in the
  //Voice Schema
  if (dataType == BV_STR)
    setLEDs();
//Performs the LED changes according to the value in
//bvSerial.strData
void setLEDs()
  if (bvSerial.strData == "wake")
    digitalWrite(pinR, LOW);
    digitalWrite(pinY, LOW);
    digitalWrite(pinG, LOW);
    digitalWrite(pinR, HIGH);
    digitalWrite(pinY, HIGH);
    digitalWrite(pinG, HIGH);
    delay(200);
    delay(200);
    delay(200);
    delay(200);
    delay(200);
    lightLevel = 0;
  else if (bvSerial.strData == "sleep")
    delay(200);
    delay(200);
    delay(200);
    lightLevel = 0;
  else if (bvSerial.strData == "RH")
    lightLevel = 255;
  else if (bvSerial.strData == "RL")
    lightLevel = 0;
  else if (bvSerial.strData == "YH")
    lightLevel = 255;
  else if (bvSerial.strData == "YL")
    lightLevel = 0;
  else if (bvSerial.strData == "GH")
    lightLevel = 255;
  else if (bvSerial.strData == "GL")
    lightLevel = 0;
  else if (bvSerial.strData == "ALLON")
    lightLevel = 255;
  else if (bvSerial.strData == "ALLOFF")
    lightLevel = 0;
  else if (bvSerial.strData == "brighter")
    if (lightLevel < 255)
      lightLevel += 85;
      analogWrite(pinR, lightLevel);
      analogWrite(pinY, lightLevel);
      analogWrite(pinG, lightLevel);
  else if (bvSerial.strData == "darker")
    if (lightLevel > 0)
      lightLevel -= 85;
    bvSerial.sendToBV("ERROR:" + bvSerial.strData);
The BitVoicer Voice Schema I used can be downloaded from: http://www.justbuss.xpg.com.br/BitVoicerTest2.zip (you need to have BitVoicer installed to be able open it).
Now I want to control a few things (lights and ceiling fan) at home. Suggestions on how to connect them to the Arduino are very welcome.
« Last Edit: December 27, 2012, 07:51:39 am by msb4180 » Logged
Offline Offline
Newbie
View Profile
I added wireless communication to this project so that the Arduino does not have to be physically connected to the computer. Here is the link to the new project: http://arduino.cc/forum/index.php/topic,140765.0.html
Logged
Pages: [1]   Go Up
Print
Jump to:
