Topic: 3xRGB stripe controlling through android...need your help (Read 2660 times) previous topic - next topic
mekonca
Hi. this picture will explain everything, but I need one more stripe if its possible
Everything is almost done(not by me). I found on this site code and apk for android http://www.myledlamp.net/
There you can add, inside apk, more then one "lamp"/stripe to control.
I will need your help to combine this stuff to make it usable for everyone.
1. Can someone make tutorial how to connect these stuff and to change code so we can use one arduino with at least 3  LED stripes ?
2. Can it be change to use ethernet not only bluetooth? So we can attach it to our router.
As you can see I dont have any experience with arduino. It will be great that some one can make good tutorial so anyone will be able to make this remote controller for leds. I hope it wont be so difficult with all the codes and apk on that site.
Thanks for any help
PaulS
This part of the forum is for THE Arduino project, not for an Arduino project. Ask a moderator to move your post to where it belongs - Project Guidance.
mekonca
I asked moderators but got no reply.
Can you at least tell me which arduino board will have enough PINS for 3 RGB stripes = 9 Pins
Ive read that out of 14 pins 6 provide PWM so can I use one of those 6 PWM pins for controlling R or G or B?
Need advice because I plan to buy arduino and dont want to buy the wrong one.
Thanks
PaulS
Quote
On a 328-based Arduino, this is true. On the Mega, there are more PWM pins. The Teensy 3.0, developed and marketed by a regular here also has 10 PWM pins, and can be programmed using the Arduino IDE.
Quote
Yes. If you want each stripe to be a different color, though, you need 9 PWM pins.
Buying the wrong one just means that you'll end up with two. That's not a bad thing. I have 8 spares right now. That makes it easy to test a small sketch and hardware on one, without interfering with the big sketch (and hardware) being developed for another one.
mekonca
So I need 9 PWM pins for the "picture+1 stripe" in my first post...
About teensy 3.0 - there is no ethernet board for 3.0 as I can see. Maybe bluetooth module will work.
Thanks for info.
PaulS
Quote
It's hard for these old eyes to make out the text in that picture, but I see what appear to be two stripes connected to 3 PWM pins each. So, for three of them, as the topic title suggests, you need 9 PWM pins.
mekonca
9 PWM have androids IOIO...
There are a lot of people that developed this for only one stripe and not for more :(
I found this company from Taiwan that made exactly what I am describing http://www.jystex.com/index.html
mekonca
#7
Dec 20, 2012, 12:23 am Last Edit: Dec 20, 2012, 03:46 pm by mekonca Reason: 1
Just a little update.
Remote apk is https://play.google.com/store/apps/details?id=com.diyphonegadgets.DemoKit#?t=W251bGwsMSwxLDIxMiwiY29tLmRpeXBob25lZ2FkZ2V0cy5EZW1vS2l0Il0.
It can be used with  Arduino with shield I think but dont know for the IOIO.
We need just little modification of the apk, instead of sliders for each R,G,B we need 3x color wheels for each stripe.  libraries for implementing can be found here http://stackoverflow.com/questions/2442407/android-color-picker
If anyone can help.
