Offline
Newbie
« on: December 19, 2012, 02:34:25 pm » |
Hi everyone, I am doing project using many chips and parallel port to run fan But the problem , our circuit it doesn't run when we provide the voltage We didn't use parallel port yet because just we want to test the circuit if it is work?
Logged
Offline
Newbie
« Reply #1 on: December 19, 2012, 02:38:29 pm » |
This is the circuit diagram  Wejust use the upper part , means we used just one uln 2803 chip
« Last Edit: December 19, 2012, 02:43:50 pm by Afnan »
Logged
Offline
Full Member
« Reply #2 on: December 19, 2012, 02:42:38 pm » |
its the black wire thats the problem,
the one just behind the pink one,
Logged
Offline
Newbie
« Reply #3 on: December 19, 2012, 05:15:25 pm » |
Which one do u mean? The circuit has many wires
Logged
Global Moderator
Dallas
Offline
Shannon Member
« Reply #4 on: December 19, 2012, 06:00:06 pm » |
The last time I checked, Arduinos don't have parallel ports. Are you certain you are posting your request for help on the correct forum? Could you have meant your posts for a "PC automation" forum?
Logged
Global Moderator
Dallas
Offline
Shannon Member
« Reply #5 on: December 19, 2012, 06:03:17 pm » |
Please do not cross-post.
Logged
SF Bay Area (USA)
Offline
Faraday Member
Strongly opinionated, but not official!
« Reply #6 on: December 19, 2012, 09:24:27 pm » |
This IS the "other hardware" party of the forum, though usually we prefer topics to be somewhat Arduino-related... You could in fact replace the entire circuit up to the ULN chips with an Arduino or AVR chip, simultaneously gaining the ability to operate via USB (and/or get debugging info via USB.) it doesn't run when we provide the voltage "doesn't run" how? What are you doing to it, and how are you expecting it to behave? You have no bypass caps. The 74LS05 has open-collector outputs and really isn't well-suited to use as a general purpose inverter. Though it might work if you're using "real" 74ls series logic, since inputs float high. It looks like the circuit should toggle the relays when you provide a clock by select/deselect/etc the inputs to the '154, but your circuit isn't providing any toggling. Doing so by attach/detach of wires will have "bounce" issues.
Logged
SF Bay Area (USA)
Offline
Faraday Member
« Reply #7 on: December 19, 2012, 09:30:10 pm » |
(um, are you working from here: http://xman.postalboard.com/t75-device-switching-using-pcs-parallel-port ? Or a less detailed source of information? Maybe their explanation will help (but it doesn't look like a very good explanation to me.)
Logged
Offline
Newbie
« Reply #8 on: December 20, 2012, 05:48:50 am » |
Logged
Offline
Newbie
« Reply #9 on: December 20, 2012, 05:52:04 am » |
This IS the "other hardware" party of the forum, though usually we prefer topics to be somewhat Arduino-related... You could in fact replace the entire circuit up to the ULN chips with an Arduino or AVR chip, simultaneously gaining the ability to operate via USB (and/or get debugging info via USB.) it doesn't run when we provide the voltage "doesn't run" how? What are you doing to it, and how are you expecting it to behave? You have no bypass caps. The 74LS05 has open-collector outputs and really isn't well-suited to use as a general purpose inverter. Though it might work if you're using "real" 74ls series logic, since inputs float high. It looks like the circuit should toggle the relays when you provide a clock by select/deselect/etc the inputs to the '154, but your circuit isn't providing any toggling. Doing so by attach/detach of wires will have "bounce" issues. Yes when provide 12v to relay and 5v to other chips that in the circuit diagram The fan doesn't work
Logged
nr Bundaberg, Australia
Offline
Tesla Member
Scattered showers my arse -- Noah, 2348BC.
« Reply #10 on: December 20, 2012, 07:19:07 am » |
The mind boggles. Even in 2007 that article was 20 years behind the times. And the code is all left justified and full of  s @Afnan Do you have a reason to go this way? If you're into having a retro trip or just want to learn about 74-series chips that's OK, but if this is a serious project it's time to get real. Yes when provide 12v to relay and 5v to other chips that in the circuit diagram The fan doesn't work Don't the chips need some control from the PC? Just sayin' _____ Rob
« Last Edit: December 20, 2012, 07:23:41 am by Graynomad »
Logged
SF Bay Area (USA)
Offline
Faraday Member
« Reply #11 on: December 20, 2012, 11:24:36 am » |
Don't the chips need some control from the PC? Just sayin' That's the way I read it. Nothing will happen (aside from possible random startup state) without manipulating the inputs so that the relevant 7474 clocks end up toggling.
Logged
Offline
Newbie
« Reply #12 on: December 21, 2012, 03:19:56 pm » |
Hi to everyone, Please i want to run fan in this circuit using parallel port Please if anyone suggest to me code to run this circuit  I used 74ls154, 74ls05, 74ls74 and ULN2803 I connected the relay with ULN2803 and connected the fan with relay So i want to run the fan from the code If anyone know about that please help me..
Logged
Virginia
Offline
Newbie
powerfully insane
« Reply #13 on: December 21, 2012, 09:22:36 pm » |
Kinda tough to see what is going on there since there aren't any labels or schematics. Without knowing the circuit or having some idea of what you want it to do it's going to be hard to help out, especially with "code" for hardware you might not be using. Is this going to be connected to an Arduino at some point?
Also, this is the "Other Software Development" board; you might have better luck posting in "General Electronics" or (if you're going to use an Arduino) "Interfacing w/ Software".
Logged
Offline
God Member
« Reply #14 on: December 21, 2012, 09:41:57 pm » |
He doesn't need to post this anywhere else. He's already got a whole thread on it in Other Hardware.
Pete
Logged
