Pages: [1] 2   Go Down
Author Topic: POOR MAN'S RTC  (Read 554 times)
Seattle, WA
Disclaimer: I'm pretty new to all this.
Hi, I'd like to make a time of day based event, such on a certain hour (or several), something happens.  Down the road maybe an RTC makes sense, but it would be cool to make one from scratch.
Here's what I got so far (Thanks to guix to help me get started)
unsigned long  time_old;
unsigned long  time_new;
int hours = 0;
  time_old = millis();
  time_new = millis();
   if(time_new - time_old >= (60 * 60 * 1000UL ))
     hours++;
   if(hours == 4)
     //do something
   if(hours>= 24)
     time_old = time_new;
Will this work? Will this keep time at all accurately?  Will it not if I use delay() in my "do something" section?
Also, if I power cycle the Uno at noon, would it reset the clock?
California
Will this work? Will this keep time at all accurately?/
Depends on how you define "accurately"
Not likely, but it depends on how you are using delay and how you are using the time.
Virginia, USA
Here is a time library on the playground. I have not used this but it may be what you are looking for.
http://playground.arduino.cc/Code/Time
Seattle, WA
Hmm, a minute per day accurate maybe?
So, I reduced the counter so I could debug... doesn't seem to work.  I'd expect every 10 seconds for hours to increment, then print to serial, etc. every 10 seconds, but what happens is after 10 seconds, it prints 1 to 24 really fast, then nothing.  Any ideas?  Thanks
int hours = 0;
   if(time_new - time_old >= (10 * 1000UL )) //shortened for debug
     hours++;
     Serial.println(hours);
   if(hours == 4)
     //do something
   if(hours>= 24)
Edit: adding " hours = 0;" to the last IF makes the same thing repeat every 10 seconds, not 240 smiley-sad
Manchester (England England)
Online Online
Solder is electric glue
Everything gets reset in a power cycle. If it is not exactly at noon then hours will not match real time.
Seattle, WA
Ok, got it, needed to reset time_old each ~hour.
if(time_new - time_old >= (1 * 1000UL )) //shortened for debug
     hours++;
     time_old = time_new;  //new line
With the standard Uno, no it won't be accurate enough for a clock, since the Uno uses a
ceramic resonator rather than a quartz crystal as its time base.  It is possible to resolder
a quartz crystal and caps in place of the resonator, but it is a pretty fiddly job.  The
Duemilanova (previous standard version of Arduino) used a quartz crystal, but alas the
Uno doesn't.
Calling delay() has little effect on your code if the delays are short - the checks for the hour will be held up
but the time accounting will still work.
Seattle, WA
ceramic resonator rather than a quartz crystal as its time base....
.....the checks for the hour will be held up
Cool, this will be enough to get me going and maybe later I can get a real RTC.  Is there not a Arduino model currently being produced with a quartz?
Thanks!
It will drift, by the duration of the main loop.
The best is through an interrupt.
If you have to use millis(), this is what I would do:
#define PR_1s 1000ul //duration of 1 second, in ms
#define PR_1m (60 * PR_1s) //duration of 1 minute
#define PR_1h (60 * PR_1m) //duration of 1 hour
#define PR_ERROR 0 //error term
#define PR PR_1m //duration set to 1 minute
void loop(void) {
  static time = millis(); //reset current time
  if (millis() - time >= PR) {//desired time has elapsed
    time += PR + PR_ERROR; //update time, with error correction
    //do something
The code is self-contained and allows you to correct for timing errors.
Its accuracy is only determined by the crystal.
Boston area, metrowest
On the other hand, a DS1307 & crystal are pretty inexpensive
http://www.dipmicro.com/store/DS1307N
http://www.dipmicro.com/store/XC4-32768
Use two 4.7K pullups on the SCL, SDA lines
Battery & holder
http://www.dipmicro.com/store/BAT-CR2032
http://www.dipmicro.com/store/BH120591-1
So, about $1.25 total?
I would change it slightly:
unsigned char rtc_tick(void) {
  static unsigned long time = millis(); //reset current time
    return 1; //return a tick
  } else return 0;
Whenever the duration defined by PR has passed, rtc_tick() returns 1, making time counting quite easy.
SE USA
@ssh0le
they are expensive in terms of memory, everyone uses the wire library to control the things, which directly states "I am going to eat your ram!" just to return a string you could write on a band-aid
Netherlands
@dhenry
nice implementation !
minor point, I would use uint8_t  instead of unsigned char as return type to indicate it is really an int. Or boolean true / false? ==> in short it depends.
Rob Tillaart
Pittsburgh, PA, USA
I only know some basic electricity....
Battery & holder
It's the other $40 I spend to justify shipping that gets me....
Examples can be found at Learning in the Main Site and at the Playground
Dallas, TX USA
1307 boards are cheap off ebay.
A bit over $2 USD including shipping:
http://www.ebay.com/sch/i.html?_odkw=i2c+rtc&LH_BIN=1&_sop=15&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313&_nkw=1307+module&_sacat=0
The boards even come with an eeprom and have a spot for a 18sB20 1 wire temperature sensor.
(some even come with it already soldered in).
One of those, the Time library along with TimeAlarms library and you are good to go.
--- bill
Pages: [1] 2   Go Up
