Loading...
Pages: [1] 2   Go Down
Author Topic: Raspberry pi arduino SPI  (Read 1424 times)
Offline Offline
Newbie
View Profile
connecting rpi and arduino via spi
transmitting bytes from arduino after receiving byte(0xFE) from rpi. its working fine but im receiving like this. mention my mistake.
Thanks
AA
FE
AB
FE
FE
AC
FE
FE
FE
FE
AD
AE
FE
FE
AF
B0
FE
FE
FE
FE
FE
B1
FE
FE
FE
FE
FE
FE
FE
FE
B2
Code:
static const char *device = "/dev/spidev0.0";
static uint8_t mode;
static uint8_t bits = 8;
static uint32_t speed = 500000;
static uint16_t delay;
static void transfer(int fd)
int ret;
uint8_t tx[] = {0xFE};
uint8_t rx[ARRAY_SIZE(tx)] = {0,};
struct spi_ioc_transfer tr = {
.tx_buf = (unsigned long)tx,
.rx_buf = (unsigned long)rx,
.len = ARRAY_SIZE(tx),
.delay_usecs = delay,
.speed_hz = speed,
.bits_per_word = bits,
ret = ioctl(fd, SPI_IOC_MESSAGE(1), &tr);
if (ret < 1)
pabort("can't send spi message");
for (ret = 0; ret < ARRAY_SIZE(rx); ret++)
printf("%.2X ", rx[ret]);
puts("");
while(1)
  transfer(fd);
Arduino code:
Code:
#include <SPI.h>
#define st_byte 254
char buf [100];
char data[]= {0xAA, 0xAB, 0xAC, 0xAD, 0xAE, 0xAF, 0xB0, 0xB1, 0xB2, 0xB3, 0XB4};
volatile byte pos;
volatile boolean process_it;
void setup (void)
  Serial.begin (115200);   // debugging
  // have to send on master in, *slave out*
  pinMode(MISO, OUTPUT);
  // turn on SPI in slave mode
  SPCR |= _BV(SPE);
  // get ready for an interrupt
  pos = 0;   // buffer empty
  process_it = false;
  // now turn on interrupts
  SPI.attachInterrupt();
}  // end of setup
// SPI interrupt routine
ISR (SPI_STC_vect)
byte c = SPDR;  // grab byte from SPI Data Register
  // add to buffer if room
  if (pos < sizeof buf)
    buf [pos++] = c;
    // example: newline means time to process buffer
    if (c == 254)
      process_it = true;
    }  // end of room available
}  // end of interrupt routine SPI_STC_vect
// main loop - wait for flag set in interrupt routine
void loop (void)
  int i;
    if(process_it)
         buf [pos] = 0;
         Serial.println(data);
         for(i=0;i<sizeof data;i++)
           SPI.transfer(data[i]);
         pos = 0;
         process_it = false;
    }  // end of flag set
}  // end of loop
« Last Edit: March 14, 2013, 02:33:31 am by venksbond » Logged
Switzerland
Offline Offline
Faraday Member
View Profile
Do you have a voltage converter between the two? The Raspberry Pi is a 3V device while the Arduino is a 5V.
Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
Pylon means the IO Pins have a different voltage
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Offline Offline
Newbie
View Profile
These work really well! And are cheap.
https://www.sparkfun.com/products/8745
Logged
Manchester (England England)
Online Online
Brattain Member
Solder is electric glue
View Profile
WWW
i got converter, one thing i want ask while connecting wires is it need to connect the voltage pins to the level converter? Or MOSI,MISO and clk is enough?
Yes you need to connect level converters between all the wires connecting a Pi and an Arduino.
Logged
Online Online
Brattain Member
View Profile
WWW
If you have at any time connected the signals from the arduino and Pi together you might have burnt out the GPIO pins on the Pi.
You need to check if the Pi is still working, use an oscilloscope to check this.
Logged
Online Online
Brattain Member
View Profile
WWW
when i unplug miso cable i'm receiving 0x00 so its working i think. even im not receiving any other garbage value.
No that is not sufficient to say it is working.
Logged
Offline Offline
Newbie
View Profile
yes you are right. now im getting garbage. i got this link to use (but it is I2C)level shifter https://dl.dropbox.com/u/4710119/mess/rasp_ard_i2c_bb_working.png. i cant understand why both 5v & 3.3v are used from pi to wiring and why resistor are need can u explain.
thanks
Logged
Online Online
Brattain Member
View Profile
WWW
On that diagram the 5V from the Pi is being used to power the arduino. You must not plug in the USB lead while it is wired like this.
The resistors are pull ups required by the I2C interface. They are not needed on the Pi side because it already has a pull up on its I2C lines.
Logged
Miramar Beach, Florida
Offline Offline
Faraday Member
View Profile
Your original post does not show garbage. That looks like a buffer overflow. Is that the output of the Pi or the Arduino?
I would not use this unless you have a terminating zero at the end of that array.
Code:
How big is the rx array?
Code:
Logged
Offline Offline
Newbie
View Profile
the o/p in rpi. im transmitting 0xFE to arduino and receiving data(bytes) in RPI. serial.println for debugging purpose in arduino. rx array size defined in structure of 'tr' i.e .len tells how many bytes we transmit and receive.
Logged
Offline Offline
Newbie
View Profile
Its working fine for rasp clock speed @200khz transferring 10 bytes. when i increase clock speed >200khz data sequence is not fine. what is the maximum SPI clock speed for arduino can support?
Logged
Online Online
Brattain Member
View Profile
WWW
Quote
It is 8MHz.
http://arduino.cc/en/Reference/SPISetClockDivider
Please do not delete your posts, it makes the thread disjointed. Even if you said things that you now know are not true please preserve a record for the benefit for those searching on this thread in future.
Logged
Offline Offline
Newbie
View Profile
is it necessary to config setclockdivider when arduino act as slave?
Logged
Online Online
Brattain Member
View Profile
WWW
No that only sets the clock output, so no need if it is a slave.
Logged
Pages: [1] 2   Go Up
Print
Jump to:
