Author Topic: Burn Bootloader on ATMEGA328P-PU 8MHz  (Read 1173 times)
Montemarciano, Ancona, Italia
Hi, i've been tryng a couple of time to burn the 8MHz bootloader by following these steps http://arduino.cc/en/Tutorial/ArduinoToBreadboard. I've tryed burn the 16MHz Bootloader, and all works fine, but when I try to burn the 8MHz bootloader, i got an empty signature.
This is my circuit:
And this is what i get when i try to burn the bootloader:
C:\Users\Riccardo\Desktop\arduino-1.0.3\hardware/tools/avr/bin/avrdude -CC:\Users\Riccardo\Desktop\arduino-1.0.3\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -cstk500v1 -P\\.\COM3 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0x05:m -Uhfuse:w:0xDA:m -Ulfuse:w:0xE2:m
avrdude: Version 5.11, compiled on Sep  2 2011 at 19:38:36
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "C:\Users\Riccardo\Desktop\arduino-1.0.3\hardware/tools/avr/etc/avrdude.conf"
         Using Port                    : \\.\COM3
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
avrdude: Send: 0 [30]   [20]
avrdude: Recv: . [14]
avrdude: Recv: . [10]
         AVR Part                      : ATMEGA328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel STK500 Version 1.x firmware
avrdude: Send: A [41] . [80]   [20]
avrdude: Recv: . [02]
avrdude: Send: A [41] . [81]   [20]
avrdude: Recv: . [01]
avrdude: Send: A [41] . [82]   [20]
avrdude: Recv: . [12]
avrdude: Send: A [41] . [98]   [20]
avrdude: Recv: . [00]
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
avrdude: Send: A [41] . [84]   [20]
avrdude: Send: A [41] . [85]   [20]
avrdude: Send: A [41] . [86]   [20]
avrdude: Send: A [41] . [87]   [20]
avrdude: Send: A [41] . [89]   [20]
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: Send: B [42] . [86] . [00] . [00] . [01] . [01] . [01] . [01] . [03] . [ff] . [ff] . [ff] . [ff] . [00] . [80] . [04] . [00] . [00] . [00] . [80] . [00]   [20]
avrdude: Send: E [45] . [05] . [04] . [d7] . [c2] . [00]   [20]
avrdude: Send: P [50]   [20]
Reading | avrdude: Send: V [56] 0 [30] . [00] . [00] . [00]   [20]
avrdude: Send: V [56] 0 [30] . [00] . [01] . [00]   [20]
################avrdude: Send: V [56] 0 [30] . [00] . [02] . [00]   [20]
################################## | 100% 0.06s
avrdude: Device signature = 0x000000
avrdude: Yikes!  Invalid device signature.
         Double check connections and try again, or use -F to override
         this check.
avrdude: Send: Q [51]   [20]
avrdude done.  Thank you.
What's wrong?
South Texas
Has this chip been programmed before? what fuse setting are in the chip before you started?
Using an Arduino Uno, you can program your 8 or 16 MHz AVR with a bootloader or directly with any other hex file (you do not really need a bootloader for most applications) by following the steps of this tutorial: http://pdp11.byethost12.com/AVR/ArduinoAsProgrammer.htm
Dallas
Shannon Member
What's wrong?
I can see from the image you are not providing a clock signal and do not have a crystal or resonator connected to the target.
If you have a crystal or resonator, this is the time to add them to your breadboard.
If you do not have a crystal or resonator, the Uno can be configured to output an appropriate clock signal which is then fed into the XTAL1 pin on the target.
What's wrong?
I'm trying to burn the 8MHz bootloader, so i don't need the crystal.
What do you mean for fuse setting?
I'll try, thank you :-)
Valencia, Spain
You do if the chip is currently configured to use a crystal... is it a 'virgin' chip or did it come pre-configured?
Yep, i've bought it preconfigured smiley-razz I'll try with the crystal...
All right! Tank you  smiley
Valencia, Spain
If it's preconfigured then it should have a bootloader...
