Topic: arduino and openwrt (Read 3782 times) previous topic - next topic
berlin
Hey,i just work on a project using openwrt and arduino.I wonder how they communicate.By network or serial does anyone had done something about it?
Thanks
SurferTim
I'm not sure about openwrt, but I use Mikrotik/Routerboard products, and I can use either protocol. I connect the Arduino to the usb port on the Routerboard (gets power there too), and the ethernet shield to one of the ethernet ports. I can ssh into the router and connect to the Arduino usb like a serial monitor, or use the ip address with TCP/IP as either a server or client.
Maybe openwrt has that usb feature also.
Headroom
Taht depends o what Hardware the openwrt is running.
For example a little TP-Link WR703n pocket router has a USB port that is usually meant to receive a USB  3G Modem. Running openwrt that USB port can be repurposed to connect and communicate directly with an Arduino.
I don't have any direct experience with that.
The more common way is to connect the router per Ethernet and TCP/IP to an Ethernet Shield/Arduino.
http://trippylighting.com
http://ledshield.wordpress.com/
berlin
Actually,i just need to do some programming on the router to let it do more controls.I wonder which system does the routerboard runs and i wonder if you can let the router board deal with the things itself.
Thanks
berlin
I use the pocket tp-link once .I wonder do i need to do some convertion before i attach the arduino usb directly to the tp-link.
Headroom
I am not sure what you mean with "conversion" so here is a link to the openwrt site with this routers info.
http://wiki.openwrt.org/toh/tp-link/tl-wr703n
Base on a previous thread her in the Networking section  of the forum I know that there are users that have successfully connected said router per USB directly to an Arduino.
berlin
Thanks
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
