Topic: logic high == +5v ? (Read 596 times) previous topic - next topic
robvoi
I bought a Pololo A4988 stepper driver to configute microstepping I need to bring some pins to logig high or logic low (which they are in by default).
I can simply connect them to +5V? Or is there a difference between bringing them to high via a digital PIN and connecdting them to +5V rail?
Thanks
Robert
CrossRoads
robvoi
Thanks. Just wanted to make sure I don't fry the driver.
Robert
MarkT
Nearly all modern stuff is CMOS, and CMOS logic levels go right to the rails.  (This wasn't true
for older TTL logic families which used pull-up resistors for logic high)
CrossRoads
CMOS uses transistors to pull the outputs low or to drive them high also.
http://www.ti.com/lit/an/scla007a/scla007a.pdf
See figures 2 & 3 on pages 1 & 2.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
