Pages: 1 [2]   Go Down
Author Topic: A few questions on C++ (from my C++ textbook)  (Read 719 times)
Charleston, SC
void foo (int a, int b)
  // you can do things with a and b here
  return;   // you cannot return a value
  }  // end of foo
int bar (int a, int b)
  return a + b;  // you must return an int
  }  // end of bar
To call those:
int main ()
  foo (1, 2);  // call foo, there is no return value
  bar (4, 5);  // call bar, discard the return value
  int fubar = bar (6, 7);  // call bar, get its return value
  } // end of main
Thanks again for the replies.
Fubar... hehe  sounds like most of the code I write  smiley
So here:
int main ()
  } // end of main
In the function "void foo(int a, int b)", you're assigning the number 1 and 2 to "int a" and "int b" respectively.
In the function "int bar(int a, int b)", you're assigning the number 4 and 5 to "int a" and "int b" respectively, resulting in a value of int a + int b (4 + 5) which equals 9, but discarding the return value.
Then using the variable "int fubar", int fubar = bar(6, 7) to get a return of "13" ?
t
Melbourne, Australia
Shannon Member
Lua rocks!
That's correct.
Shannon Member
Lua rocks!
Just to make sure...
#include <iostream>
using std::cout;
using std::endl;
the stripped down C++ used by Arduino doesn't have "iostream" or "std", right?
To be precise, the C++ isn't stripped down particularly. However if you compile the above you get:
sketch_dec21a.cpp:1:20: warning: iostream: No such file or directory
You can use the Streaming library from here to implement something similar:
http://arduiniana.org/libraries/streaming/
It doesn't particularly make sense for the Arduino IDE to support stdin and stdout (or stderr) as they don't have any real meaning in the environment.
However if you like to "stream" output to, say, Serial, then you can use the Streaming library to get similar effects.
UK
Just as a curiosity, I saw a bit of code from maniacbug in an example sketch that configured stdout to use Serial. I suppose it would have been possible to hook up the stdin and stderr file descriptors in the same way, but I've never tried it. I also haven't tested to see whether the standard i/o streams followed the same path. Anyway, I thought it was a neat technique.
 Copyright (C) 2011 James Coliz, Jr. <maniacbug@ymail.com>
 This program is free software; you can redistribute it and/or
 modify it under the terms of the GNU General Public License
 version 2 as published by the Free Software Foundation.
 * @file printf.h
 * Setup necessary to direct stdout to the Arduino Serial library, which
 * enables 'printf'
#ifndef __PRINTF_H__
#define __PRINTF_H__
int serial_putc( char c, FILE * )
  Serial.write( c );
  return c;
void printf_begin(void)
  fdevopen( &serial_putc, 0 );
#endif // __PRINTF_H__
http://arduino.cc/forum/index.php/topic,120440.0.html
http://www.nongnu.org/avr-libc/user-manual/group__avr__stdio.html
UK
Bookmarked, thanks.
Pages: 1 [2]   Go Up
