Topic: Newbie needs assistance (Read 49817 times) previous topic - next topic
nickgammon
The only other thing is I'm getting errors because of duplicate uses. Is there an easy way around that without having lists of defines and so on longer than the operating code?
What do you mean by defines? My code didn't have a single one, so I don't see where "lists of defines" comes from.
Nick what did you mean about the state 50 and so on?
If you have 50 states the next state doesn't have to be the 51st. one. States can loop.
For example, if your daily routine is:
  • 1. Wake up
  • 2. Get out of bed
  • 3. Have breakfast
  • 4. Go to work
  • 5. Have dinner
  • 6. Go to bed
  • 7. Go to state 1.
The 7th state in my example "goes backwards" (loops) so next day you do the same thing.
secretreeve
wantimpulsered
if used more than once, would return a duplication error when called for twice, once to turn on and once to turn off. obviously at different stages in the "list of events"
nickgammon
Time for you to start thinking about this. You need two states, right? One to turn impulsered on, and one to turn impulsered off. Any ideas for their names?
secretreeve
I had tried that, But for some reason the newer entry looped the fade.
I'll take another look at it tomorow though and see what happens.
secretreeve
#244
Dec 29, 2012, 12:36 am Last Edit: Dec 29, 2012, 12:51 am by secretreeve Reason: 1
The only other thing is, I know you said about the states, but still not sure on "down fading".
Also, the "startup sequence" stage is knocked out, so for the impulse mode sequence, would i want to put that where the note says //what next?
or after the break;
I'm thinking it would be where "whats next?" is. but just want to get that confirmed.
Also, progress report with code!
// The Enterprise
// Author: Nick Gammon
// Date:   27 December 2012
#include <LedFader.h>
#include <LedFlasher.h>
// pin assignments
const byte StrobesPin = 13;
const byte NavigationPin = 12;
const byte DeflectorbluePin = 11;   // PWM
const byte DeflectororangePin = 10;    // PWM
const byte NacellsbluePin = 9;      // PWM
const byte ShuttlebayPin = 8;
const byte DoorsPin = 7;
const byte NacellsvioletPin = 6;   // PWM
const byte ImpulseorangePin = 5;  // PWM
const byte TorpedoPin = 4;
const byte ImpulseredPin = 3;   // PWM
const byte RCSPin = 2;
const byte CabinPin = 1;
// Faders
//                                  pin           min   max   millis  on?    stop?
LedFader impulseredFader      (ImpulseredPin,      0,   40,  3000,   false,  true);
LedFader impulseorangeFader   (ImpulseorangePin,   0,   40,  3000,   false,  true);
LedFader deflectororangeFader (DeflectororangePin, 0,   40,  3000,   false,  true);
LedFader deflectorblueFader   (DeflectorbluePin,   0,   40,  3000,   false,  true);
LedFader nacellsvioletFader   (NacellsvioletPin,   0,   40,  3000,   false,  true);
LedFader nacellsblueFader     (NacellsbluePin,     0,   40,  3000,   false,  true);
// Flashers
//                        pin          off-time  on-time       on?
LedFlasher strobes    (StrobesPin,        8000,      100,     false);
LedFlasher navigation (NavigationPin,     2000,      500,     false);
// states for the state machine
typedef enum
  initialState,
  wantCabin,
  wantRCS,
  wantDeflectororangeon,     // impulse mode
  wantDeflectorblueon,       //                 warp mode
  wantDeflectororangeoff,    //                 warp mode
  wantDeflectorblueoff,      // impulse mode
  wantNacellsvioleton,       // impulse mode
  wantNacellsblueon,         //                 warp mode
  wantNacellsvioletoff,      //                 warp mode
  wantNacellsblueoff,        // impulse mode
  wantImpulseredon,          // impulse mode
  wantImpulseorangeon,       //                 warp mode
  wantImpulseredoff,         //                 warp mode
  wantImpulseorangeoff,      // impulse mode
  wantShuttleBayopen         // open in impulse
  wantShuttleBayclosed       //                 closed in warp
  wantNavigation,            // ALWAYS ON
  wantStrobes,               // ALWAYS ON
  wantTorpedoon,             // impulse mode
  wantTorpedooff             //                 warp mode
  // more states here
  } states;
// state machine variables
states state = initialState;
unsigned long lastStateChange = 0;
unsigned long timeInThisState = 1000;
void setup ()
  pinMode (CabinPin, OUTPUT);
  pinMode (RCSPin, OUTPUT);
  pinMode (ShuttlebayPin, OUTPUT);
  pinMode (NavigationPin, OUTPUT);
  pinMode (StrobesPin, OUTPUT);
  pinMode (TorpedoPin, OUTPUT);
  // set up faders, flashers
  impulseredFader.begin ();
  deflectororangeFader.begin ();
  deflectorblueFader.begin ();
  nacellsvioletFader.begin ();
  nacellsblueFader.begin ();
  strobes.begin ();
  navigation.begin ();
  }  // end of setup
void doStateChange ()
  lastStateChange = millis ();    // when we last changed states
  timeInThisState = 1000;         // default one second between states
  switch (state)
    case initialState:
         state = wantCabin;
         break;
    case wantCabin:
         digitalWrite (CabinPin, HIGH);
         state = wantRCS;
         break;
    case wantRCS:
         digitalWrite (RCSPin, HIGH);
         state = wantDeflectororangeon;
         break;
    case wantDeflectororangeon:
         deflectororangeFader.on ();
         state = wantDeflectorblueon;
         break;
    case wantDeflectorblueon:
         deflectorblueFader.off();
         state = wantNacellsvioleton;
         break;
    case wantNacellsvioleton:
         nacellsvioletFader.on();
         state = wantImpulseorangeon;
         break;
    case wantImpulseorangeon:
         impulseorangeFader.on();
         state = wantShuttleBay;
         break;
    case wantShuttleBay:
         digitalWrite (ShuttlebayPin, HIGH);
         state = wantStrobes;
         break;
        case wantStrobes:
         strobes.on();
         state = wantNavigation;
         break;
    case wantNavigation:
         navigation.on();
         state = wantTorpedo;
         break;
    case wantTorpedo:
         digitalWrite (TorpedoPin, HIGH);
         timeInThisState = 5000;         // no rush
         // what next?
         break;
   }  // end of switch on state
  }  // end of doStateChange
void loop ()
   if (millis () - lastStateChange >= timeInThisState)
     doStateChange ();
   // update faders, flashers
   impulseorangeFader.update ();
   impulseredFader.update ();
   deflectororangeFader.update ();
   deflectorblueFader.update ();
   nacellsvioletFader.update ();
   nacellsblueFader.update ();
   navigation.update ();
   strobes.update ();
  // other stuff here like testing switches
  }  // end of loop
The notes in the want list are there to help me keep organised, so pay them little mind.
secretreeve
Okay, here is the (almost) complete code!
It has all 3 sequences in there for the startup mode, impulse mode and warp mode.
// The Enterprise
// pin assignments
// Faders
// Flashers
typedef enum
  initialState,
  wantCabin,
  wantRCS,
  wantDeflectororangestartup,//                           startup mode
  wantNacellvioletstartup,   //                           startup mode
  wantImpulseorangestartup,   //                           startup mode
  wantShuttleBayon,          // impulse mode
  wantShuttleBaystartup,     //                            startup mode
  wantShuttleBayoff  ,       //                 warp mode
  // more states here
  } states;
void setup ()
  strobes.begin ();
  }  // end of setup
  switch (state)
    case initialState:
         state = wantCabin;
         break;
    case wantCabin:
         state = wantRCS;
         break;
    case wantRCS:
         state = wantDeflectororangestartup;
         break;
    case wantDeflectororangestartup:
         state = wantNacellvioletstartup;
         break;
    case wantNacellvioletstartup:
         state = wantImpulseorangestartup;
         break;
    case wantImpulseorangestartup:
         state = wantShuttleBaystartup;
         break;
//doors open here
    case wantShuttleBaystartup:
         break;
    case wantStrobes:
         strobes.on();
         break;
         navigation.on();
         state = wantTorpedoon;
         break;
    case wantTorpedoon:
         timeInThisState = 20000;         // no rush 10minutes, "600,000"
//impulse mode
    case wantImpulseorangeoff:
         impulseorangeFader.off();
         state = wantImpulseredon;
         break;
    case wantImpulseredon:
         impulseredFader.on();
         break;
         deflectororangeFader.on();
         break;
         state = wantShuttleBayon;
         break;
//doors need to open here
    case wantShuttleBayon:
         timeInThisState = 20000;  //10 minutes, "600,000"
//warp mode
   case wantImpulseredoff:
        impulseredFader.off();
        break;
        state = wantDeflectororangeoff;
        break;
   case wantDeflectororangeoff:
        deflectororangeFader.off();
        break;
        deflectorblueFader.on();
        state = wantNacellsvioletoff;
        break;
   case wantNacellsvioletoff:
        nacellsvioletFader.off();
        state = wantNacellsblueon;
        break;
   case wantNacellsblueon:
        nacellsblueFader.on();
        state = wantShuttleBayoff;
        break;
   case wantShuttleBayoff:
        digitalWrite(ShuttlebayPin, LOW);
         // what next?
         break;
void loop ()
     doStateChange ();
   strobes.update ();
  }  // end of loop
Problem is, theres a bug in the impulse lights (the 3rd and 4th from the right in the below video).
video: http://www.youtube.com/watch?v=f-trRl2oFaw&feature=youtu.be
As you can see, its not staying on when it is supposed to.  its the first blue led from the right. "impulseorange". It is MEANT to stay on until later on in the sequence when "impulsered" comes on and not turn off when the white one next to it comes on. Also i cant work out why the red (impulsered) is turning off as that is meant to stay on until the blue one (impulseorange) comes back on.
Can anyone see anything in the code which would cause it to be doing this?
Also, I still need a little more help in "down fading" the leds instead of them just "turning off" and getting impulse mode and warp mode to run in loops.
note: the led right in the middle at the lowest point is not meant to come on at any time. so thats not a problem.
secretreeve
So i guess I'll have to try and work this out.
Can someone tell me the output specs of the pins please? i.e voltage and current.
AWOL
HIGH voltage is supply minus a tiny bit, LOW is ground plus a tiny bit.
Current is an ABSOLUTE maximum of 40mA per pin, with a per-package limit of something like 200mA.
Or you could read the spec for your board.
secretreeve
Well I would do if it had a specs sheet with in, but instead just had some legal stuff in it.
AWOL
I can't remember what board you're using, but if you follow the links here you should find the specs for whatever you have.
secretreeve
Thanks AWOL. Its the UNO i think. It's got uno printed on it anyway lol.
AWOL
I've deleted four or five off-topic, pointless recent replies to this thread.
Please, you know who you are - just don't.
secretreeve
Appreciated AWOL.
I dont suppose you have any ideas on the interaction between the torpedo pin (4) and the impulse pins? (3 and 5)
AWOL
No, I'm afraid I don't and short of building your hardware, I don't suppose I'll be finding out any time soon.
secretreeve
Well it was worth asking.
