Topic: Clean and energy efficient LED dimming (Read 13943 times) previous topic - next topic
0AlphaOmega
Hm, a resistor at the gate? I have the 4.5Volt at the LED even with the gate not connected to the Arduino.
To test. disconnect from the Arduino and tie the gate to ground using your pull-down resistor. You can short it to ground if you like. Check if you still have 4.5V
Source voltage? You mean the 12Volt that go to the LED? The IRLU8726PBF is made for up to 30Volt.
Sorry, that is fine, what I meant was do you have the correct limiting resistor for your LED for the voltage being supplied?
Are your grounds okay? Short, connected to a single point. Is your CAT6 shielded? and if so, is the grounding at a single point - it's not unusual for Radio2 to take control of your circuit ;) If you have wires spanning the house, you will have quite a nice antennae going. Look out for the WOW! signal ;)
For whom does the clock pulse? It pulses for you!
MrGlasspoole
#16
Feb 15, 2013, 03:57 am Last Edit: Feb 15, 2013, 04:37 am by MrGlasspoole Reason: 1
Grounding the gate changes nothing.
There is no limiting resistor cause its a 12V LED. Its one of those you can swap with
the 12V halogen lamps in halogen systems: http://www.amazon.de/ersetzt-35Watt-Halogen-warmes-Kelvin/dp/B0076J5AHG/
They are really bright like 35Watt normal lamps and make a nice light.
The first LED i saw that really make sense when it comes to price<->power saving (amortization).
There is no CAT6 at the moment. Everything is short and on the breadboard :D
But when you talk about shielding. Would you always connect the shield to ground?
Both ends ore just one?
I use just shielded cable:
Stranded CAT.5E SF/UTP for switches and flow sensors.
Stranded CAT.6 S/STP for network.
Solid CAT.6 S/FTP AWG23 for 12V power to the LEDs and Arduinos.
Lappkabel UNITRONIC LiYCY 2x0,25mm2 where i have to spread the 12V: http://products.lappgroup.com/online-catalogue/data-communication-systems/low-frequency-data-transmission-cables/din-colour-code/unitronic-liycy.html
And i want to make a extra cable from the breaker box to my home stereo.
I want to use Lappkabel ÖLFLEX 120 CH 3x2,5mm2: http://products.lappgroup.com/online-catalogue/power-and-control-cables/various-applications/halogen-free/oelflex-120-ch.html
But i'm not sure what to to with the shield on this 220Volt cable.
spatula
I'm no expert, but since MR16 lamps are designed to be compatible with halogen lamps their internal circuitry, by design, has to work in concert with transformers and dimmers made for halogen lamps. This compatibility requirement has led to proprietary solutions which may have important side-effects.
I'm not sure whether the source can be considered reliable, but here's a couple of articles that worried me
http://ledsmagazine.com/features/9/6/8 and http://ledsmagazine.com/features/9/2/10.
MrGlasspoole
#18
Feb 15, 2013, 09:27 am Last Edit: Feb 15, 2013, 09:40 am by MrGlasspoole Reason: 1
God damn. After removing the LED i still had 12Volt.
From 10 Mosfets i picket a broken one :0
So i did some testing now and the electronic in the LED makes problems.
Here are some measurement:
Monitor PWM: 1, Pin 6 Volts: 0.03
D6 = 0.02 Volt
LED = 0.00 Volt (lights up)
LED turned = 0.21 Volt (lights up)
no LED = 11.3 Volt
Monitor PWM: 36, Pin 6 Volts: 0.72
D6 = 0.71 Volt
LED = 2.85 Volt (lights up)
LED turned = 2.85 Volt (lights up)
no LED = 11.5 Volt
If i connect the LED directly to the 12 Volt power supply i have 12 Volt at the LED.
In the PWM circuit i have the funniest volts.
There are allot PWM circuits out there but PWM is what the Arduino does.
Maybe a LED driver?
I found this: http://www.led-treiber.de/html/leds_grundlagen.html#PWM-Dimmer
and they write it works with all there LED drivers: http://www.led-treiber.de/html/getaktete_treiber.html
How about a power supply for all the LEDs and a "reverse phase control dimmer" in front of them
who is controllable with the Arduino?
There must be a way to dim those LEDs with some kind of circuit :-(
lax123
#19
Feb 15, 2013, 09:48 am Last Edit: Feb 15, 2013, 09:51 am by lax123 Reason: 1
your link to your LED:
"Produktmerkmale: Nicht Dimmbar", cant be dimmed
MrGlasspoole
#20
Feb 15, 2013, 11:31 am Last Edit: Feb 15, 2013, 11:35 am by MrGlasspoole Reason: 1
As a german i know what it means :D
But i think its there cause there are to many factors with transformers and dimmers.
I have a 12 volt halogen electronic transformer that is dim able with "reverse phase control dimmer" and
"phase control dimmer". But here the dimmer is in front of the transformer and its AC.
I was thinking DC and PWM the whole time - maybe there is another way.
I mean if i feed less volt to the LED its darker.
Maybe AC instead of DC...
Edit:
Just found this: http://www.youtube.com/watch?v=XgwNyO01mIg
So i need to do more research and use other words in google.
Was looking the whole time for PWM stuff.
lax123
i asked in a german forum about this:
http://www.mikrocontroller.net/topic/287066#new
maybe it helps
MrGlasspoole
After thinking i cant open the LED without breaking it i have it open now.
The 3 LEDs are series-connected.
The electronic was sealed in some silicon.
Looks close to this ones: http://detail.china.alibaba.com/pic/914205741.html
Its a MT7201 1A LED driver: http://www.maxictech.com/en/UploadFiles/MT7201_rev1.1_EN.pdf
And the circuit is close to this one: http://www.led-treiber.de/html/getaktete_treiber.html#MIC3201
But there are some diodes in front of it as rectifier.
Looks like you can PWM control this driver.
I will try to reverse engineer the circuit/PCB to find out what the LEDs need.
If i build my own driver, is it better to
1. put the MOSFET and driver near the LED
2. put the MOSFET near the Arduino and the driver near the LED
3. put the MOSFET and the driver near to the Arduino
And sure there are dimable LEDs out there, but they are not cheap and this have a really
good Colour Rendering Index and Color temperature.
MrGlasspoole
Ok, i did some measuring as you can see in the attachment.
I cant figure out the driver circuit cause its to small.
But there is a R25 and 3R00 on the PCB.
If i look at the M7201 data sheet that would mean they drive the LEDs with 0.1 / 0,25? = 400mA
That is close to my measurement.
If the 0.25? and 3? resistors are parallel its right: 0.1 / 0.23? = 430mA
If i look at the CRI and Color temperature and everything i bet they are Cree XLamp  XP-E High-Efficiency White LEDs. http://www.rapidonline.com/pdf/55-2568.pdf
But if the forward voltage is 3V, why do i measure 9V?
Shouldn't it be: 12V - 3 x 3V = 3V
So from all the reading around it looks like the driver needs to be near the LEDs.
So i need a third wire for PWM?
But how about the PWM cable length?
lax123
yea you need to connect pwm output to the adj pin as suggested on page 8-9 of the datasheet.
i dont think cable length does matter, as long its not something like half a meter. well you can calculate loss of voltage depending on cable length.
MrGlasspoole
0.5 Meter?
It's a house. There are 5-10 meters...
I found this driver: http://www.leds.de/out/media/KSQ.pdf
And they write to make the cable from the supply not longer then 1,5 meters.
Or is it that they assume that power cables are always unshielded?
lax123
#26
Feb 17, 2013, 06:18 pm Last Edit: Feb 17, 2013, 06:25 pm by lax123 Reason: 1
uhh 20 meters, i read in one of your first posts..
well a cable is like a resistor...the longer the cable the bigger the resistor...
http://www.elektronik-kompendium.de/sites/grd/1003191.htm
so maybe ur input supply is 12V with a cable of 20meters maybe only 10V depending on load "arrive" at the end of the cable
heres a calculator:
http://www.bmc-braunschweig.de/de/sonstiges/78.html
MrGlasspoole
@lax123, i thank you that you want to help me. But that is basic stuff i know.
And this calculator shows what i don't understand. Why so big and short cables for LED's?
I read stuff like 0.75mm2 - 1.5mm2 on most sides.
But if you look at eldoLED POWERdrive they write 3 meters to the LEDs.
And they write 0.2mm2 per 1 ampere.
They also wrote somewhere that 6 meters is no problem with CAT cable and also wrote that
they have customers who made up to 50 meters.
What i can't find is a answerer to PWM over longer distance.
If i have a LED driver with PWM in - how long can i make the PWM line from the Arfuino
to the driver.
There is also the option to dim analog. This would change the color temperature a little.
But i can't see in the Cree datasheets what color temperature at which ampere.
They write color temperatures from 2600 to 4300 for the XP-E High-Efficiency White LEDs.
Damn is this LED stuff complicated when it comes to dimming.
I wish i had a oscilloscope :D
lax123
can you link the source?
