Loading...
Pages: [1]   Go Down
Author Topic: Selecting bias resistor for thermistor  (Read 203 times)
Offline Offline
Newbie
View Profile
Rt is thermistor. Rb is bias resistor, which value I need to calculate. The temperature that I'm interested in is giving Rt resistance range of 4k...115k. What I want is to scale this to whole ADC resolution, which is 10 bit ie 0...1023. So when Rt = Rb ADC will convert it to 511. Not sure if it's possible, but ideally I would like to get 0 ADC reading when Rt = 4k and 1023 when Rt = 115k (or the other way).
Internally in MC I have lookup table, which will convert ADC value to temperature, according to curve described in thermistor datasheet.
Logged
Riga, Latvia
Offline Offline
Newbie
View Profile
WWW
My suggestion is to use digital thermometer. I have used Dallas DS18B20 using OneWire library. And I can say only the best about them - very precise and stable. And dead simple to use.
Logged
Offline Offline
Newbie
View Profile
Unfortunately this is not an option due to many reasons.
Logged
Offline Offline
Edison Member
View Profile
Quote
Fortunately, that's not possible.
Logged
Riga, Latvia
Offline Offline
Newbie
View Profile
WWW
Well ... I'm afraid you cannot get the full 0-5v output using just the voltage divider. You can get only the half of it.. like 0-2.5v (using the same 4k as Rb). You should be using at least 10 volt power source to get full 0-5v ADC resolution ( 0.336V to 5V using the 4k Rb).  Or 2.8k for the best resolution if you are using 12v power source ( 0.285v to 4.941). Please correct me if I'm wrong.
« Last Edit: December 21, 2012, 08:25:22 am by Arty » Logged
Pages: [1]   Go Up
Print
Jump to:
