Netherlands
« on: December 21, 2012, 05:11:46 am » |
I had a look at the magic numbers in SoftwareSerial today (only the 16Mhz part for now) because I wanted to check non-standard serial baudrates too. static const DELAY_TABLE PROGMEM table[] = { // baud rxcenter rxintra rxstop tx { 115200, 1, 17, 17, 12, }, { 57600, 10, 37, 37, 33, }, { 38400, 25, 57, 57, 54, }, { 31250, 31, 70, 70, 68, }, { 28800, 34, 77, 77, 74, }, { 19200, 54, 117, 117, 114, }, { 14400, 74, 156, 156, 153, }, { 9600, 114, 236, 236, 233, }, { 4800, 233, 474, 474, 471, }, { 2400, 471, 950, 950, 947, }, { 1200, 947, 1902, 1902, 1899, }, { 300, 3804, 7617, 7617, 7614, }, }; I came up with the following formulas rxstop = 16000000L/(7 * baudrate) - 2; rxintra = rxstop; // an easy one tx = rxstop - 4; // slight error rxcenter = rxstop/2 - 5; // slight error at higher baud rates.
this generates the following table baud rxcenter rxintra rxstop tx 115200 3 17 17 14 57600 13 37 37 34 38400 23 57 57 54 31250 30 71 71 68 28800 33 77 77 74 19200 53 117 117 114 14400 73 156 156 153 9600 113 236 236 233 4800 232 474 474 471 2400 470 950 950 947 1200 946 1902 1902 1899 300 3803 7617 7617 7614
The difference 'matrix' 2 0 0 2 3 0 0 1 2 0 0 0 1 1 1 0 1 0 0 0 1 0 0 0 1 0 0 0 1 0 0 0 1 0 0 0 1 0 0 0 1 0 0 0 1 0 0 0
Not yet tested thoroughly but the error matrix indicates that the tables can be replaced by formulas, allowing non standard baud rates. (to be continued)
« Last Edit: December 21, 2012, 05:13:34 am by robtillaart »
Netherlands
« Reply #1 on: December 21, 2012, 11:23:09 am » |
8 Mhz tables static const DELAY_TABLE table[] PROGMEM = { // baud rxcenter rxintra rxstop tx { 115200, 1, 5, 5, 3, }, { 57600, 1, 15, 15, 13, }, { 38400, 2, 25, 26, 23, }, { 31250, 7, 32, 33, 29, }, { 28800, 11, 35, 35, 32, }, { 19200, 20, 55, 55, 52, }, { 14400, 30, 75, 75, 72, }, { 9600, 50, 114, 114, 112, }, { 4800, 110, 233, 233, 230, }, { 2400, 229, 472, 472, 469, }, { 1200, 467, 948, 948, 945, }, { 300, 1895, 3805, 3805, 3802, }, }; the formulas: int rxstop = 8000000L/(7 * baudrate) - 4; int rxintra = rxstop; int tx = rxstop - 3; int rxcenter = max(rxstop/2 - 7, 1);
results of these formulas baud rxcenter rxintra rxstop tx 115200 1 5 5 2 57600 1 15 15 12 38400 5 25 25 22 31250 9 32 32 29 28800 10 35 35 32 19200 20 55 55 52 14400 30 75 75 72 9600 50 115 115 112 4800 110 234 234 231 2400 229 472 472 469 1200 467 948 948 945 300 1895 3805 3805 3802
The difference 'matrix' 0 0 0 1 0 0 0 1 3 0 1 1 2 0 1 0 1 0 0 0 0 0 0 0 0 0 0 0 0 1 1 0 0 1 1 1 0 0 0 0 0 0 0 0 0 0 0 0
Dallas
Online
Shannon Member
« Reply #2 on: December 21, 2012, 12:58:06 pm » |
I think rxcenter is adjusted a bit to try to account for the ISR overhead. Is that correct? Have you done something similar (is that the "- 5" in the first formulas)?
Netherlands
« Reply #3 on: December 21, 2012, 01:17:47 pm » |
(is that the "- 5" in the first formulas) rxcenter is used to get the middle of the pulse, so when reading the bit stream you're not on a falling or rising edge. What I actually did was place the existing table in Excel; Calculate the "ideal" table (clock/baud) and adjust the numbers for the differences (subtractions). For the 8Mhz I got a negative value so I adjusted the formula with an additional max() [pragmatic].
« Last Edit: December 21, 2012, 01:55:22 pm by robtillaart »
Netherlands
« Reply #4 on: December 21, 2012, 01:50:18 pm » |
First test with Arduino 1.0 SoftwareSerial example code and a Serial LCD - 9600 & 19200 baud - it behaves identical. Mind you: Both the original table version and the new formula version miss a byte once and a while when sending more than ~10 bytes  Adding a delay(1) in the code helps a bit but..... OK, the changes in SoftwareSerial.cpp are void SoftwareSerial::begin(long speed) { _rx_delay_centering = _rx_delay_intrabit = _rx_delay_stopbit = _tx_delay = 0;
// added lines long baud = speed; _rx_delay_stopbit = 16000000L/(7 * baud) - 2; _rx_delay_intrabit = _rx_delay_stopbit; _tx_delay = _rx_delay_stopbit - 4; _rx_delay_centering = _rx_delay_stopbit/2 - 5; // // for (unsigned i=0; i<sizeof(table)/sizeof(table[0]); ++i) // { // long baud = pgm_read_dword(&table[i].baud); // if (baud == speed) // { // _rx_delay_centering = pgm_read_word(&table[i].rx_delay_centering); // _rx_delay_intrabit = pgm_read_word(&table[i].rx_delay_intrabit); // _rx_delay_stopbit = pgm_read_word(&table[i].rx_delay_stopbit); // _tx_delay = pgm_read_word(&table[i].tx_delay); // break; // } // }
// Set up RX interrupts, but only if we have a valid RX baud rate if (_rx_delay_stopbit) { if (digitalPinToPCICR(_receivePin)) { *digitalPinToPCICR(_receivePin) |= _BV(digitalPinToPCICRbit(_receivePin)); *digitalPinToPCMSK(_receivePin) |= _BV(digitalPinToPCMSKbit(_receivePin)); } tunedDelay(_tx_delay); // if we were low this establishes the end }
#if _DEBUG pinMode(_DEBUG_PIN1, OUTPUT); pinMode(_DEBUG_PIN2, OUTPUT); #endif
listen(); }
The memory size of the 2 sketches: TABLE BASED : 4484 FORMULA BASED: 4302 ==> 182 bytes less every entry in the DELAY_TABLE = 12 bytes x 12 entries = 144 bytes so the code is also shorter => no search loop and progmem calls)
in fact as we calculate the baudrate we can also leave out the following lines from SoftwareSerial::begin() - _rx_delay_centering = _rx_delay_intrabit = _rx_delay_stopbit = _tx_delay = 0; - if (_rx_delay_stopbit) - and remove the local variable baud too difference is now 192 bytes less!
« Last Edit: December 21, 2012, 01:55:09 pm by robtillaart »
Netherlands
« Reply #5 on: December 21, 2012, 01:54:31 pm » |
Conclusion:
Not to bad result, 1) a smaller code base (192 bytes) and 2) freedom of baud rate selection.
The 2nd is quite useful as now one can adapt the baud rate when the Arduino has no 16.000.000 Hz Crystal but a resonator producing less or more cycles / second.
Pity the SoftwareSerial drops some chars once and a while (original version did that too)
Todo: - check every baud rate (old & new) - check this code on 1.0.3 - 20Mhz tables => formulas - Due too? - test on other Arduino's [MegaTeensy] - ...
Netherlands
« Reply #6 on: December 21, 2012, 02:18:48 pm » |
first version 20 MHz formulas. static const DELAY_TABLE PROGMEM table[] = { // baud rxcenter rxintra rxstop tx { 115200, 3, 21, 21, 18, }, { 57600, 20, 43, 43, 41, }, { 38400, 37, 73, 73, 70, }, { 31250, 45, 89, 89, 88, }, { 28800, 46, 98, 98, 95, }, { 19200, 71, 148, 148, 145, }, { 14400, 96, 197, 197, 194, }, { 9600, 146, 297, 297, 294, }, { 4800, 296, 595, 595, 592, }, { 2400, 592, 1189, 1189, 1186, }, { 1200, 1187, 2379, 2379, 2376, }, { 300, 4759, 9523, 9523, 9520, }, }; formulas int rxstop = 20000000L/(7 * baudrate) - 1; int rxintra = rxstop; int tx = rxstop - 3; int rxcenter = rxstop/2 - 4;
115200 7 23 23 20 57600 20 48 48 45 38400 32 73 73 70 31250 41 90 90 87 28800 45 98 98 95 19200 69 147 147 144 14400 94 197 197 194 9600 144 296 296 293 4800 293 594 594 591 2400 590 1189 1189 1186 1200 1185 2379 2379 2376 300 4757 9522 9522 9519
The difference 'matrix' 4 2 2 2 0 5 5 4 5 0 0 0 4 1 1 1 1 0 0 0 2 1 1 1 2 0 0 0 2 1 1 1 3 1 1 1 2 0 0 0 2 0 0 0 2 1 1 1
definitely worse than the 16 and 8 Mhz difference matrices, but it's a start
Netherlands
« Reply #7 on: December 22, 2012, 11:30:57 am » |
Still wondering why there is a rxintra and a rxstop column. The values are identical....
« Reply #8 on: December 22, 2012, 02:13:48 pm » |
@robtillaart, Noob question, but what's the reason for these values in SoftwareSerial? Obviously, less memory usage is a good thing.
Netherlands
« Reply #9 on: January 02, 2013, 10:40:04 am » |
Netherlands
« Reply #10 on: January 02, 2013, 10:54:40 am » |
@Marc G
A serial protocol is like a train with wagons and on each wagon there is one bit, 10 bits in total (including start/stop bits). The baud rate represents the speed of the train.
The software serial receiving code is triggered by the edge of the start bit (train). To read a bit properly one wants to read the value of the signal (HIGH/LOW) in the middle of the bit, not at the edges.
rxCenter is the time to the (approx) middle of the first (start) bit, rxIntra, rxStop are used as timings from the middle of one bit to the middle of the next. The higher the baud rate the lower these numbers.
tx is used for the timing for the transmit.
You can see this in the code of the library - C:\Program Files (x86)\arduino-1.0\libraries\SoftwareSerial - (windows) and search for this function - void SoftwareSerial::recv() -
« Last Edit: January 02, 2013, 12:56:35 pm by robtillaart »
Netherlands
« Reply #11 on: January 02, 2013, 01:19:59 pm » |
Did a more extensive test with the SoftwareSerial using the formula approach. I connected two Arduino's - UNO, 16Mhz (resonator) + 2009, 16Mhz (crystal) + IDE 1.0 - both using SoftwareSerial, one Master and the other Slave (essentially an echo). The master sent byte 0x55 at baudrate 100 and waits until the slave echos it back. If the answer is not 0x55, the test fails and master prints a message. Otherwise it just increases the baud rate with 100 and starts over. The results are pretty good as it only gets constantly distorted above 190K baud. Between 90K and 190K it only failed 10 times. I took 0x55 as test pattern 0x55 == 01010101 ; it helps to see what happened. (see comments after output Typical output (multiple runs had comparable output) Note: started with baud rate 100 in steps of 100... start... BAUD BYTE 97600 F5 FAIL // = 11110101 ?? 111200 AA FAIL // = 10101010 1 bit shifted 114400 D5 FAIL // = 11010101 1 bit failed (interference with start bit ? 124600 AA FAIL 140600 D5 FAIL 145500 AA FAIL 149000 D5 FAIL 163200 AF FAIL // = 10101111 ?? 190500 FF FAIL // = 11111111 expect sync lost 190600 FF FAIL 190700 FF FAIL 190800 FF FAIL 190900 FF FAIL 191000 FF FAIL ... The master and the slave were kept in sync by starting at the same baud rate an wait for each other. To repeat the test start the master, then start the slave, and press a char in the serial monitor of the master. Slave program (essentially echo) // // FILE: serialSlave (echo) // AUTHOR: Rob Tillaart // DATE: 2013-01-02 // // PUPROSE: test SW serial with formulas //
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2, 3);
void setup() { Serial.begin(9600); Serial.println("start slave..."); }
unsigned long baud=0;
void loop() { baud += 100; mySerial.begin(baud); while (mySerial.available() == 0); int b = mySerial.read(); mySerial.write(b); Serial.println(b,DEC); delay(10); }
master program // // FILE: serialMaster // AUTHOR: Rob Tillaart // DATE: 2013-01-02 // // PUPROSE: test SW serial //
void setup() { Serial.begin(9600); Serial.println("start..."); }
void loop() { if (Serial.available() > 0) { Serial.flush();
baud += 100; mySerial.begin(baud); mySerial.write(0x55); while (mySerial.available() == 0); int b = mySerial.read(); if (b != 0x55) { Serial.print(baud); Serial.print("\t"); Serial.print(b, HEX); Serial.print("\t"); Serial.println(" FAIL"); } delay(20); } } As always comments/remarks are welcome
« Last Edit: January 02, 2013, 01:21:54 pm by robtillaart »
Netherlands
« Reply #12 on: January 02, 2013, 01:49:40 pm » |
same test with stepsize 10 gave some more errors (typical run started with baud rate 10, step 10) start... BAUD BYTE 70660 D5 FAIL 81950 AD FAIL 88870 AF FAIL 89570 BD FAIL 94410 D5 FAIL 95340 AA FAIL 96590 D5 FAIL 98980 AA FAIL 100750 AB FAIL 103590 BD FAIL 105740 D5 FAIL 110600 AA FAIL 113260 AF FAIL 120200 AA FAIL
Up till 70K no failures ( that are 7000 different baudrates tested !) between 70K and 115K "only" 13 failures (13 fail on 4500 baudrates tested ~~ 1/300 above 120K the failures increased, not shown Conclusion from the tests, SoftwareSerial "by formula" works very good up to 70.000 and reasonable well up to 115.200 Tweaking the formulas further may improve the test results but for now I'm quite satisfied.
This SoftwareSerial "by formula" allows one to build a communication channel in which the baud rate is constantly altered, making it very difficult to eavesdrop - and yes to get in sync
Austin, TX USA
« Reply #13 on: January 03, 2013, 10:43:26 pm » |
@Rob,
I applaud this effort. Thanks for investigating so thoroughly. I always thought it might be fun to develop some equations that allow the synthesis of the "table" values on the fly, and now it looks like you are pretty close to doing just that.
It's good that you are getting error-free transmission up to 70K. Make sure you test not just the single byte round trip, but also lots of bursts. The values should vary Example:
1. Arduino sends 0x55 as fast as possible to host for one minute. 2. Arduino sends 0xFE as fast as possible to host for one minute. 3. Arduino sends 0x01 as fast as possible to host for one minute. 4. Host sends 0x55 as fast as possible to Arduino for one minute. 5. Host sends 0xFE as fast as possible to Arduino for one minute. 6. Host sends 0x01 as fast as possible to Arduino for one minute.
When constructing the tables, I found several times that I thought the values were good--until I tested the large bursts.
If we want to improve performance at baud rates > 57.6K, I think we're going to have to optimize the timer tick vector. I studied this for some time with the logic analyzer and discovered that the occasional glitch was due to a timer tick interrupt being processed exactly when a pin change was pending.
Lastly, and you probably already know this, but if your formula is off a bit for the lower baud rates, it shouldn't be a big deal. They are very tolerant.
Nice!
Mikal
« Reply #14 on: January 04, 2013, 03:21:48 am » |
robtillaart
like the idea of a formula, but could be slow to change baud rate could it not.
not certain, and for interest, did you try two boards connected using the standard software serial code, did you try two boards using the standard hardware uart.
