Pages: [1] 2   Go Down
Author Topic: Serial.available()  (Read 919 times)
Casorezzo, Milan, Italy
Not clear the meaning of Serial.available() function.
Can someone help!?
thanks
UK
It tells you how many characters are available in the receive buffer for you to read.
Netherlands
See - http://arduino.cc/en/Serial/Available -
Tip: never read more bytes (chars) than Serial.available() indicates smiley-wink
Rob Tillaart
So, typing:
if (Serial.available()==3){
Arduino gets data from computer, if you insert three characters only?
is that correct?
UK
Yes, but the problem is, if you don't check often enough, you may find that you have found four characters available, and the test will fail.
>= 3 would be a better test.
Thanks a lot!
but, sorry, for me it's still a bit misleading...
//in this case:
void loop(){
  if (Serial.available()>2){
    int inByte=Serial.read();
    Serial.println(inByte);
/* after uploading the sketch, typing a number of char, in the serial window, lower than 3,
no replies are obtained.
actually, after 4 or more characters are entered, even if just new one is typed, Arduino  sends the corresponding
ASCII code back.
How can I change the sketch, so only if 2 or more characters are entered, replies are sent, at any moment?
I hope i've been clear...*/
UK
Think about what you have.
Imagine you start "loop" with three characters in the buffer.
Think about what will happen to Serial.available after you have read out one character.
Seattle, WA USA
Seattle, WA USA
The Arduino does not have a serial window. The PC has an application called Serial Monitor that the Arduino IDE can launch.
That Serial Monitor application may, or may not append data to the serial stream it is sending, depending on what (unspecified) option you have selected.
That application does not send data as you type. It sends data only when you press the enter key or press the send button.
It would be really helpful if you would explain what application you are using to send the data, what options you have set, and how, exactly, you are sending the data.
To send data to Arduino, i use the serial monitor launched from the Arduino IDE.
My purpose is to send ASCII codes (so composed by one ore more digits) to Arduino and get back the corresponding character....is it possible...?
I'm not able to figure it out...no ideas..
UK
You see that Serial.available returns three.
Three is greater than two, so you read one character out.
"loop" exits, gets called again, and you call Serial.available again
What happens next?
Seattle, WA USA
Seattle, WA USA
The best ratio of answers to questions is 1. Higher than 1 is much better than lower than 1.
Now, we know that you are using the Serial Monitor application, but not what options you have set, what you are sending or when.
Yes, it is. It is quite easy, in fact.
There are two ways to go about it. One is to always send three characters, and hope like hell none get lost (not a realistic thing to do). The other is to send the value followed by a delimiter. The Serial Monitor makes this option easy.
Then, you read the data on the Arduino, storing it in a NULL terminated char array until the delimiter arrives. When that happens, you convert the array contents to an int, using atoi(), send a response, and reset the array index to 0 and put a NULL in that position of the array.
Though why you want to do this, versus looking in an ASCII table, is unclear.
What happens next?
void setup(){
void loop(){
  if(Serial.available()>2){
  char inBytes=Serial.read();
  Serial.println(inBytes);
first three characters typed:
"567"
Serial returns
"5"
(as you said)
going on with serial input, for example with
"sg89"
i get
"67sg"
ecc...
so, opening for the very first time the serial monitor, while less than 3 char are typed,
no signal is returned. When 3 or more char are entered, serial data began to flow from Arduino to pc.
Buffer does not reset each time the loop() cycle begin, for this reason, just when i open for the first time the serial port, this happens.
Right?...
my goodness, i'm sweating...
« Last Edit: December 22, 2012, 01:22:39 pm by gianlucalongoni » Logged
UK
I don't see anything in your observations that I don't expect.
What are you expectations?
Seattle, WA USA
Seattle, WA USA
No, it does not. No serial data is sent until you press the Send button or hit the enter key.
True. It would be useless if it did.
No. The buffer is cleared because opening the serial port resets the Arduino. The buffer is set up after the reset, empty.
You wouldn't be here. It's freezing.
Yep, sorry, i meant "after pressing" enter key...
i was trying to get the meaning of Serial.available function, and what seem to be obvious statements,
for my experience, are enormous obstacles!
Thanks foor helping me, Your all advices have been precious for me!
Pages: [1] 2   Go Up
