Topic: using DMA for memory-to-memory (Read 2938 times) previous topic - next topic
mantoui
Dec 21, 2012, 10:59 pm Last Edit: Dec 21, 2012, 11:02 pm by mantoui Reason: 1
You can do a memory-to-memory transfer under control of the DUE DMA, though I'm not sure why you'd want to because memcpy() is faster!  Here is simple sketch that compares a DMA memcpy (called memcpy32()) and memset (memset32()) to the library memcpy/memset and a for-loop (dst=src) for 32-bit words.
 http://pastebin.com/UR9DvzKB
Earlier, did the same thing on a maple (72Mhz), here are times in microseconds for 1000 32-bit words
Code: [Select]
               maple    DUE
      loop     269    132            for loop
      memcpy32  93     68         DMA
      memcpy    62     56
      memset32  94     69         DMA
      memset    38     41
Looking at the dis-assembled memcpy()  for the DUE sketch, you get an unrolled loop (64) of
ldr.w
str.w
and  version 1.20 of newlib actually has an ARM memcpy.S that has an unrolled loop with
ldrd
strd
stimmer
#1
Dec 22, 2012, 12:01 am Last Edit: Dec 22, 2012, 12:17 am by stimmer Reason: 1
Try using channel 5 :) Also, try using ASAP mode.
Code: [Select]
3
45
memcpy32 31
loop 133
memset32 33
loop 108
memcpy 59
3
memset 39
42424242
Due VGA library - http://arduino.cc/forum/index.php/topic,150517.0.html
mantoui
Ah, thanks.  Those changes do speed things up.  I made another sketch, mem2mem2.ino, to test DUEling memcpy's.  I added DMA interrupt to sketch and altered the DMA memcpy32() to run asynchronously.  I then let the DMA memcpy battle with the library memcpy() by starting up the DMA memcpy32() and immediately starting up the library memcpy(), operating on two separate src/dst 1024 32-bit word vectors.
The DMA copy won the DUEl, finishing first in 34us, and the memcpy() took 80us, total elapsed time 82us.  Using SRAM1 for one of the src/dst pairs, resulted in the DMA running in 33us and the memcpy() took 60us, with total elapsed time of 70us.
For the maple, the memcpy() finished first (64us) and the DMA took 122us.
I don't know what magic the DUE MATRIX might provide...
mem2mem2.ino can be found in my DUEZoo
  https://github.com/manitou48/DUEZoo
