New York
xronosclock.com
« on: December 21, 2012, 07:38:01 pm » |
I need to attach small 5cm speaker inside acrylic enclosure. Not sure how to proceed speaker doesn't have any attachment points. Is ther some kind of bracket I can glue or screw to plastic?
« Last Edit: December 21, 2012, 07:56:51 pm by bratan »
Xronos Clock - A talking arduino based alarm clock is now available. Check out xronosclock.com for pictures, source code, schematics, and purchasing info
the land of sun+snow
« Reply #1 on: December 21, 2012, 11:12:30 pm » |
I use Amazing Goop to attach everything [not available in some countries outside the USA]. It holds tenaciously to almost everything, and the best part is, you can take things back apart without destroying everything in the process. Just a little dab will do.
Murphy's Corollary: the "real" problem is usually what they don't tell you about, which leads to endless second-guessing. m
New York
xronosclock.com
« Reply #2 on: December 23, 2012, 11:18:40 pm » |
Thanks! I will try it!
SE USA
@ssh0le
« Reply #3 on: December 23, 2012, 11:56:06 pm » |
goop is a stupid strong rubber cement,and I love it, the only thing I would fear is that the fumes would cloud up clear plastic.
usually those speakers are held into place with little metal tabs and a hole drilled in one end to screw them down, you could make some easily out of a soup can ... another thought would be silicone caulk, since its often used on plexiglass I would guess it would not fume up the plastic
Maine
Caution: Explosives in use.
« Reply #4 on: December 24, 2012, 12:37:10 am » |
I have used both cold weld and loctite brand Epoxy on Lexan without any discoloration. Not sure about Acrylic.
"Anyone who isn't confused really doesn't understand the situation." Arduino-based airsoft props -> www.nightscapetech.com
Johannesburg UTC+2
Online
« Reply #5 on: December 24, 2012, 12:44:30 am » |
You could put a piece of metal on the other side and have the speaker clamp itself to that with its magnet....
IT Crowd: Roy... "Have you tried turning it off and on again?" Moss.. "Have you tried forcing an unexpected reboot?"
Central MN, USA
« Reply #6 on: December 25, 2012, 12:55:53 am » |
Hot glue gun? Just don't use crazy glue. It destroys the acrylic surface and out gasses that becomes nasty white powder on acrylic.
