Topic: Little Help Guys! Arduino Programming (Read 4033 times) previous topic - next topic
kelvs24
Keep in mind that pressing another key in between needs to reset the count of key presses. And, you need to deal, with some keys, like 3, where the user might want to produce "ee" that even the same key pressed more than once may, or may not, be trying to generate a new letter.
That is why the timing between keypresses is important.
Yes, can you give me example codes for timing that is related to my problem?
PaulS
Quote
There doesn't need to be a timeout. So if you wanted to type "bb" you'd press "222<right>222" rather than "222<pause>222"
I think that would be "22<right>22", wouldn't it?
Then, to type "be", you'd type "2<right>33<right>". Do you really want to hit the right key after every letter?
WizenedEE
Quote
I believe OP originally said he wanted it to display 2 if pressed once. It is rather irrelevant though.
Quote
Well in the code I posted, it would display the currently selected letter after anything other than a 2 was pressed... So "be" would be "2233"
Quote
WizenedEE, what happen is,
https://fbcdn-sphotos-h-a.akamaihd.net/hphotos-ak-ash4/314674_2587553506143_471668955_n.jpg
Can you post your exact code?
kelvs24
here
Code: [Select]
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2, 3);
int incr = 0;
char btn2 = 4;
    // use the ba ud rate your bluetooth module is configured to
    // not all baud rates are working well, i.e. ATMEGA168 works best with 57600
     Serial.println("Come at me baby!");
     mySerial.begin(9600);
     mySerial.println("Allright");
    // we initialize analog pin 5 as an input pin
    char someChar;
    static char lastBtn = -1;
    static char lastChar = 0;
    static int numPresses = 0;
    if(digitalRead(btn2) == HIGH) {
        if (lastChar != 2) {
            if (lastChar != 0) mySerial.print(lastChar);
            numPresses = 0;
            lastBtn = 2;
        someChar = '1';
        lastChar = 'a' + numPresses;
        numPresses++;
    delay(100);
PaulS
Code: [Select]
We do? Please don't post code using that invisible font.
Code: [Select]
This will NOT work, in any serious program. You need to detect transitions, not states. You need to know when the switch becomes pressed, not is pressed.
What, exactly, is someChar doing?
How IS the switch wired to pin 4?
