Topic: Sugru silicon stuff (self-setting rubber for DIY) (Read 3710 times) previous topic - next topic
robtillaart
Has anyone hands on experience with Sugru? Positive or negative, there are only a few threads mentioning this material and it looks quite useful.
Link - http://sugru.com/ -
Rob Tillaart
Coding Badly
I assume it's silicone rubber.  I have used something similar (EasyMold).  The stuff makes great tool handles.
Some things I know...
• If it will be in contact with food (after curing, of course) make certain it is "food grade".
• Be weary of the cure time.  It can be difficult to get it in the right shape within one minute.  After about half the cure time it will get significantly rigid.  A little planning goes a long way.
• This...
http://sugru.com/us/guides/how-to-repair-your-dishwasher
...is very difficult to get right.  It naturally tends to pull away from other materials.  It is not glue or even glue-like.  Make certain what it is supposed to "stick" to is very clean.
• It conducts heat fairly well (makes a good sealer for temperature sensors).
• Make certain it is well mixed.
• Make certain it is stable over about double the cure time (don't move it around).
• While curing, it will sag because of gravity.
• If you buy in "bulk", do not accidentally contaminate one with the other or you will end up with a hockey puck.
This is a bit creepy: "This brightly coloured smelly silicone blob..."  None of the silicone rubber I've worked with is "smelly".
I think I paid about $20 per ounce the last time I bought some (came in two equally sized containers).
robtillaart
Rob Tillaart
Osgeld
apparently you can fake it with corn starch and caulk
http://www.instructables.com/id/How-To-Make-Your-Own-Sugru-Substitute/
if that's anything like the name brand recipe, it explains the smell
Papa G
My grandkids love the stuff. It comes in many colors and sticks to most anything, except your hands.
westfw
As far as I can tell, sugru is subtly different than prior silicone molding compounds, particularly in that it's designed to stick to things rather than pull away cleanly.  I haven't actually used it myself.
Coding Badly
Gotta love this bit...
We bought a small mixer and working with one of our engineer friends to design a packaging machine, we built it for £5,000 and it ran on an arduino.
trendski
I used Sugru quite a few things and it's good at joining things together. I found it expensive though.
I also use this two part epoxy putty which is great to work with:
http://www.milliput.com/home.htm
Craig Turner, blog: http://gampageek.blogspot.co.uk/ It helps with my learning if I write things down, esp. for others to follow (constructive comments welcomed to improve)
Msquare
Best thing since sliced bread. I have fixed a broken handle on a casserole/pot. The handle broke of, I made a new one of two packets SUGRO and stuck it on the brackets. Has worked fine for four months (and I lift the pot with 2-3 litres boiling water in it). Also the cutlery/silverware-basket in the dishwasher the plastic netting in the bottom broke. I did some patching with Sugro. Still there after 5 months of daily dishwasher operation - and holding the cutlery.
westfw
This is a pretty impressive video, demonstrating the "stickiness" capabilities pretty well:
http://blog.makezine.com/2012/12/19/sugru-and-lego/
(It IS an advertisement.  YMMV.)
