Loading...
Pages: [1]   Go Down
Author Topic: rMp3 Spectrum Analysis Issue  (Read 241 times)
Offline Offline
Newbie
View Profile
I've been working with the rMp3 shield from Rogue Robotics for most of the day, and I'm pulling my hair out over one thing. I'm running the example code located here:
http://www.roguerobotics.com/wikidocs/projects/rmp3/spectrum_analyzer_demonstration#full_source
However, I don't have an LCD so I am instead routing the output values from the spectrum analysis array to a line that says
Code:
serial.print((int)v[i])
and looking at the resulting intensities over time.
Other than this print command, I have made only one other change to the code. I cannot get it to run with a baud rate of 38400, so I had to run
Code:
rmp3_s.begin
at 9600. If I change the serial rate to anything other than 9600, the shield will not sync, and so I can't even play the music.
Logically, I should see the decibels that are associated with each of the frequencies, right? Instead, I get nothing that's even slightly associated with the values. I do get values and they do change, every once in a while.
Is this the right way to look at the simple output of the system? How important is the baud rate for this? How do I get it running for a baud rate higher than 9600? I'm just looking for the values to change if the music changes, and I'm not even getting that.
Thank you,
dcellucci
Logged
Pages: [1]   Go Up
Print
Jump to:
