Topic: Can the ground wire in an analog video cable be shared with other ground wires? (Read 1 time) previous topic - next topic
David82
First of all, which wire is ground in an analog video cable? Is it the inner wire, or the outer 'shielding' wire? It is designed similarly to coaxial cable.
Secondly, can I share that ground wire with the ground from a 12v source and still have clear video?
I drawed a picture..
PeterH
I don't know about video signals specifically, but in general the shielding should only be grounded at one end to avoid forming an earth loop.
Grumpy_Mike
Yes it has to be grounded but don't pass current down it. It is the outer that is ground, however it has to be connected at both ends in most cases. It is not shielding which should be grounded at one end only.
rvasque
Always the outer braid... it's like a Faraday cage.
Of course.
I don't think so, not for single-ended lines.
Now, if this is a balanced/differential line, then you have the HOT and COLD lines, and you have the shield/ground. Then you can connect your shield (pin1 usually on XLR or TRS jacks) grounded to the case immediately at the entry point (use the metal tabs on the XLR jacks provided for this - short pin1 and the metal tab with a glob of solder, then secure XLR jack to metal case with screws.)
David82
Of course.
You are correct. It works now. Thanks.
