Loading...
Pages: [1] 2 3   Go Down
Author Topic: Has anyone got these cheap LCD's to work with arduino? (ST7735R)  (Read 2525 times)
South UK
Offline Offline
Sr. Member
View Profile
http://www.ebay.co.uk/itm/1-8-Serial-128X160-SPI-TFT-LCD-Modul-Display-PCB-Adapter-SD-Socket-4-Arduino-/280937300096?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item41692b0080
Nice price available to my location and look like they could be good to shrink some projects down! Anyone ever tried these eBay specials?
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
No but I wonder if the interface chip it uses ST7735R is compatible with the ST7735 (nothing immediately
springs out when comparing the datasheets).  The UTFT library supports ST7735 serial from what I can
glean.   Spend some time comparing the two datasheets perhaps?
Logged
South UK
Offline Offline
Sr. Member
View Profile
Good idea I will take a look when I find some spare time
« Last Edit: December 23, 2012, 09:49:25 pm by dtokez » Logged
Norfolk UK
Offline Offline
Edison Member
View Profile
The ebay URL you supplied contains a download link to a file that appears to contain an Arduino library and example sketches for the device. The example sketches are .pde extension instead of .ino so the libraries may need modifying to work with Arduino IDE v1.0+
Logged
South UK
Offline Offline
Sr. Member
View Profile
Ah right, I just found the link you mentioned. Is it easy to update the libs?
Logged
Norfolk UK
Offline Offline
Edison Member
View Profile
After downloading them to check what may need changing and I read they are Adafruit libraries so I suggest getting them direct from them to ensure latest versions. You need two libraries, this https://github.com/adafruit/Adafruit-GFX-Library and this https://github.com/adafruit/Adafruit-ST7735-Library I downloaded and compild them without problem but don't have a display to test them.
Logged
South UK
Offline Offline
Sr. Member
View Profile
Hi Riva, that's good news! I think I will order a display then as it seems there should be a way to get them working smiley
Can't go wrong for that price really!
Logged
Katowice POLAND
Offline Offline
Full Member
Arduino rocks
View Profile
Hi
I did smiley
They are superb smiley-grin The PCB layout is easy to design and make. Now you can get this lcd on ready pcb adapter for few bucks.
I already ordered 3 of them. Adafruit library works wery well smiley
i bought 2
http://www.ebay.pl/itm/1-8-Serial-TFT-Color-LCD-Display-Module-With-SPI-Interface-5-IO-Ports-128X160-/350631278788?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item51a340b8c4
and one
http://www.ebay.pl/itm/1-8-Serial-SPI-TFT-LCD-Module-Display-PCB-Adapter-Power-IC-SD-Socket-128X160-/370677580907?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item564e1b046b
so cheap as dirt smiley-grin
« Last Edit: December 25, 2012, 06:54:54 pm by zachwiej » Logged
South UK
Offline Offline
Sr. Member
View Profile
Thats great stuff! So basically the cheaper one has no PCB but the slightly more expensive one is ready to be run from an arduino?
Logged
Katowice POLAND
Offline Offline
Full Member
Arduino rocks
View Profile
Yes smiley I tested already one without pcb (I made my own) and its doing fine smiley
Logged
South UK
Offline Offline
Sr. Member
View Profile
Sounds perfect I will try one out, thanks smiley
Logged
France
Offline Offline
Sr. Member
View Profile
WWW
This one looks interesting: 2.8" inch 320x240 Touch TFT LCD Display Module, SPI Interface, ILI9320 at USD14
http://www.ebay.co.uk/itm/2-8-inch-320x240-Touch-TFT-LCD-Display-Module-SPI-Interface-ILI9320-/181008290930?pt=LH_DefaultDomain_0&hash=item2a24ef5472
Logged
avenue33
Katowice POLAND
Offline Offline
Full Member
Arduino rocks
View Profile
I think that SPI can be for touch controler not the LCD
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
The pinout suggest that there is another variant of the board supporting SPI (LCDB rather than LCDA) - perhaps
same vendor has this one too?
Logged
Rapa Nui
Offline Offline
God Member
Pukao hats cleaning services
View Profile
I've got this one:
http://www.ebay.co.uk/itm/1-8-Serial-128X160-SPI-TFT-LCD-Module-Display-PCB-Adapter-SD-Socket-/261150773094?_trksid=p2045573.m2042&_trkparms=aid%3D111000%26algo%3DREC.CURRENT%26ao%3D1%26asc%3D27%26meid%3D4648364954718621766%26pid%3D100033%26prg%3D1011%26rk%3D3%26sd%3D280937300096%26
working nice with the latest adafruit's ST7735 library.
The only issue I see is it uses BGR565 color coding (the driver does expect RGB565 coded colors).. smiley-confuse
p.
« Last Edit: January 04, 2013, 08:53:31 pm by pito » Logged
Pages: [1] 2 3   Go Up
Print
Jump to:
