Pages: [1] 2 3   Go Down
Author Topic: Has anyone got these cheap LCD's to work with arduino? (ST7735R)  (Read 2726 times)
South UK
http://www.ebay.co.uk/itm/1-8-Serial-128X160-SPI-TFT-LCD-Modul-Display-PCB-Adapter-SD-Socket-4-Arduino-/280937300096?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item41692b0080
Nice price available to my location and look like they could be good to shrink some projects down! Anyone ever tried these eBay specials?
Online Online
No but I wonder if the interface chip it uses ST7735R is compatible with the ST7735 (nothing immediately
springs out when comparing the datasheets).  The UTFT library supports ST7735 serial from what I can
glean.   Spend some time comparing the two datasheets perhaps?
South UK
Good idea I will take a look when I find some spare time
« Last Edit: December 23, 2012, 09:49:25 pm by dtokez » Logged
Norfolk UK
The ebay URL you supplied contains a download link to a file that appears to contain an Arduino library and example sketches for the device. The example sketches are .pde extension instead of .ino so the libraries may need modifying to work with Arduino IDE v1.0+
South UK
Ah right, I just found the link you mentioned. Is it easy to update the libs?
Norfolk UK
After downloading them to check what may need changing and I read they are Adafruit libraries so I suggest getting them direct from them to ensure latest versions. You need two libraries, this https://github.com/adafruit/Adafruit-GFX-Library and this https://github.com/adafruit/Adafruit-ST7735-Library I downloaded and compild them without problem but don't have a display to test them.
South UK
Hi Riva, that's good news! I think I will order a display then as it seems there should be a way to get them working smiley
Can't go wrong for that price really!
Katowice POLAND
Hi
I did smiley
They are superb smiley-grin The PCB layout is easy to design and make. Now you can get this lcd on ready pcb adapter for few bucks.
I already ordered 3 of them. Adafruit library works wery well smiley
i bought 2
http://www.ebay.pl/itm/1-8-Serial-TFT-Color-LCD-Display-Module-With-SPI-Interface-5-IO-Ports-128X160-/350631278788?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item51a340b8c4
and one
http://www.ebay.pl/itm/1-8-Serial-SPI-TFT-LCD-Module-Display-PCB-Adapter-Power-IC-SD-Socket-128X160-/370677580907?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item564e1b046b
so cheap as dirt smiley-grin
« Last Edit: December 25, 2012, 06:54:54 pm by zachwiej » Logged
South UK
Thats great stuff! So basically the cheaper one has no PCB but the slightly more expensive one is ready to be run from an arduino?
Katowice POLAND
Yes smiley I tested already one without pcb (I made my own) and its doing fine smiley
South UK
Sounds perfect I will try one out, thanks smiley
France
This one looks interesting: 2.8" inch 320x240 Touch TFT LCD Display Module, SPI Interface, ILI9320 at USD14
http://www.ebay.co.uk/itm/2-8-inch-320x240-Touch-TFT-LCD-Display-Module-SPI-Interface-ILI9320-/181008290930?pt=LH_DefaultDomain_0&hash=item2a24ef5472
avenue33
Katowice POLAND
I think that SPI can be for touch controler not the LCD
Online Online
The pinout suggest that there is another variant of the board supporting SPI (LCDB rather than LCDA) - perhaps
same vendor has this one too?
Rapa Nui
Pukao hats cleaning services
I've got this one:
http://www.ebay.co.uk/itm/1-8-Serial-128X160-SPI-TFT-LCD-Module-Display-PCB-Adapter-SD-Socket-/261150773094?_trksid=p2045573.m2042&_trkparms=aid%3D111000%26algo%3DREC.CURRENT%26ao%3D1%26asc%3D27%26meid%3D4648364954718621766%26pid%3D100033%26prg%3D1011%26rk%3D3%26sd%3D280937300096%26
working nice with the latest adafruit's ST7735 library.
The only issue I see is it uses BGR565 color coding (the driver does expect RGB565 coded colors).. smiley-confuse
p.
« Last Edit: January 04, 2013, 08:53:31 pm by pito » Logged
Pages: [1] 2 3   Go Up
