Topic: Test 1.5v battery mAh with analogread. (Read 2267 times) previous topic - next topic
stoopkid
I am interested in performing the typical which battery lasts longest experiment with some AA and AAA alkaline batteries. The idea was to simply put maybe a 20ohm resistor in circuit with it then measure the voltage. 1.5v / 20ohms = 75mA so my current in mA = analogRead / (1024 / 5 * 1.5) * 75... Or something like that, just a general idea.
My question is, when the voltage of the battery drops, is this equation still valid or will it not account for a dying battery? Because obviously that's the point.
Secondary question, I might not even worry about it, but can I drop the vRef to 3.3v by simply wiring it on the breadboard or PCB and connecting vRef to a 3.3v source? Then obviously the equation would change.
Thanks.
be80be
I would hook  a resistor across the battery read the volts drop across it till it dropped below the 75mA level and yes you can change the  vRef to 3.3 but i would leave it.
backbone
http://mad-science.wonderhowto.com/inspiration/diy-arduino-battery-tester-reveals-secret-capacity-disposable-batteries-0134638/
Enjoy
Never to old to learn and I learn every day
stoopkid
While this would definitely suit my needs, I was hoping to get the actual current. That way every few seconds I could see what the current was then at the end I could get an actual mAh reading rather than just a voltage/time number. Could I still do that?
PeterH
If you discharge the battery through a known resistance and measure the voltage across the resistor then you can calculate the current through the resistor; by integrating the current over time you can calculate the charge capacity. By integrating the voltage * current over time you can calculate the energy capacity.
