Loading...
Pages: [1]   Go Down
Author Topic: how to amplify Simple SD Audio?  (Read 943 times)
UK
Offline Offline
Newbie
View Profile
I managed to get this library (http://arduino.cc/forum/index.php/topic,112745.0.html) working on an Arduino Uno (R3) in under 30 minutes and was very happy to hear the audio coming out of my speaker - however, when I tried connecting an LM386N-3 based 1W amplifier (http://ebookbrowse.com/n48fl-pdf-d393297795) with a set gain of 50 (adjustable input attentuation via POT) to the output pin (using the recommendations in the docs (.h) for powered speakers), all I got was beeping noises rather than audio?
I tried another amp kit based on NE5532 chip and got the same result - which means I'm doing something very wrong :-)
Any advice appreciated!
Logged
Manchester (England England)
Online Online
Brattain Member
Solder is electric glue
View Profile
WWW
It is hard to see what you did because all that link did was to download a dmg file to my Mac, and I am not about to run random untrusted stuff on my machine.
However, it is well known that these amplifiers require large power supply decoupling capacitors to stop them hooting. I suspect that you have not got a big enough capacitor here.
Logged
Dubai, UAE
Offline Offline
Edison Member
View Profile
WWW
This LM386 circuit works well for me -
http://rcarduino.blogspot.co.uk/2012/08/adding-audio-to-arduino-projects.html?m=1
Duane B
Logged
Offline Offline
Jr. Member
View Profile
the audio signal level coming from a pwm pin is vey high - often too high - for direct connection to an amplifier. So try the following:
PWM out --> capacitor 100nF to 10uF --> potentiometer to ground with slider to input to amplifier
Poti value between 1k to 100k should work. If no poti availible, use resistor divider for ratio about 1:100 to 1:1000
Logged
UK
Offline Offline
Newbie
View Profile
Thanks for the suggestions all - I'll give it a try after xmas is over - the PDF from the link above for the LM386 circuit is attached.
Logged
Online Online
Brattain Member
View Profile
WWW
@Tuttut - The input to the amplifier shows it already going through a pot so thee is no worry about the input being too high.
Coupling the arduino output through a capacitor is however a good idea.
The circuit shown only a 220uF capacitor across the supply, I would recommend at least a 1000uF.
Make sure the ground of this circuit is connected to the ground of the arduino.
Logged
Dubai, UAE
Offline Offline
Edison Member
View Profile
WWW
Double check that your capacitors are the right way around as well
Duane B
rcarduino.blogspot.com
Logged
UK
Offline Offline
Newbie
View Profile
Looks like the problem was a dry joint on one of the caps in the amp circuit - it's working perfectly now :-)  I also reduced the input signal to the amp by running the audio output pin through a cap, resistor and then tying it to ground via another resistor.  works a treat now.  Thanks for the help folks!
Logged
Pages: [1]   Go Up
Print
Jump to:
