Loading...
Pages: [1]   Go Down
Author Topic: start with arduino  (Read 585 times)
Egypt
Offline Offline
Newbie
View Profile
Please need help to start verify my first code in arduino .. this massage take place in my compiler
C:\Program Files (x86)\Arduino\Arduino ERW 1.0.3\hardware\tools\avr\bin\avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=103 -IC:\Program Files (x86)\Arduino\Arduino ERW 1.0.3\hardware\arduino\cores\arduino -IC:\Program Files (x86)\Arduino\Arduino ERW 1.0.3\hardware\arduino\variants\standard C:\Users\Mohamed\AppData\Local\Temp\build852336354766841764.tmp\sketch_dec23a.cpp -o C:\Users\Mohamed\AppData\Local\Temp\build852336354766841764.tmp\sketch_dec23a.cpp.o
avr-g++: CreateProcess: No such file or directory
Please help me  smiley-cry smiley-cry smiley-cry smiley-cry smiley-cry smiley-cry
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
What you need to do is to save your sketch with a proper name first.
Then you need to post the code you are trying to compile, along with the links to any libraries you are using. Then we can see what is wrong.
It is probably that you have not installed a library that the code is wanting but we can't tell because you haven't posted the code.
Logged
Egypt
Offline Offline
Newbie
View Profile
when i click on verify this massage display on :avr-g++: CreateProcess: No such file or directory
please need help important case .... i use win 8 64bit and adruino uni R3 & adruino EWR 1.0.3
the sketch was named and i am not use any library it's a very simple code smiley-sad
« Last Edit: December 23, 2012, 11:02:50 am by mohamed_hamdy » Logged
Gosport, UK
Offline Offline
Faraday Member
View Profile
As you are using Eried's forked IDE, try adding a post to his thread. He might have a solution.
http://arduino.cc/forum/index.php/topic,118440.0.html
Logged
Offline Offline
Brattain Member
View Profile
WWW
Why are you not using the proper Arduino IDE?
What happens when you do?
Logged
Egypt
Offline Offline
Newbie
View Profile
The same error smiley-sad
Logged
Brazil
Offline Offline
Newbie
View Profile
WWW
can arduino access the folder where you saved the sketch? sometimes, privacy/protection settings from windows prevents it from happening.
Logged
Offline Offline
Brattain Member
View Profile
WWW
Then you arduino IDE install is not correct. Try installing it again.
Why is this in the Audio section? It has nothing to do with audio!
Logged
Pages: [1]   Go Up
Print
Jump to:
