Topic: Buttons, interrupts and de-bouncing (Read 4295 times) previous topic - next topic
dhenry
Quote
So does it make sense to always use interrupts
No. Nor does it make sense to always use polling.
As a matter of fact, it doesn't make sense to always do anything.
MrGlasspoole
Ok, more confused :smiley-roll:
I found this from Ladyada and she writes:
"To change the pins or number of buttons, just put them in the array called "buttons" and the rest of the code will automatically adjust."
http://www.adafruit.com/blog/2009/10/20/example-code-for-multi-button-checker-with-debouncing/
The second sketch uses interrupts. But she is using analog inputs and how can i just ad buttons if i can't just
use every input pin as interrupt??
This sketch also says: "which pin to use for reading the sensor? can use any pin!"
https://raw.github.com/adafruit/Adafruit-Flow-Meter/master/Adafruit_FlowMeter.pde
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
