Topic: How would you go about building a stand alone atmega 2560? (Read 5198 times) previous topic - next topic
To_noob_to_be_true
Could someone explain how to do so? Which pins would connect to a ceramic resonator ect?
johnwasser
Just look at the datasheet for the TQFP-pinout ATmega640/1280/2560:
10: VCC
11: GND
30: Reset
31: VCC
32: GND
33: XTAL2
34: XTAL1
61: VCC
62: GND
80: VCC
81: GND
98: AREF
99: GND
100: AVCC
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
CrossRoads
I'd do it like this.
You can get a breakout board from schmartboards.com, solder the chip in place, then add the few components needed.
JoeN
If you don't like the soldering aspect this guy will do it for you:
http://jkdevices.com/ATMEGA2560
If you do like the soldering aspect, you can get these boards on eBay and do it yourself.  You can probably get the chip from Atmel for free if you can do a little song and dance on the samples request page.
http://www.ebay.com/itm/TQFP-100-TQFP100-0-5mm-pitch-Adapter-PCB-PIC24-PIC32-
I will never ask you to do anything that I wouldn't do myself.
codlink
I am in the process of of designing a custom PCB for the 2560 using Eagle.  I may have an issue though, I have ran the DRC and the Itead DRC check advised that the pins on the 2560 have a clearance issue.  I am probably just going to finish the board and send it too Itead and see if they will still fab it.
//LiNK
CrossRoads
The '2560 on a breakout board looks like a pretty good deal, but there is only 1 hole/pin.
I like the schmartboard as it gives two holes/pin and I think would make assembling a standalone board a little easier.
I have a couple of 2560 chips & schmartboards, will see if the wife will let me do some playing today.
http://www.schmartboard.com/index.asp?page=products_qfp&id=70
Re: the custom PCB, try this eagle symbol, it has thinned down pads that itead will accept.
The standard one does not have enough clearance between pads for soldermask.
I have used this one before with itead.
codlink
Thanks Crossroads.  Hate having to rip up all of my traces..  But I guess every designer had to do it at least once..  lol
//LiNK
CrossRoads
Rip them up because the symbol placement is different?
Can you just drop the new footprint where the old one was, and the let the autorouter take care of the little disconnect at the end?
codlink
The 2560 I was using had the IO pins and VCC/GND on separate symbols.  The one you gave me was also bigger.  It's ok, I didn't like how I had the traces ran anyway..
//LiNK
CrossRoads
In the schematic only? The board symbol was okay?
Most of the time, I don't run many traces on the schematic, just names.
codlink
Yea, the schematic.  The package on the board is the same.  The new symbol you gave me was bigger and had the VCC and GNDs on one symbol so I had to reorganize everything.  I use the naming process to do mine as well.  Just had to line everything up in the schematic.  Like I said before, I didn't like how the traces were coming out on the board so I ripped them up and going to see if I can make it look more professional.
//LiNK
westfw
I would start with the Arduino MEGA Schematic and Board files (or maybe the Seeeduino MEGA files) and start deleting the pieces I didn't want.  Possibly just having the board made as-is and partially-populating it rather than doing a new design...
codlink
What's the fun in that?  I am also here to learn.
//LiNK
CrossRoads
I like that style of thinking!
White Christmas for us tomorrow, couple inches of snow on the way ...
westfw
Quote
You can learn a lot in the process of figuring out someone else's design.
Also, you weren't the original poster...
