Loading...
Pages: [1] 2 3 ... 5   Go Down
Author Topic: Audioino?  (Read 1852 times)
Offline Offline
Jr. Member
View Profile
Has anyone successfully done the Audioino where you can program your microchip through an audio file? I am trying to install the bootloader on my standalone arduino but I cannot figure out how to do it through the arduino IDE. How do I add that option to the menu? I know I have to edit the boards.txt but I am a bit lost from there.
http://www.hobby-roboter.de/forum/viewtopic.php?f=4&t=127
http://www.hobby-roboter.de/forum/viewtopic.php?f=4&t=128&p=531
Its really cool and would be perfect for a christmas gift I am working on since the recipient doenst have any arduino programmer and so I would be able to send updates just through an audio file.
Any help?
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
So why not send a serial programmer too?
http://www.ebay.com/itm/CP2102-USB-2-0-to-UART-TTL-6PIN-Module-Serial-Converter-/130683943875?pt=LH_DefaultDomain_0&hash=item1e6d5ebbc3
This with a simple trace cut (trace to the RST pin) and a jumper add (from DTR hole to the now isolated RST pin) will allow easy programming thru the IDE.
To install a bootloader, you need an In System Programmer (ISP) to connect to the SPI pins.
http://www.ebay.com/itm/USBASP-USB-AVR-Programmer-for-Atmel-USB-ASP-USBISP-ISP-Arduino-Bootloader-USA-/150739530304?pt=LH_DefaultDomain_0&hash=item2318c6b240
I have an Atmel AVR ISP MKii from Mouser.com, very useful for All the Arduino chips.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Offline Offline
Jr. Member
View Profile
Yea I could send a serial adapter but it would be nicer to simplify it. I also just always wanted to build one haha.
So I tried using an Arduino as ISP to do the programming
and set up the boards file to include
Code:
atmega328.name=Audioino w/ ATmega328 (8 Mhz)
atmega328.upload.protocol=arduino
atmega328.upload.maximum_size=30720
atmega328.upload.speed=57600
atmega328.bootloader.low_fuses=0xE2
atmega328.bootloader.high_fuses=0xDF
atmega328.bootloader.extended_fuses=0xFA
atmega328.bootloader.path=atmega
atmega328.bootloader.file=chAudioBoot_ATMEGA168_IN_PD1_LED_PB5.hex
atmega328.bootloader.unlock_bits=0x3F
atmega328.bootloader.lock_bits=0x0F
atmega328.build.mcu=atmega328p
atmega328.build.f_cpu=8000000L
atmega328.build.core=arduino
atmega328.build.variant=standard
Im not sure if I pointed to the correct hex file for the bootloader. Its all a bit confusing to use and im getting errors when I try to flash the bootloader.
Logged
The Netherlands
Offline Offline
Sr. Member
View Profile
Follow that link.
Meant ISP is a piece of hardware.
It connects to the 6 pin (3 x 2) header on your arduino, not the USB port normally used with the IDE.
Once you got your hands on such hardware, you can try using IDE to program your loader.
Logged
Offline Offline
Jr. Member
View Profile
I understand how isp works. Can I not use Arduino as ISP for something like this? I have ordered a usbasp but even when I get it, dont I have to edit the boards.txt file for the bootloader to show up on the arduino IDE so i can burn the bootloader? Thats the part I am confused on.
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
If you are installing the standard Uno bootloader, you do not need to modify boards.txt.
Logged
Offline Offline
Jr. Member
View Profile
I am trying to use the Audioino bootloader so its not the regular uno one. I'm not sure if I edited the boards file properly to allow for me to burn the new bootloader. I posted the links above if you can please look at the files it comes with. It comes with directions for how to do it in AVR studio I think, but i rather just stick with the arduino IDE since thats all i have at the moment.
Logged
Temple, Texas
Offline Offline
Sr. Member
View Profile
This seems to be a pretty good link about burning bootloaders using Arduino as ISP: http://www.ladyada.net/library/arduino/arduinoisp.html.  See the very last bit about using the avrdude command line to be able to specify a different bootloader's hex file.
Let us know how you come with this, it sounds pretty interesting to me!  I wonder if you could install a wav file to such a device using an iPhone or Android...
John
Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
I'm not sure if this will help, but I've uploaded bootloaders without using a "commercial" ISP programmer. Two different methods:
http://www.gammon.com.au/forum/?id=11635  (you put the bootloader into the sketch itself)
http://www.gammon.com.au/forum/?id=11638 (you can upload any file from an SD card)
Logged
Offline Offline
Jr. Member
View Profile
Thanks alot Nick! That looks awesome and I was looking for soemthing like Optiloader for custom bootloaders since I've been having issues with using Arduino as ISP with my UNO (even when using a 10uF cap between reset and ground)
So I tried using MUSHClient on my Windows virtualization and when I tried to follow your tutorial on adding the bootloader from Audioino (which im kinda worried only supports the ATMEGA168) i got and error from the script. I tried the "chAudioBoot_ATMEGA168_IN_PD1_LED_PB5" hex file from the Audioino folder. I think thats the correct bootloader file?
here is a screenshot of the error I got:
http://cl.ly/image/273F3X0v2L2n
Can you help me get the arduino script that incorporates the Audioino bootloader for an ATMEGA328 running at 8mhz (that would be just burning the correct fuses right?)
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Can you click that box that says "show errors in output window next time", run it again, and then copy and paste the error message that appears? There is something in red underneath I can't read.
Logged
Offline Offline
Jr. Member
View Profile
After looking at the actual error I was able to fix the error by simply adding a new end code to the Lua script. I got the following output from the script
Code:
// File = chAudioBoot_ATMEGA168_IN_PD1_LED_PB5.hex// Loader start: 3C00, length: 1024
// MD5 sum = 86 9B DA 86 0E 68 2B F1 0C 20 E5 47 D8 3C 8D E5
byte PROGMEM chAudioBoot_ATMEGA168_IN_PD1_LED_PB5_hex [] = {
0x0C, 0x94, 0x34, 0x1E, 0x0C, 0x94, 0x51, 0x1E, 0x0C, 0x94, 0x51, 0x1E, 0x0C, 0x94, 0x51, 0x1E,
0x0C, 0x94, 0x51, 0x1E, 0x0C, 0x94, 0x51, 0x1E, 0x0C, 0x94, 0x51, 0x1E, 0x0C, 0x94, 0x51, 0x1E,
0x0C, 0x94, 0x51, 0x1E, 0x0C, 0x94, 0x51, 0x1E, 0x11, 0x24, 0x1F, 0xBE, 0xCF, 0xEF, 0xD4, 0xE0,
0xDE, 0xBF, 0xCD, 0xBF, 0x11, 0xE0, 0xA0, 0xE0, 0xB1, 0xE0, 0xE8, 0xE9, 0xFF, 0xE3, 0x02, 0xC0,
0x05, 0x90, 0x0D, 0x92, 0xA0, 0x30, 0xB1, 0x07, 0xD9, 0xF7, 0x11, 0xE0, 0xA0, 0xE0, 0xB1, 0xE0,
0x01, 0xC0, 0x1D, 0x92, 0xA5, 0x38, 0xB1, 0x07, 0xE1, 0xF7, 0x0E, 0x94, 0xC3, 0x1F, 0x0C, 0x94,
0xCA, 0x1F, 0x0C, 0x94, 0x00, 0x1E, 0xDF, 0x93, 0xCF, 0x93, 0x00, 0xD0, 0x00, 0xD0, 0xCD, 0xB7,
0xDE, 0xB7, 0x1A, 0x82, 0x19, 0x82, 0x1A, 0x82, 0x19, 0x82, 0x89, 0xB1, 0x82, 0x70, 0x28, 0x2F,
0x30, 0xE0, 0x89, 0xB1, 0x90, 0xE0, 0x82, 0x70, 0x90, 0x70, 0x28, 0x17, 0x39, 0x07, 0xC9, 0xF3,
0x69, 0xB1, 0x62, 0x70, 0x10, 0x92, 0xB2, 0x00, 0x40, 0xE0, 0x50, 0xE0, 0x89, 0xB1, 0x26, 0x2F,
0x30, 0xE0, 0x90, 0xE0, 0x82, 0x70, 0x90, 0x70, 0x28, 0x17, 0x39, 0x07, 0xB9, 0xF3, 0x20, 0x91,
0xB2, 0x00, 0x10, 0x92, 0xB2, 0x00, 0x69, 0xB1, 0x62, 0x70, 0x48, 0x30, 0x51, 0x05, 0x30, 0xF0,
0x89, 0x81, 0x9A, 0x81, 0x82, 0x0F, 0x91, 0x1D, 0x9A, 0x83, 0x89, 0x83, 0x4F, 0x5F, 0x5F, 0x4F,
0x40, 0x31, 0x51, 0x05, 0x19, 0xF7, 0x29, 0x81, 0x3A, 0x81, 0xC9, 0x01, 0x88, 0x0F, 0x99, 0x1F,
0x82, 0x0F, 0x93, 0x1F, 0x25, 0xE0, 0x96, 0x95, 0x87, 0x95, 0x2A, 0x95, 0xE1, 0xF7, 0x9C, 0x83,
0x8B, 0x83, 0x80, 0x91, 0xB2, 0x00, 0x2B, 0x81, 0x3C, 0x81, 0x90, 0xE0, 0x82, 0x17, 0x93, 0x07,
0xC0, 0xF3, 0x16, 0xC0, 0x89, 0xB1, 0x90, 0xE0, 0x82, 0x70, 0x90, 0x70, 0x28, 0x17, 0x39, 0x07,
0xC9, 0xF3, 0x49, 0xB1, 0x10, 0x92, 0xB2, 0x00, 0x80, 0x91, 0xB2, 0x00, 0x2B, 0x81, 0x3C, 0x81,
0x90, 0xE0, 0x82, 0x17, 0x93, 0x07, 0xC0, 0xF3, 0x64, 0x2F, 0x62, 0x70, 0x10, 0x92, 0xB2, 0x00,
0x26, 0x2F, 0x30, 0xE0, 0x89, 0xB1, 0x90, 0xE0, 0x82, 0x70, 0x90, 0x70, 0x28, 0x17, 0x39, 0x07,
0x09, 0xF3, 0x49, 0xB1, 0x42, 0x70, 0x58, 0xE0, 0xA0, 0xE0, 0x60, 0xE0, 0x70, 0xE0, 0x89, 0xB1,
0x24, 0x2F, 0x30, 0xE0, 0x90, 0xE0, 0x82, 0x70, 0x90, 0x70, 0x28, 0x17, 0x39, 0x07, 0xB9, 0xF3,
0x10, 0x92, 0xB2, 0x00, 0x49, 0xB1, 0x80, 0x91, 0xB2, 0x00, 0x2B, 0x81, 0x3C, 0x81, 0x90, 0xE0,
0x82, 0x17, 0x93, 0x07, 0xC0, 0xF3, 0x29, 0xB1, 0x22, 0x70, 0xEA, 0x2F, 0xF0, 0xE0, 0xE0, 0x50,
0xFF, 0x4F, 0x80, 0x81, 0x88, 0x0F, 0x80, 0x83, 0x42, 0x70, 0x42, 0x17, 0x11, 0xF0, 0x81, 0x60,
0x80, 0x83, 0x51, 0x50, 0x11, 0xF4, 0xAF, 0x5F, 0x58, 0xE0, 0x6F, 0x5F, 0x7F, 0x4F, 0x42, 0x2F,
0x24, 0xE0, 0x68, 0x32, 0x72, 0x07, 0x99, 0xF6, 0x30, 0xE0, 0x90, 0x91, 0x04, 0x01, 0x80, 0xE0,
0x20, 0x91, 0x03, 0x01, 0x82, 0x0F, 0x91, 0x1D, 0x8A, 0x5A, 0x95, 0x45, 0x09, 0xF4, 0x31, 0xE0,
0x83, 0x2F, 0x0F, 0x90, 0x0F, 0x90, 0x0F, 0x90, 0x0F, 0x90, 0xCF, 0x91, 0xDF, 0x91, 0x08, 0x95,
0x1F, 0x93, 0xCF, 0x93, 0xDF, 0x93, 0xDA, 0x01, 0xF8, 0x94, 0x83, 0xE0, 0xFB, 0x01, 0x80, 0x93,
0x57, 0x00, 0xE8, 0x95, 0x07, 0xB6, 0x00, 0xFC, 0xFD, 0xCF, 0xAB, 0x01, 0x11, 0xE0, 0xEB, 0x01,
0xC0, 0x58, 0xDF, 0x4F, 0x8C, 0x91, 0x11, 0x96, 0x3C, 0x91, 0x11, 0x97, 0x20, 0xE0, 0xF9, 0x01,
0xE8, 0x0F, 0xF1, 0x1D, 0xCF, 0x01, 0x12, 0x96, 0x0C, 0x01, 0xFA, 0x01, 0x10, 0x93, 0x57, 0x00,
0xE8, 0x95, 0x11, 0x24, 0x07, 0xB6, 0x00, 0xFC, 0xFD, 0xCF, 0x4E, 0x5F, 0x5F, 0x4F, 0x4C, 0x17,
0x5D, 0x07, 0x41, 0xF7, 0x85, 0xE0, 0xFB, 0x01, 0x80, 0x93, 0x57, 0x00, 0xE8, 0x95, 0x07, 0xB6,
0x00, 0xFC, 0xFD, 0xCF, 0x81, 0xE1, 0x80, 0x93, 0x57, 0x00, 0xE8, 0x95, 0xDF, 0x91, 0xCF, 0x91,
0x1F, 0x91, 0x08, 0x95, 0x82, 0xE0, 0x80, 0x93, 0xB1, 0x00, 0x08, 0x95, 0x14, 0xB8, 0x17, 0xB8,
0x1A, 0xB8, 0xF8, 0x94, 0x10, 0x92, 0xB1, 0x00, 0xEE, 0x27, 0xFF, 0x27, 0x09, 0x94, 0x08, 0x95,
0xFF, 0x92, 0x0F, 0x93, 0x1F, 0x93, 0xCF, 0x93, 0xDF, 0x93, 0x82, 0xE0, 0x80, 0x93, 0xB1, 0x00,
0xC0, 0xE1, 0xD7, 0xE2, 0x66, 0xE0, 0x53, 0xE0, 0x70, 0xE2, 0x80, 0x91, 0xB2, 0x00, 0x85, 0x36,
0xA8, 0xF0, 0x10, 0x92, 0xB2, 0x00, 0x21, 0x97, 0x89, 0xF4, 0x85, 0xB1, 0x87, 0x27, 0x85, 0xB9,
0x61, 0x50, 0x51, 0xF4, 0x2D, 0x98, 0x14, 0xB8, 0x17, 0xB8, 0x1A, 0xB8, 0xF8, 0x94, 0x10, 0x92,
0xB1, 0x00, 0xEE, 0x27, 0xFF, 0x27, 0x09, 0x94, 0xC0, 0xE1, 0xD7, 0xE2, 0x89, 0xB1, 0x24, 0x2F,
0x30, 0xE0, 0x90, 0xE0, 0x82, 0x70, 0x90, 0x70, 0x28, 0x17, 0x39, 0x07, 0x19, 0xF0, 0x49, 0xB1,
0x42, 0x70, 0x51, 0x50, 0x55, 0x23, 0xC9, 0xF6, 0x2D, 0x9A, 0x60, 0xE2, 0xF6, 0x2E, 0x0E, 0x94,
0x53, 0x1E, 0x88, 0x23, 0x79, 0xF4, 0x90, 0xE2, 0x80, 0x91, 0xB2, 0x00, 0x85, 0x36, 0xE0, 0xF3,
0x10, 0x92, 0xB2, 0x00, 0x21, 0x97, 0xC1, 0xF7, 0x85, 0xB1, 0x89, 0x27, 0x85, 0xB9, 0xC8, 0xEE,
0xD3, 0xE0, 0xF2, 0xCF, 0x85, 0xB1, 0x8F, 0x25, 0x85, 0xB9, 0x80, 0x91, 0x00, 0x01, 0x82, 0x30,
0x61, 0xF0, 0x83, 0x30, 0xE9, 0xF4, 0x14, 0xB8, 0x17, 0xB8, 0x1A, 0xB8, 0xF8, 0x94, 0x10, 0x92,
0xB1, 0x00, 0xEE, 0x27, 0xFF, 0x27, 0x09, 0x94, 0x13, 0xC0, 0x10, 0x91, 0x02, 0x01, 0x00, 0xE0,
0x80, 0x91, 0x01, 0x01, 0xB8, 0x01, 0x68, 0x0F, 0x71, 0x1D, 0x76, 0x95, 0x76, 0x2F, 0x66, 0x27,
0x77, 0x95, 0x67, 0x95, 0x80, 0xE0, 0x90, 0xE0, 0x45, 0xE0, 0x51, 0xE0, 0x0E, 0x94, 0x08, 0x1F,
0x10, 0x92, 0x00, 0x01, 0xC4, 0xCF, 0x25, 0x9A, 0x59, 0x9A, 0x0E, 0x94, 0x50, 0x1F, 0x80, 0xE0,
0x90, 0xE0, 0x08, 0x95, 0xF8, 0x94, 0xFF, 0xCF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
}; // end of chAudioBoot_ATMEGA168_IN_PD1_LED_PB5_hex
I then added that as a .h file into your Atmega_Board_Programmer and edited the code a bit to incorporate the Audioino Bootloader and I was able to successfully bootload a ATMEGA328p.
You can see the some of the alterations I made to the script and the output from Nick's programmer software in the screenshot:
http://cl.ly/image/2A2A0q333S0z
I have yet to actually test the bootloader however, so that would be the next step!
Logged
Offline Offline
Jr. Member
View Profile
After trying to test the Audioino I realized it wasnt working properly. I am a bit worried that the fuses were possibly incorrect since in the ReadMe file of the audioino bootloader they use these settings for the atmega168
Code:
ATMEGA168, 1K bootloader: -Wl,--section-start=.text=0x3c00
Fuses Atmega168:
Extended: 0xFA
HIGH: 0xDF
LOW: E2
But I am not sure if I should run the same fuses for Atmega328p since currently I am burning the fuses of the lilypad to get the same 8mhz internal clock setting
Code:
else if (subcommand == 'A')  // use internal 8 MHz clock
      Serial.println (F("Using Audioino 8 MHz loader."));
      bootloader = chAudioBoot_ATMEGA168_IN_PD1_LED_PB5_hex;
      newlFuse = 0xE2;  // internal 8 MHz oscillator
      newhFuse = 0xDA;  //  2048 byte bootloader, SPI enabled
      addr = 0x7800;
      len = sizeof chAudioBoot_ATMEGA168_IN_PD1_LED_PB5_hex;
      }  // end of using the 8 MHz clock
Should I change the fuses?
I am expecting the audioino to blink for 6 seconds after reset to show me that it is ready to be programmed through audio. Currently I am not seeing that. It might be that is because the current atmega328 I am burning is plugged into an arduino board... maybe i should make that a standalone and try again.
Logged
Offline Offline
Jr. Member
View Profile
So I created a standalone atmega328 and changed the fuses to
Code:
      newhFuse = 0xDC;  //  512 byte bootloader, SPI enabled
      newextFuse = 0xFF;
      addr = 0x3C00;
which better follows the fuses that were in the README of the bootloader. I was able to successfully bootload the chip and i see the blinking status LED and when I try to use the java program to play the audio file the status LED begins to blink quickly and that it. Regardless of the hex file I program it always blinks quickly and nothing else changes and whenever I reset the Audioino, it going back into the slow blinking LED. It seems like its stuck in the bootloader and that its actually never becoming programmed properly.
Any suggestions?
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Quote
You want the 1024 byte bootloader, not the 2048 or 512 byte one. That is the first thing to get right.
Logged
Pages: [1] 2 3 ... 5   Go Up
Print
Jump to:
