Pages: [1] 2 3   Go Down
Author Topic: Connecting Arduino to PIC  (Read 1749 times)
Philippines
hi im doing this project FYI: im a beginner at programming..
i want to use the digital output of arduino and connect it to a pic16f877a pin..
so arduino(output) to pic16f877a(input)
i tried connecting it to my pic and it doesnt do anything..
i tried connecting a resistor and led to the connecting wires so that i will know if the connections are good..
and the led lights up, so arduino is sending a signal but the pic doesnt do anything..
what am i doing wrong?..
« Last Edit: December 24, 2012, 01:15:04 am by siyete » Logged
SE USA
@ssh0le
is the pic expecting input where your hooking up to? its a software driven device like the arduino
Philippines
yes i configured all PORTA to input, here is part of my code for the pic:
ALL_DIGITAL = True
PORTB_PULLUPS = On
TRISA  = %111111
TRISB  = %00000000
TRISC  = %00000000
TRISD  = %00000000
TRISE  = %111
----------Arduino Controls----------
arduino:
If PORTA.2 = 1  And PORTA.3 = 1 Then
GoTo Forward_Slow
ElseIf PORTA.2 = 0  And PORTA.3 = 1 Then
GoTo Left_Slow
ElseIf PORTA.2 = 1  And PORTA.3 = 0 Then
GoTo Right_Slow
Else
    If PORTE.0 = 1 And PORTE.1 = 0 Then
    GoTo Grab_Ball
    ElseIf PORTE.0 = 0 And PORTE.1 = 1 Then
    GoTo Back_Slow
    Else
    GoTo Rotate_Right
    EndIf
EndIf
GoTo main
'----------Drive Controls----------
Forward_Slow:
High PORTD.0
Low  PORTD.1
High PORTD.2
Low  PORTD.3
Clear PORTD
GoTo main
Right_Slow:
High PORTD.1
High PORTD.2
Clear PORTD
GoTo main
Left_Slow:
High PORTD.0
High PORTD.3
Clear PORTD
GoTo main
Back_Slow:
Low  PORTD.0
High PORTD.1
Low  PORTD.2
High PORTD.3
Clear PORTD
GoTo main
Rotate_Right:
Low  PORTD.0
High PORTD.1
High PORTD.2
Low  PORTD.3
DelayMS 500
Clear PORTD
GoTo main
the led is lighting up, meaning the wiring is good right?.. and i believe the program is also good..
because when i switch the port meant for arduino and replace it with an infrared proximity sensor it does what it is supposed to do..
the proximity sensor also gives high and low signal, same as arduino but why when i plug arduino on the pic it does nothing..
« Last Edit: December 24, 2012, 03:20:01 am by siyete » Logged
Australia
Does the 16f887 have some kind of program in it ?
Philippines
yes the pic16f877a is programmed to receive input
and the arduino is programmed to produce output..
both use digital signal..
the land of sun+snow
I'm not famliar with using Basic on a PIC, but the '877A boots up with Port A pins
all set to analog, and need to be changed for use as digital pins. I don't know if
"ALL_DIGITAL = True" actual does this for Port A. In any case, you might try using one
of the Port B or C pins for the input.
Also, there is no indication in your code what the various configuration fuses are set to,
nor what the oscillator setting is. Maybe the compiler takes care of that automatically,
I don't know. Is this a Picaxe, or what?
Kitchen-Sink Arduino-compatible boards
Australia
A circuit diagram would help.
The 16F887 code seems to be some kind of combinatorial logic that needs combinations of input pins to do anything.
Are all the pins that are defined as inputs connected to something?
Test the arduino and pic individually to make sure that they behave as expected, then connect them together.
Otherwise, you don't where the problems are.
Philippines
those are not my full codes, i just posted parts of the code.. im using proton basic..
im using xtal osc 4mhz, and using "ALL_DIGITAL = True" really changes the pins to digital..
these are my pin configurations:
arduino - pic - purpose
digital 13 - PORTA.3 - Send Signal To PORTD[Output Pin] To Turn Left Motor On/Off
digital 12 - PORTA.2 - Send Signal ToPORTD[Output Pin] Output Pin To TurnRight  Motor On/Off
yes all the pins are defined as input, its in the codes i posted
TRISA  = %111111, 1 is for input 0 is for output..
im working on doing a circuit diagram,..
its been christmas vacation so ive been busy with family matters..
ive doing this right now, ive tested arduino and its working fine..
gonna test my pic16f877a next, but i believe the problem lies on the signal..
im thinking if i should use a switching transistor..
im currently using this wiring: but ill try using a 2n3904 transistor:
what?
I have a couple of surgestions
Rather than diving head first and writing pages of code, just try a simple program with one switch in and one led out.
Get yourself an 18F452, all 18F's can be programmed with the C18 compiler which is going to be closer to arduino code and therefore make porting code between devices easier, I never liked Proton, it is easy to learn but somewhat limited in functionality and speed, The 16F877 is still a good chip but not supported by C18
Alternativly try a smaller chip like 16F84a with less hardware so less complication, it's easier to upscale later
This is always the proper way to proceed with new programs. Get the basic, simple stuff
working first, and then build around that.
Philippines
just tried it an hour ago, and it doesnt work.. tried both active low and active high..
maybe i really need to have a transistor for it to work.. ill try to drop by local electronic store to get 2n3904..
UK
Forget the circuits.
What does the PIC do when you connect the input to +5V or 0V?
(what do the PIC forums say?)
You don't need a switch, just connect the pin to 0V or 5V. Since it's not working, as I
indicated a couple of days ago, "you might try using one of the Port B or C pins for the
input".
Left Coast, CA (USA)
Measurement changes behavior
OK maybe a dumb question but I have to ask anyway. You do have a common ground wire connected between the arduino and the PIC, correct?
Lefty
Pages: [1] 2 3   Go Up
