Topic: Connecting Arduino to PIC (Read 7584 times) previous topic - next topic
mauried
What exactly is the PIC supposed to do.
You have set Port A and Port E to inputs.
Are you setting all the pins of Port A and Port E to some combination of logic levels.
The code seems to need a combination of logic to make something happen.
If you set pins to input, then you must connect either a 1 or a 0 to all the pins, or enable pullups ,otherwise they will float
and give erratic results.
siyete
#16
Dec 27, 2012, 08:04 am Last Edit: Dec 27, 2012, 11:55 am by siyete Reason: 1
Forget the circuits.
What does the PIC do when you connect the input to +5V or 0V?
(what do the PIC forums say?)
just tried it an hour ago, and it doesnt work.. tried both active low and active high..
You don't need a switch, just connect the pin to 0V or 5V. Since it's not working, as I
indicated a couple of days ago, "you might try using one of the Port B or C pins for the
input".
when i connect the pin to 5v it does what is it supposed to do..
it sends the output to the motor from portd..
OK maybe a dumb question but I have to ask anyway. You do have a common ground wire connected between the arduino and the PIC, correct?
Lefty
i powered the arduino from the vdd pin(ground) and vss pin(+5v) of the pic..
and i connected the arduino gnd to the digital gnd..
am i doing it wrong?..
abrookfield
vdd is normally +v, vss is normally 0v
www.reeftopper.com
siyete
sorry i got it backwards, anyway is the wiring supposed to be like this:
im having doubts on using the pic pin as gnd so using the supply gnd will do right?..
abrookfield
remove the link from "Input to pic" and "gnd"
www.reeftopper.com
retrolefty
Well that drawing shows correct common grounding between the arduino and the PIC, but it also shows a permanent ground wired to the PIC input pin, which is certainly incorrect.
Lefty
siyete
Lefty
ok i finally got it to work using that wiring, but you said incorrect can i know where i should place the common ground?..
retrolefty
Hard to understand what you are saying. Can you post a new drawing of how you have it presently wired and working?
Lefty
siyete
#23
Dec 27, 2012, 03:44 pm Last Edit: Dec 27, 2012, 03:49 pm by siyete Reason: 1
got it to work using this:
you said it was incorrect due to the pic input being permanently grounded, so where should i place the common ground?..
AWOL
I don't think so.
See that node labelled "Input to PIC", and the one labelled "PIC PSU Gnd" and that solid black line that connects the two?
That's why it doesn't work.
siyete
I don't think so.
i guess but im not sure if your saying i should do
"arduino output<resistor<pic input" and a different connection for the common ground?..
tried using vss for common ground but i dont know why it doesnt work..
AWOL
That schematic is grounding your PIC input - that's a solid "LOW" on that input.
Connect the grounds together, but don't short an input to ground.
(unless it says "unused inputs should be tied to ground" somewhere in the datasheet. This is clearly not unused, because it is connected to an output from the Arduino.)
If you want a series resistor, I guess that's OK.
siyete
#27
Dec 31, 2012, 01:22 pm Last Edit: Dec 31, 2012, 01:28 pm by siyete Reason: 1
im really confused now, can you show me a schematic of the wiring on how i can connect the output from arduino to the input of the pic?..
it tried connecting it directly and it doesnt work.. can you please show me how.. do i need a transistor?..
will something like this work:
or
oric_dan
I haven't been following this thread lately, but somehow the replies have gotten you
completely confused. In fact, your original ckts in posts #8 and #11 are ALL correct,
and since then, they are all wrong.
However, you possibly did not have a ground wire connected between the 2 processor
boards originally. So, forget everything else, and go back to your original ckts, and
where it says Gnd, just make sure that point goes to the grounds on both boards.
siyete
need help again, i dont know if its my wiring or whathever but my arduino is rebooting/restarting..
im using this wiring:
http://i46.tinypic.com/51dopu.jpg
a 12v battery powers my pic16f877a and my arduino so that covers the common ground right?..
i cant pinpoint the reason why it is restarting..
1. power is not enough?..
2. my wiring is wrong so its rebooting?..
3. arduino low memory so its restarting?..
4. my arduino is damaged?..
5. any other reason you can think of...
need help.. thanks..
