Pages: 1 [2]   Go Down
Author Topic: Problem running Gobetwino  (Read 1880 times)
Guys i am starting to be somehow frustrated with this Leonardo board smiley-sad
Tried to run MegunoLink, can t get live data...
Tried to run Fetch, cant get live data...
Don t know if this deserves a new thread....
Thanks for your help.
Seattle, WA USA
Seattle, WA USA
Not yet. Lets see if we can't get GoBetwino working first. If so, then the change that needs to be made to GoBetwino probably needs to be made to the other classes you are having issues with.
You can then create new topics for each of them.
Copenhagen / Denmark
Do it !
i will try to put the dtr enable in gobetwino, just give me a tiny little time  smiley
« Last Edit: December 27, 2012, 03:32:32 pm by MikMo » Logged
Seattle, WA USA
Seattle, WA USA
MikMo sent me a link to the new version of GoBetwino to test. It works with the Mega, the Duemilanove, AND the Leonardo. I'm sure he'll be making it available for all, soon.
Do it !
Ok so it was the DTR that should be enabled.
Thanks for testing Paul  smiley
I will repackage GoBetwino ASAP.
There is also a little bug that was discovered recently that i will fix.
Seattle, WA USA
Seattle, WA USA
While you're at it...
It would be nice to change the serial port, and have that close the existing port, if opened, and open the new one, without having to restart GoBetwino.
Do it !
That is in 06  smiley-cool
Wonderfull smiley Can t wait to try then.
Thanks.
And by the way, when fixed could you explain what was the problem(s)?
I would like to understand. And think other people would too.
Thanks again.
Seattle, WA USA
Seattle, WA USA
The Leonardo uses a different USB to Serial converter chip from other Arduinos. This one appears to need the DtrEnable flag (Data Terminal Ready) set in order for communications to occur.
My code had it; why I can not remember. MikMo's (and most other) code does not, because it has not been necessary, until now.
MikMo added it to his code. His code is now able to talk to the Leonardo.
It's time, I think, for you to open the other threads we talked about, mentioning your inability to communicate with the Leonardo. Reference this thread, so the fix needed is obvious. I'm sure that quick turnaround will be possible on the other code will be made, too.
Ok.
I will do that.
Thanks.
Do it !
There is an updated version here:
http://www.mikmo.dk/gobetwinodownload.html
I wil try now.
Thanks.
Check.
I ran the examples for working with CPFIL and LGFIL commands with Leonardo and it works perfectly.
Thanks a lot guys.
Go to this thread that will guide you to gobetwino home page to download the recent version of gobetwino:
http://arduino.cc/forum/index.php/topic,139721.0.html
Pages: 1 [2]   Go Up
