« Reply #15 on: December 27, 2012, 02:46:03 pm » |
Guys i am starting to be somehow frustrated with this Leonardo board  Tried to run MegunoLink, can t get live data... Tried to run Fetch, cant get live data... Don t know if this deserves a new thread.... Thanks for your help.
Seattle, WA USA
Seattle, WA USA
« Reply #16 on: December 27, 2012, 02:51:36 pm » |
Don t know if this deserves a new thread.... Not yet. Lets see if we can't get GoBetwino working first. If so, then the change that needs to be made to GoBetwino probably needs to be made to the other classes you are having issues with. You can then create new topics for each of them.
Copenhagen / Denmark
Do it !
« Reply #17 on: December 27, 2012, 03:30:49 pm » |
i will try to put the dtr enable in gobetwino, just give me a tiny little time
« Last Edit: December 27, 2012, 03:32:32 pm by MikMo »
Seattle, WA USA
Seattle, WA USA
« Reply #18 on: December 28, 2012, 08:28:12 am » |
MikMo sent me a link to the new version of GoBetwino to test. It works with the Mega, the Duemilanove, AND the Leonardo. I'm sure he'll be making it available for all, soon.
Do it !
« Reply #19 on: December 28, 2012, 08:38:21 am » |
Ok so it was the DTR that should be enabled. Thanks for testing Paul  I will repackage GoBetwino ASAP. There is also a little bug that was discovered recently that i will fix.
Seattle, WA USA
Seattle, WA USA
« Reply #20 on: December 28, 2012, 09:07:43 am » |
There is also a little bug that was discovered recently that i will fix. While you're at it... It would be nice to change the serial port, and have that close the existing port, if opened, and open the new one, without having to restart GoBetwino.
Do it !
« Reply #21 on: December 28, 2012, 10:42:13 am » |
That is in 06
« Reply #22 on: December 28, 2012, 02:07:09 pm » |
I'm sure he'll be making it available for all, soon. Wonderfull  Can t wait to try then. Thanks.
« Reply #23 on: December 28, 2012, 02:10:09 pm » |
And by the way, when fixed could you explain what was the problem(s)?
I would like to understand. And think other people would too.
Thanks again.
Seattle, WA USA
Seattle, WA USA
« Reply #24 on: December 28, 2012, 04:25:43 pm » |
The Leonardo uses a different USB to Serial converter chip from other Arduinos. This one appears to need the DtrEnable flag (Data Terminal Ready) set in order for communications to occur.
My code had it; why I can not remember. MikMo's (and most other) code does not, because it has not been necessary, until now.
MikMo added it to his code. His code is now able to talk to the Leonardo.
It's time, I think, for you to open the other threads we talked about, mentioning your inability to communicate with the Leonardo. Reference this thread, so the fix needed is obvious. I'm sure that quick turnaround will be possible on the other code will be made, too.
« Reply #25 on: December 28, 2012, 05:01:51 pm » |
Ok.
I will do that.
Thanks.
Do it !
« Reply #26 on: December 29, 2012, 02:16:17 pm » |
« Reply #27 on: December 30, 2012, 07:04:09 am » |
I wil try now.
Thanks.
« Reply #28 on: December 30, 2012, 07:59:08 am » |
Check. I ran the examples for working with CPFIL and LGFIL commands with Leonardo and it works perfectly. Thanks a lot guys. Go to this thread that will guide you to gobetwino home page to download the recent version of gobetwino: http://arduino.cc/forum/index.php/topic,139721.0.html
