Loading...
Pages: [1]   Go Down
Author Topic: Debouncing button with sam3x registers  (Read 844 times)
Offline Offline
Newbie
View Profile
I saw in the datasheet that there is a possibility to debounce by setting the right registers.since i don't know how to access registers yet I must ask again on how to do this. And no,I don't want to use debouncing software nor using a capacitor.
Thanks in advance
Decrux
Logged
Brighton, UK
Offline Offline
Newbie
View Profile
You might get some ideas from a header file with lots of 'debounce' mentions, component_supc.h, in:
    ... \arduino-1.5.1r2\hardware\arduino\sam\system\CMSIS\Device\ATMEL\sam3sd8\include\component
But I'm afraid I don't yet know how this part of the Arduino 1.5 tree relates to anything else...
Jim
Logged
Offline Offline
Newbie
View Profile
Hello,
I figured it out myself. For those interested:
Code:
/* PB26 is digital Pin 22, view Datasheet page 647 */
pinMode(22, INPUT);
digitalWrite(22, HIGH); // Pullup
attachInterrupt(22, myInterruptServiceRoutine, FALLING);
REG_PIOB_IFER |= 1<<26; // Input Filter Enable Register
PIOB->PIO_DIFSR |= 1<<26; // Debouncing Input Filter Select Register
PIOB->PIO_SCDR |= 0xff; // Slow Clock Divider Register
But I would rather use the digital Pin names instead of the Port Pins. Ideas?
Greetings
decrux
Logged
nr Bundaberg, Australia
Offline Offline
Tesla Member
Scattered showers my arse -- Noah, 2348BC.
View Profile
WWW
Are you sure that will debounce enough? From the data sheet
Quote
When the glitch or debouncing filter is enabled, a glitch or pulse with a duration of less than 1/2
Selected Clock Cycle (Selected Clock represents MCK or Divided Slow Clock depending on
PIO_SCIFSR and PIO_DIFSR programming) is automatically rejected, while a pulse with a
duration of 1 Selected Clock (MCK or Divided Slow Clock) cycle or more is accepted.
So as I read it unless you can get one of those clocks down to a period of say 10-50mS you will not be doing any meaningful debouncing, at least not in the normal context of handling a mechanical switch.
How slow does the Slow Clock get with 0xff in that register?
______
Rob
Logged
Rob Gray aka the GRAYnomad http://www.robgray.com
Offline Offline
Sr. Member
View Profile
There is an array struct called g_APinDescription which contains the port and mask for each Arduino pin number. You use it like this for example:
g_APinDescription[pin].pPort -> PIO_SODR = g_APinDescription[pin].ulPin; // equivalent to digitalWrite(pin,HIGH)
Replace 'PIOx ->' with 'g_APinDescription[pin].pPort ->'  and '1<<yy' with 'g_APinDescription[pin].ulPin'
So for example PIOB->PIO_DIFSR |= 1<<26 would become:
g_APinDescription[22].pPort -> PIO_DIFSR |= g_APinDescription[22].ulPin;
from a quick read of the data sheet I think the filter can go as slow as 1 second smiley At 0xff it's about 16ms.
Logged
Offline Offline
Newbie
View Profile
Thank you for your answer. How I understood it: g_APinDescription[] is an array of PinDescription structures (from the Arduino.h). PIO_SODR is the Set Output Data Register.
"DIV: Slow Clock Divider Selection for Debouncing
Tdiv_slclk = 2*(DIV+1)*Tslow_clock." from datasheet page 669
with a slow clock frequency of 32 kHz etc.
Your code example is working perfectly.
Logged
Offline Offline
Tesla Member
View Profile
WWW
Quote
How did you test it?
Quote
That is slow enough smiley How do you get such a low freq?
32kHz / 255 is still 128Hz.
______
Rob
Logged
Offline Offline
Newbie
View Profile
Well I simply replaced
in my code example for debouncing posted above and the button was debounced.
1 second is what I get by putting DIV = (2¹⁴ - 1) and not 255 in Tdiv_slclk = 2*(DIV+1)*Tslow_clock , see datasheet page 669. The DIVi are the single bits in DIV. slow clock frequency is by default 32 kHz. datasheet page 277. Also T = 1/f etc.
Greetings
« Last Edit: December 25, 2012, 09:05:51 am by decrux » Logged
Offline Offline
Tesla Member
View Profile
WWW
Yes I see, so you can get down to 32kHz / 16383 if you want. Nice feature.
______
Rob
Logged
Pages: [1]   Go Up
Print
Jump to:
