Offline
Newbie
« on: December 24, 2012, 01:51:06 pm » |
I would like to control a bar of RGB LEDs I am going to make that will run off 12V. I understand I will need 3 to control the red green and blue separately. What kind of potentiometer will I need to do this?
Thanks Macke
Logged
SE USA
Offline
Faraday Member
@ssh0le
« Reply #1 on: December 24, 2012, 01:58:41 pm » |
with nothing else in the mix a huge expensive rheostat to handle the current
Logged
http://arduino.cc/forum/index.php?action=unread;boards=2,3,4,5,67,6,7,8,9,10,11,66,12,13,15,14,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,86,87,89,1;ALL
Offline
Newbie
« Reply #2 on: December 24, 2012, 02:02:13 pm » |
I really need that big of one for 12V? It will probably only be no more than 2A
Logged
Offline
Newbie
« Reply #3 on: December 24, 2012, 02:19:15 pm » |
12V DC if that is unclear
Logged
Left Coast, CA (USA)
Offline
Brattain Member
Measurement changes behavior
« Reply #4 on: December 24, 2012, 02:30:52 pm » |
Probably have to know more about your 'bar of rgb led's and how they are wired up. A drawing showing the individual leds and how they are wired to each other would be a good starting point. And on using a pot to adjust current flow, I would propose that you are best off using both a resistor and a pot in series such that turning the pot to 'zero ohms' position doesn't burn everything up. Calculate the fixed resistor to set the absolute maximum current flow and then allow the pot to dim from there.
Lefty
Logged
Offline
Newbie
« Reply #5 on: December 24, 2012, 02:50:43 pm » |
The RGB bars will be wired up in parrellel with each LED getting 3 resistors. So I don't think I would need the resistor in front of the pot, because there is resistors on the LEDs.. There will be 4 wires going into the Bar, with one red, one green, one blue, and a ground. With a pot on each of the RGB wires. If this does any good please respond or ask more questions of what you need to know, all I need is 3 potentiometers that can resist the flow of 12V DC.
Thanks Macke
Logged
The Netherlands
Offline
Sr. Member
« Reply #6 on: December 24, 2012, 03:11:49 pm » |
You don't understand the reason for the questions (which is also the reason why the first respondant showed you that monster). 12 volt doesn't tell us anything. You probably do not want to control the voltage, you want to control amperage. To be sure about that, we need to know how your bars are built. How many LED's are in there and how are they hooked up. Are all LED's of the same color in parallel (all A's together and al K's togehter), or are they series connected (K of LED 1 connected to A of led2, K of 2 to A of 3 and zo on), or any combination of these two possibilities ? What resistors are connected to the LED's ?
Controlling the brightness of LED's should not be done by a potentiometer, if that is your goal. There's a much better way to do this, certainly if you're using an Arduino.
Logged
Offline
Newbie
« Reply #7 on: December 24, 2012, 03:40:13 pm » |
I don't know my specifics yet, but like I said the LEDs will be in parrellel with the reds all connected, the greens all connected, and the blues all connected, and ground all connected. The purpose of this is to not use an arduino so I can save 30$. If I was using arduino, I would know exactly how to do that. But is there any way just to give me a general pot I could probable use? Also, my power supply will probably be 2A so I know my LEDs wont draw more than that.
My RGB LEDs will use 20mA so say I have 12 RGB LEDs, that's technically 36 different LEDs, so 36 times .02 = .72, so my bars will probably be right about .72 AMPS.
If that helps clear things up and I can get an answer, great, if not, ask more questions. Also I don't need an EXACT potentiometer, just like a general idea of what I would need. I'm mainly in planning staged right now and am looking at the cost. And then I might order them.
And also, why shouldn't the pot control LEDs? I understand the duino can do this much easier, but once agin, cost. I don't understand why pots shouldn't do this job, seeing is they are pretty much variable resistors, which is what I want to do, vary the resistance to control brightness..
Thanks Macke
Logged
SE USA
Offline
Faraday Member
@ssh0le
« Reply #9 on: December 24, 2012, 04:17:37 pm » |
depends on current, that joker I posted above is only rated for 1.4 amps no matter the voltage, and its going to get hot pretty quickly. I use them frequently at work using 9 to 16 volts
this is why we like PWM, a small pot a 555 (or arduino) and a fet can achieve the same thing without burning off current as heat
« Last Edit: December 24, 2012, 04:20:42 pm by Osgeld »
Logged
The Netherlands
Offline
Sr. Member
« Reply #10 on: December 24, 2012, 04:56:58 pm » |
Because you will probably be regulating voltage instead of amperage. LED's brightness can be set a lot smoother, safer and have a much better range by using PWM and thus using an Arduino, but ofcourse you can also use a 555. Using a 555 and a few components will save you some money, but you'll have to build a PCB or use a breadboard (times 3). To save space you could also consider a 558 which is 4 * 555 in one.
Logged
Offline
Newbie
« Reply #11 on: December 24, 2012, 06:23:47 pm » |
Well then if its going to be that much trouble I guess it's going to be with an arduino... Any one know of any cheap arduino clones?
I know of the teensys but those are just about as much as a arduino from amazon.. So...
Thanks everyone, I guess I misunderstood potentiometers!! Macke
Logged
The Netherlands
Offline
Sr. Member
« Reply #12 on: December 24, 2012, 07:01:47 pm » |
If you're going for cheap, you can consider a chinese nano board. They are cheap, small and offer enough for your LED bars. Shipping is often included in the ridiculous low prices but you might have to wait for 2 - 4 weeks for them to arrive.
As there is no financial contribution to the Arduino community in these low prices, you might consider donating a bit some time in the future as a thank you to it.
Logged
0
Offline
Tesla Member
Arduino rocks
« Reply #13 on: December 26, 2012, 12:56:58 pm » |
Surely a 555 timer and a MOSFET switch can do PWM cheaper than an Arduino? Something like:
Logged
