Topic: Fuel Gauge for Lipo? (Read 1 time) previous topic - next topic
Nishant_Sood
anyone here used a Fuel Gauge for Lipo? can suggest me any?
"Real Men can Accomplish  Anything"
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੁਂ!
www.winacro.com
Nishant_Sood
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੁਂ!
www.winacro.com
retrolefty
The concept of having a 'fuel gauge' indication for a Lipo depends on your expectation of accuracy and context. A Lipo single cell has a range of output voltages that vary pretty linearly from 4.2vdc at 100% of charge to 3.0 at what most consider a good 0% or empty charge. Discharging a lipo cell too low can permanently damage the cell so different people use different 'cut-off' voltage value. Now if you wanted a totally accurate fuel gauge measurement value you would not depend just on the cells terminal voltage but rather measure the actual mAH consumption of current consumed over time, which is a lot more complex then just measuring the terminal voltage of the cell. And of course if your specific lipo battery is made from a number of series wired single cells then the voltage values I gave above would be 2X or 3X, etc depending on the number of series cells your pack has.
So if your dealing with just a single cell then wiring the cells output terminal to an arduino analog input pin would allow you to measure the cell's terminal voltage and then based on that value calculate it's relative position between 0% and 100% terminal voltage. If your using a multiple cell lipo then you would need to use a two resistor voltage divider to safely measure the voltage on your arduino and the scale as required in your software.
Lefty
jerseyguy1996
Sparkfun sells a few.  Here's one:
https://www.sparkfun.com/products/10617
Arduino Uno;
Mega328
CrossRoads
Try these Nishant, MAX17047, MAX17050
http://www.maximintegrated.com/datasheet/index.mvp/id/7181/t/al?ver=C&utm_expid=50713806-2&utm_referrer=http%3A%2F%2Fwww.maximintegrated.com%2Fpst%2Frun.mvp%3Fq%3Dlipo%20fuel%20gauge%26spell%3D1%26site%3D_products%26num%3D20%26access%3Dp
Both shown as In Production, may have to ask Maxim for a sample to get some tho.
Nishant_Sood
Thanks Sir Robert ,actually I would need to see that whether one of these 2 are available on Digi/mouser/element 14 or not to buy them
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੁਂ!
www.winacro.com
Nishant_Sood
Hi Again Sir The problem with these maxim parts is that they are available in atleast thousands!!!!! I want like 2-5. XD :smiley-eek-blue:
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੁਂ!
www.winacro.com
