Topic: RFID reader received XXxxx 000 (Read 852 times) previous topic - next topic
Paradigm
Hi All,
          I had just received my Parallex RFID reader and connected them to my Arduino Uno with
Arduino RX to RFID SOUT
Arduino GND to RFID GND
Arduino Digital pin 2 to RFID /Enable
Arduino +5V to RFID Vcc pin.
          However when I run the code in the forum, I got XXxx 00 as shown at the bottom of the post and not the card number. BTW I am using the 2 cards that come together with the RFID reader. I do not know what happen. Anyone can advise? Thanks a lot
http://www.parallax.com/Store/Microcontrollers/BASICStampModules/tabid/134/txtSearch/rfid/List/1/ProductID/114/Default.aspx?SortField=ProductName%2cProductName
Code: [Select]
// RFID reader for Arduino
// Wiring version by BARRAGAN <http://people.interaction-ivrea.it/h.barragan>
// Modified for Arudino by djmatic
int  val = 0;
char code[10];
int bytesread = 0;
Serial.begin(2400); // RFID reader SOUT pin connected to Serial RX pin at 2400bps
pinMode(2,OUTPUT);   // Set digital pin 2 as OUTPUT to connect it to the RFID /ENABLE pin
digitalWrite(2, LOW);                  // Activate the RFID reader
  if(Serial.available() > 0) {          // if data available from reader
    if((val = Serial.read()) == 10) {   // check for header
      bytesread = 0;
      while(bytesread<10) {              // read 10 digit code
        if( Serial.available() > 0) {
          val = Serial.read();
          if((val == 10)||(val == 13)) { // if header or stop bytes before the 10 digit reading
            break;                       // stop reading
          code[bytesread] = val;         // add the digit
          bytesread++;                   // ready to read next digit
      if(bytesread == 10) {              // if 10 digit read is complete
        Serial.print("TAG code is: ");   // possibly a good TAG
        Serial.println(code);            // print the TAG code
      bytesread = 0;
      digitalWrite(2, HIGH);                  // deactivate the RFID reader for a moment so it will not flood
           delay(1500);                       // wait for a bit
// extra stuff
// digitalWrite(2, HIGH);             // deactivate RFID reader
Tom Carpenter
#1
Dec 28, 2012, 01:19 pm Last Edit: Dec 28, 2012, 02:16 pm by Tom Carpenter Reason: 1
Code: [Select]
Serial.begin(2400);
Look at the bottom right of the arduino Serial Monitor, and tell me what is wrong  :).
~Tom~
Paradigm
Oops,
          Sorry. I dont know that I need to still set the serial monitor. I thought serial.begin(2400) will do the job...hahaha
