Topic: Is my board dead (Read 2372 times) previous topic - next topic
lanctotsm
Dec 25, 2012, 09:01 pm Last Edit: Dec 25, 2012, 09:23 pm by lanctotsm Reason: 1
I was trying to test a PS/2 mouse sensor, and I think that the way that the PCB was wired up I may have hooked up ground to 5v through only a resistor. Now I cannot get Windows to recognize a Due device, only the programming port. Am I toast? Also all the digital pins are outputing 3.3v...
Edit:(I checked the circuitry and there is a capacitor between ground and 5v which should block all current)
I havent even programmed it yet, and I held down the erase button to make sure that there is no program on it.
Ive gotten the arduino ide to recognize the com port, but when I try to program it says that there is no device on the port, and the ARM chip gets very hot
lanctotsm
#1
Dec 25, 2012, 09:29 pm Last Edit: Dec 25, 2012, 09:32 pm by lanctotsm Reason: 1
Its probably dead, I have no clue what happened. I think something may have shorted or it was defective... Never even programmed it : (
All the pwm pins are .6v lower than pin 13 and the regular digital io pins are 2.0 volts
jgmdavies
Worrying...
Does the ARM chip still get hot when you have just the board connected via USB to a PC (nothing else at all)?
Jim
retrolefty
Not dead, just pining for the fjords.
Lefty
jgmdavies
Slartibartfast would be proud!
