« on: December 25, 2012, 07:55:45 pm » |
im messing around with my new arduino uno and im unable to get my 10mm led to blink. it is wired to the arudino correctly and the led is on. Im connected to serial port 3 and im using the uno board on the programmer. When i send the correct blink code to arudino the TX and RX flash, but pin 13 led doesnt flash and the 10 mm led doesnt flash. im lost? is it the board? am i just culeless? any help would be great.
Austin, TX
Online
CMiYC
« Reply #1 on: December 25, 2012, 07:59:20 pm » |
Post your code.
« Reply #2 on: December 25, 2012, 08:02:39 pm » |
/* Blink Turns on an LED on for one second, then off for one second, repeatedly. This example code is in the public domain. */ // Pin 13 has an LED connected on most Arduino boards. // give it a name: int led = 13;
// the setup routine runs once when you press reset: void setup() { // initialize the digital pin as an output. pinMode(led, OUTPUT); }
// the loop routine runs over and over again forever: void loop() { digitalWrite(led, HIGH); // turn the LED on (HIGH is the voltage level) delay(1000); // wait for a second digitalWrite(led, LOW); // turn the LED off by making the voltage LOW delay(1000); // wait for a second }
Austin, TX
Online
CMiYC
« Reply #3 on: December 25, 2012, 08:06:00 pm » |
What does "uno board on the programmer" mean? What programmer?
What operating system are you using?
« Reply #4 on: December 25, 2012, 08:08:27 pm » |
in running windows 7 and i downloaded arduino 1.0.3
i was explaining how i selected the correct board and serial port on arduino 1.0.3.
Austin, TX
Online
CMiYC
« Reply #5 on: December 25, 2012, 08:14:51 pm » |
Does the led on pin 13 blink if the led isn't connected?
Are you sure the upload is completing without any error messages on the IDE?
« Reply #6 on: December 25, 2012, 08:19:14 pm » |
when I remove the 10mm led, pin 13 doesnt change. yes after uploading i only get a done uploading message...no error message.
Austin, TX
Online
CMiYC
« Reply #7 on: December 25, 2012, 08:21:22 pm » |
The LED and its current limiting resistor, correct?
« Reply #8 on: December 25, 2012, 08:23:14 pm » |
ya when i remove both, pin 13 led stays the same.
« Reply #9 on: December 25, 2012, 08:54:49 pm » |
after a little more tinkering i figured out that i had been applying power to the 10mm led its self along with the power coming from pin 13. Its working properly now, thank you for your time.
The Netherlands
« Reply #10 on: December 26, 2012, 06:27:39 am » |
That's the best way to learn. Make some mistake and find out yourself what you just did (being a bit annoyed about it). Thanks for sharing your solution.
