Pages: 1 2 [3] 4   Go Down
Author Topic: 2 servos (or any functions) operating simultaneously?  (Read 4571 times)
Seattle, WA USA
Seattle, WA USA
I think I'm heading in the right direction and what I now understand or at least think I understand is that there is a conversion problem.
But, I'm not going to show you my code.
It is between the 'serial buffer' and the 'readString' variable which is then indexed to 'n' in 'servo.write()'.
Well, certainly. Fix it. Or not. Only you can see what you are talking about.
I'm still looking for applicable information on this subject.
What subject would that be?
denver
...no matter where you go, there you are
PaulS:
So are your comments serious?
                                       ...joking?
                                 or seriously joking?
the code I've been working on is on post #27
       are you saying you aren't going to post yours?
Well, if you look at post #27, you can see it too
if you were to run it, you can certainly see what it do
Unfixed. And so.
the subject is apparently in the form of a question as the title of the thread (see title)
      any more explanation of my problem would be ad nauseam
If you have any info that could possibly help me solve it, I'd love to know about it.
UK
Online Online
If you've been working on the code in post #27, presumably it now doesn't look like the code in post #27, so you need to post it again.
Now.
Well, "2 servos (or any functions) operating simultaneously?" seems to have you stummped. The code only does one thing at a time, but the code itself performs actions so fast you will not be able to detect the individual actions (unless you add delays and such).
Well, if the "it" problem is a knowledge deficit on your part, it is up to you to get up to speed.
put in key search words,
denver
AWOL:
I have probably made 100's of changes to the code in #27 by now, except none of them have have brought me any closer to my goal.  Each change has had either no effect, produces undesirable effects, nullifies the code altogether, or doesn't compile.
I believe each half of the code (PROGMEM with table to Serial buffer) and (Serial.read to index. to .write) are doing things I want to see happen, I just can't seem to integrate them to work together.  Nothing I have done has furthered what is already there.
So, effectively, the code remains unchanged.
zoomkat:
I understand that it does one thing at a time and gives the impression of simultaneity, the code you presented to me (2nd half of the code in #27) definitely produces this effect.  I'm still trying to figure out what function/s will replace manually inputting parameters to serial.
The "it" certainly results from my surplus of ignorance but I'm not sitting idle waiting for someone to bestow their esoteric knowledge unto me, although it would be sweet to be blessed with such an occurrence, not unlike you supplying much the code I'm working with now.  I'm doing my due diligence and have gone through the entire reference especially focused on 'string theory', investigated many of the links provided and their links also, as well as other forums and books.  I'm learning as much as I can as quickly as I can - I may have totally overlooked the exact solution because I didn't know what I was looking at, I don't know.
I'm not going to give up on the issue, I want to understand how it is done, but I'm reaching a threshold of having to re-prioritize in order to meet the deadline for the robotics challenge.  I've figured out a way for a hexapod to use 2 servos to do the work of the 12 originally planned and as long as I am able to get the parts printed it shouldn't be too difficult to make happen.  I won't need to have the servos operate simultaneously.
I will continue to work on this simultaneous servo problem in my spare time.  In the meantime I built a different style of 'walking' robot prototype using 2 servos out of battery compartments and paperclips.  I've got a couple of other projects that I want to finish/get started after the challenge.  I'll go nuts if I only focus on this problem.
[img][img]
« Last Edit: January 26, 2013, 03:41:06 am by evolion » Logged
There are lots of three servo hexipods, and other simple walking bots. Below are some ideas.
http://www.google.com/search?num=100&hl=en&lr=&tbo=d&as_qdr=all&spell=1&q=three+servo+hexapod&sa=X&ei=DVYDUdKGAcbo0gGWlYFQ&ved=0CC8QBSgA&biw=1173&bih=642
http://davidbuckley.net/DB/Inspire.htm
denver
Ha Ha, she's one hot bot.
I thought I'd post my first project.
I don't have much to offer the forum yet, but maybe someone can benefit from this.
I built this robot out of roof flashing, designed to stay on top of fine loose sand,  spike-paddles were cut into each wheel and a 'ski' was on a pivot in the rear
I wish I had a pic of it finished
here's the code I used with it:
  ~this has nothing to do with my hexapod idea
/* 10-5-10
  Pete Dokter
  SparkFun Electronics
This is an example sketch for Arduino that shows very basically how to control an Ardumoto
 motor driver shield with a 5V Arduino controller board.
~~~ The variable values in this code have changed significantly from the (above) author's draft,
    I also incorporated bumper sensors (whiskers) with iterations and fixed the northward navigation
#include <Wire.h>
#include <LSM303.h>  //compass/accelerometer
LSM303 compass;
int pwm_a = 3;   //PWM control for motor outputs 1 and 2 is pin 3
int pwm_b = 11;  //                               outputs 3 and 4 is pin 11
int dir_a = 12;  //direction control for motor outputs 1 and 2 is pin 12
int dir_b = 13;  //                                      outputs 3 and 4 is pin 13
const int bumperPinR = 2;   //bumper pins
const int bumperPinL = 4;
int bumperStateR = 0;      //variable for reading the bumper status
int bumperStateL = 0;
int IRsensorPin = A0;     //input pin for IR sensor
int IRsensorValue = 0;    //variable to store value of IR sensor
int LEDPin = 13;          //On when backing up
  pinMode(pwm_a, OUTPUT);   //Set control pins to be outputs (motors)
  pinMode(pwm_b, OUTPUT);
  pinMode(dir_a, OUTPUT);
  pinMode(dir_b, OUTPUT);
  //initialize bumper and IR pins
  pinMode(bumperPinR, INPUT);
  pinMode(bumperPinL, INPUT);
  pinMode(IRsensorPin, INPUT);
  pinMode(LEDPin, OUTPUT);
  digitalWrite(dir_a, LOW);    //Set motor direction, 1 low, 2 high
  digitalWrite(dir_b, LOW);    //Set motor direction, 3 high, 4 low
  analogWrite(pwm_a, 255);     //set both motors to 100% duty cycle
  analogWrite(pwm_b, 255);
  Wire.begin();
  compass.init();
  compass.enableDefault();
  //Use Calibrate example program for compass values
             //(environment specific ~magnetics differ from place to place, recalibrate)
     //M min X: -405 Y: -108 Z: -9 M max X: -382 Y: -86 Z:8
                   //values are copied from serial monitor, pause calibration to copy
   compass.m_min.x = -405;
   compass.m_min.y = -108;
   compass.m_min.z = -9;
   compass.m_max.x = -382;
   compass.m_max.y = -86;
   compass.m_max.z = +8;
    digitalWrite(LEDPin, LOW);
  digitalWrite(dir_a, LOW);   //motor direction, 1 low, 2 high (forward)
  digitalWrite(dir_b, LOW);   //                      3 high, 4 low
  analogWrite(pwm_a, 200);    //motors run at 80% duty cycle (slower)
  analogWrite(pwm_b, 200);
 compass.read();
 int heading = compass.heading((LSM303::vector) {1,0,0} );   //1,0,0 aligns North
    Serial.println("");
    Serial.print("Compass: ");
    Serial.print(heading);
    Serial.print("\t");
 //IR reading
  IRsensorValue = analogRead(IRsensorPin);
    Serial.print("IR Reading: ");
    Serial.print(IRsensorValue);
    Serial.print("\t");
 //read state of bumper value
  bumperStateR = digitalRead(bumperPinR);
  bumperStateL = digitalRead(bumperPinL);
 //Check IR Sensor
   if(IRsensorValue > 455)
        Serial.println("");
        Serial.println("IR rev ");
  //reverse
     digitalWrite(dir_a, HIGH);  //motor direction, 1 low, 2 high
     digitalWrite(dir_b, HIGH);  //                     3 high, 4 low
     analogWrite(pwm_a, 225);    //motors run slower than 100% duty cycle =(255)
     analogWrite(pwm_b, 225);
      delay(450);
  //turn right
     analogWrite(pwm_a, 15);     //turns left in reverse
     analogWrite(pwm_b, 245);    //points further right in forward direction
      delay(520);
  //forward
     digitalWrite(dir_a, LOW);   //motor dir, 1 low, 2 high
     analogWrite(pwm_a, 230);    //motors run at ()% duty cycle
     analogWrite(pwm_b, 230);
      delay(850);
 //check if bumper triggered
  if (bumperStateR == LOW)
      //back and turn L
         Serial.println("");
         Serial.println("bumperR rev ");
   //reverse
     digitalWrite(dir_a, HIGH);  //motor dir, 1 low, 2 high
      delay(450);
   //turn left
     analogWrite(pwm_b, 245);    //points further right in forward direction)
      delay(525);
   //forward
     digitalWrite(dir_a, LOW);   // 1 low, 2 high
      delay(880);
  if (bumperStateL == LOW)
      //back and turn R
         Serial.println("");
         Serial.println("bumper L rev ");
   //reverse
     digitalWrite(dir_a, HIGH);   //1 low, 2 high
     digitalWrite(dir_b, HIGH);   //3 high, 4 low
     analogWrite(pwm_a, 225);     //motors slower than 100% duty cycle
      delay(450);
   //turn right
     analogWrite(pwm_a, 245);     //turns left in reverse
     analogWrite(pwm_b, 15);      //points further right in forward direction)
      delay(525);
   //forward
     digitalWrite(dir_a, LOW);    //1 low, 2 high
     digitalWrite(dir_b, LOW);    //3 high, 4 low
     analogWrite(pwm_a, 230);     //motors at ()% duty cycle
      delay(880);
 //break out of iteration, start navigation
     if(heading < 255)     // (270) = north
       //turn left
         Serial.print("left");
       analogWrite(pwm_a, 135);    //motor A (left) slower, B (right) faster
        delay(40);
     if(heading > 285)
       //turn right
         Serial.print("right");
       digitalWrite(dir_a, LOW);   //1 l, 2 h
       digitalWrite(dir_b, LOW);   //3 h, 4 l
       analogWrite(pwm_a, 225);    //motor A faster, B slower
       analogWrite(pwm_b, 135);
        delay(40);
  How do I attach a normal size photo?
« Last Edit: January 28, 2013, 01:06:24 am by evolion » Logged
denver
Ok, so I found a new approach to my problem.  I'm a bit more hopeful but I can't get it to compile.
Here is what I found (the list of compiler errors is huge):
//(this sketch is straight from the playground)
// test sketch for MegaServo library
// this will sweep all servos back and forth once, then position according to voltage on potPin
#include <MegaServo.h>
#define FIRST_SERVO_PIN  22
MegaServo Servos[MAX_SERVOS] ; // max servos is 32 for mega, 8 for other boards
int pos = 0;      // variable to store the servo position
int potPin = 0;   // connect a pot to this pin.
  for( int i =0; i < MAX_SERVOS; i++)
    Servos[i].attach( FIRST_SERVO_PIN +i, 800, 2200);
  sweep(0,180,2); // sweep once
void sweep(int min, int max, int step)
  for(pos = min; pos < max; pos += step)  // goes from 0 degrees to 180 degrees
  {                                  // in steps of 1 degree
    for( int i =0; i < MAX_SERVOS; i++){
      Servos[i].write( pos);     // tell servo to go to position
    delay(15);                  // waits 15ms for the servo to move
  for(pos = max; pos>=min; pos-=step)     // goes from 180 degrees to 0 degrees
  pos = analogRead(potPin);   // read a value from 0 to 1023
    Servos[i].write( map(pos, 0,1023,0,180));
  delay(15);
I compared the above sketch to others I found (sorry they aren't cited, I didn't record where the other similar examples were from) and here are the changes I made:
#include <Wire.h>
#include <arduino.h>
#define NBR_SERVOS 12
  MegaServo Servos[NBR_SERVOS] ; // max servos is 12
   MegaServo MegaServo;
  MegaServo.writeMicroseconds(1500);
  int i = 0;
  pinMode(i,OUTPUT);
void Servos digitalWrite.MegaServo( )
  for( int i =0; i < NBR_SERVOS; i++)
    for( int i =0; i < NBR_SERVOS; i++){
  delay(15);
compiler error:  MegaServo:23: error: expected initializer before 'digitalWrite'
This is the only error that this version produces.  I don't know that it's necessarily a good thing or not.  I guess I don't understand what an 'expected initializer' is, even after some research on it.  If this does end up compiling, I don't know that it will work correctly as I don't understand most of what is going on in it.  Please don't ask me WHY I made some of the changes were made in it as I don't really remember and probably couldn't tell you in the first place.  All I know is that this is the closest it has come to compiling.
Thanx for any input on this
UK
Online Online
what's that?
Seattle, WA USA
Seattle, WA USA
Having an instance name the same as the class name is not the brightest idea I've seen today.
denver
AWOL:
If I knew, I could tell you.
At some point I had tried some random switching of terms, that's probably what that is a result of.
Correct me if I'm wrong.  Your comment would imply that you can easily see or even know for certain that something is not right with that particular line of code.  I'm fairly sure that's not the only error but if you would care to expand on your comment a bit and share some of the wisdom I am not privy to, I would more than appreciate being exposed to what you know about it.
PaulS:
I was thinking the same thing when I saw something similar in another code but figured I would give it a shot anyway.
While we are on the subject of luminescence, would you like to shed some light on why the idea is so dim?  Maybe explain the conflict or possible conflicts?  Can instance and class written structures be/look exactly the same?  Could you suggest how it be done differently?  What would you do in such a case?  Does this even need to be done at all?
What I do know is that there is only one compiler error in the revision - an enormous improvement from the original in the playground where it is stated (in sum):  just copy and paste, no changes necessary.  I don't know who's smoking more of what on the playground but as you can see it clearly was not that simple.  Unless of course there is some obvious step omitted that every programmer knows to be common knowledge while overlooking the inexperienced newbie who's yet to be a programmer.
« Last Edit: February 08, 2013, 04:28:17 am by evolion » Logged
UK
Online Online
Could you post a link to the Playground page where you found that please?
denver
http://playground.arduino.cc//Code/MegaServo
UK
Online Online
It isn't even like saying "My hovercraft is full of eels", a sentence that follows the rules of English syntax, but which makes very little sense.
Here, we have the implication that we're looking at a function definition which doesn't return anything.
After that, my brain refuses to recognise what is going on.
I almost see a class name ("Servo"), a function name I recognise ("digitalWrite"), but with a structure field name ("MegaServo") I don't.
It's a bit like a Dali painting, expressed in C.
Afterthought Edit: In contrast, Duff's Device is more like an M.C. Escher print
« Last Edit: February 08, 2013, 07:39:04 am by AWOL » Logged
Johannesburg UTC+2
.....not true... makes perfect sense to Hungarians in tobacconists.
IT Crowd:
Roy... "Have you tried turning it off and on again?"
Moss.. "Have you tried forcing an unexpected reboot?"
Pages: 1 2 [3] 4   Go Up
