Loading...
Pages: [1] 2 3 ... 18   Go Down
Author Topic: 8x8x8 multiplexed LED cube with an Arduino Mega 2560  (Read 13754 times)
Cluj-Napoca, Romania
Offline Offline
Full Member
View Profile
WWW
Hi Everybody!
I'm a new member in this forum, who has just received an Arduino Mega 2560 as a Christmas gift smiley This means that I've never ever worked with Arduino before. but I have a big dream for about 2 years now, building an 8x8x8 LED cube and I'm going to try that as my first Arduino project. For this I need a little bit of help smiley Please help me verify my theory about how I plan to construct it and give me useful advice if you can.
I'm an amateur when it comes to electronics. I've done some electronics projects in my life (like a binary LED clock controlled with a Raspberry Pi or a miniature locomotive driver which controls H0 locomotives with PWM signals), so know a few things, but there are quite many things out there that I don't know. In the last two years I have searched the Internet for how an 8x8x8 LED cube can be created. I've read many things, half of which I don't understand at all, so I'd like to create my cube in the simplest fashion possible, but not compromising the perfection of it. I hope to avoid using shift registers, latch circuits and other additional complications which I think will be possible, as it seems that I'm in a lucky situation because the Mega 2560 has a lot of I/O pins (54 digital pins + 16 analogue pins = 70 pins in total). That gives me enough pins to create the 8x8x8 cube with multiplexing.
Usually what people do is to connect the anodes of all the LEDs which are above each other, obtaining 64 columns and to connect the cathodes of all the LEDs which are in the same horizontal plane, obtaining 8 planes. This way you can light up the LEDs using multiplexing and you need 64+8 pins. But even the Arduino Mega 2560 does not have that many pins, so I had to find another way. And there is a pretty simple way to reduce the number of pins: divide each horizontal plane into two half planes. This way you will only need 64/2=32 pins to connect to the anodes and 8*2=16 pins to connect to the cathodes, a total of 32+16=48 pins! Well, the multiplexing software will have to handle the special kind of multiplexing which uses half planes, but that's OK (I've never written software for Arduino so far, but I'm confident that I can do it, I have more doubts about the hardware part smiley ).
Based on the above approach, the LED cube can be made by dividing the cube into 16 zones (half planes). The anodes of the vertical LED columns are all connected together and the 32 resulting column groups are connected to a digital Arduino pin. The cathodes in each of the 16 half planes are also soldered together and each such group is connected to an Arduino digital pin. These 16 half plane groups are multiplexed from software, meaning that at any given time the current can only run through one half plane and the 16 half plane pins are switched very fast one after the other. Persistence of vision makes it possible for humans to see the cube as if all 16 half planes would be lit up at all times. This is the theory. To light up a given LED in the 8x8x8 matrix, we would have to pull the appropriate anode pin high and the appropriate cathode pin low, if I understood this correctly from other similar projects.
In theory it is that simple. In practice, however, it is far more complicated because of the Arduino's current limitations (global current limitation and per pin current limitation). I think the total current limitation of the 5V rail is 50 mA and in addition each pin has a maximum limitation of 40 mA. So it's clear that I'll need to power the LED cube from an external power source and that I'll need to add some transistors between the Arduino and the actual LEDs. I will use the signals coming from the Arduino pins to switch the transistor inputs and the transistor outputs will switch the actual, higher power LEDs. And this is the point where things start to become unclear to me. As we have established above, at any given point in time only one half plane should be lit up. that means that in the worst case 32 LEDs should be on at any given time. But as we all know, the multiplexing software can have bugs, which is likely to happen since it's my very first Arduino software. That means that we need to assume the worst: that it could happen that al 512 LEDs light up at the same time. That means quite an amount of current and we'll need some kind of hardware protection to limit the current and to protect the Arduino from such dangers.
But how much maximum current will be flowing exactly through the LED cube at a given time? To determine that, the fundamental question to be answered is: how much current is needed by a single LED? I'm planning to use standard superbright 5mm LEDs. Their datasheet states that they should be operated at 20 mA and people use this value most of the time. However, I have found that giving those LEDs 20 mA is a complete and utter waste of current. I've done some experiments and those LEDs are very bright even at 0.5-1 mA! Surprising, but true. SO I plan to limit the current through each LED with a resistor of appropriate value to 1 mA. I hope this can work with multiplexing (fast on/off switching of the LEDs), not just when the LEDs are continuously on. Please let me know what you think about this. If this can work, then at any given time no more than 32 mA should flow through the cube, or if the software has a bug and all LEDs light up, no more than 512 mA. Now this even questions the need to use transistors between the Arduino and the LEDs. The digital pins connected to the anodes would only be supplying 1 mA each and the digital pins connected to the cathodes would only be sinking 32 mA each. I'm thinking that I could add resistors to the anodes to limit the current to 1 mA and resistors to the cathodes to limit the current to 32 mA, for safety. Is this safe enough? Would this work?
If the above suggestion is unsafe, I plan to use ULN2803 ICs for switching the LEDs based on the signal coming from the Arduino pins. If I do this, I don't know if I should add current limiting resistors between the Arduino pins and the ULN2803 input legs, or the ULN2803 chips already include some current limitation mechcanism which will make sure that the current flowing through each of the Arduino pins and the total current flowing through all the Arduino pins is small enough. Between the ULN2803 output legs and the LEDs I plan to add current limiting resistors which would limit the current through each LED to 1 mA. Also, if I'm going for the ULN2803 based approach, I'm still thinking of avoiding an external power supply and taking the current from the Arduino's 5V rail. I'll still need to add a resistor to limit the total current taken from the 5V rail to a toal of 32 mA, in case the software goes nuts and turns on all the LEDs.
What do you think of my approach. Is this achievable at all? is it oversimplified? As I said in the beginning, I want to keep it as simple as possible, but I do not want to endanger my Arduino board in any way, so hardware protection against too big currents is a must have in all possible ways.
Thanks in advance for any good advice you might be able to give me!
Andras
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Quote
My advice is:
Start with a smaller cube, say 5x5x5. You will learn a lot about both the electronics and the software that will put you into a much better chance at being successful when you scale up to 8x8x8 cube.
Your desire to not use shift registers is a poor choice and makes your project require more components and complexity then it needs to. There are special 16 bit serial shift registers that also include programmable constant current outputs that solve the led current control problem. Datasheet: ( http://www.onsemi.com/pub_link/Collateral/CAT4016-D.PDF )  I can't emphasize how much simpler the whole project becomes when using these special shift register/driver chips then if you instead try some other method of current control for the leds. You will need an external source of +5vdc to power the cube, but it will only need to be rated at about 2 amps max output current capacity (64x.02A = 1.28 amps)
Be sure to buy 'diffused' leds as their wider dispersial of light gives a much better effect then narrow beam brighter leds.
Here is a very good led cube project page where you can learn a whole lot before committing to buying stuff. While it's based on using a PIC micro chip the hardware design is 100% applicable to an arduino based project. I used their basic design for my arduino (actually a standalone 328p chip ) driven 5x5x5 blue led cube and while challenging from both a construction point of view and software design (I wrote the sketch from stratch) it was successful from the git go.
http://picprojects.org.uk/projects/lc/index.htm#Description
Once completed I think you will find the biggest challenge is coming up with creative and complex pattern displays. I found this very tedious and time consuming and stopped after building maybe 6 or 7 pattern scripts. What is really required is some kind of PC based GUI led pattern generator editor where you can build your pattern frame by frame and then get the raw binary data patterns that you can copy and paste into your cube sketch.
Lefty
« Last Edit: December 26, 2012, 12:12:11 pm by retrolefty » Logged
Eugene, Oregon
Offline Offline
Sr. Member
View Profile
WWW
I would agree with lefty that you should really start smaller, 8x8x8 is a lot, really a lot. You will have to complete many stages of the project before you understand why not do do something a specific way, but by then you will have used up 500 leds, and have  a huge mess.
I would suggest starting with a 3x3x3, you can probably build one and get it working within a day, it will only waste 27 leds, you wont really need other hardware (should also use 9 resistors), so you can focus on learning how to build a cube, which itself is fairly difficult.
I would then progress to controlling the cube with serial data instead of parallel data. This will mean using shift registers or LED driver.  I did an instructable about converting parallel to serial with shift registers, it might be useful http://www.instructables.com/id/4x4x4-LED-cube-upgrade-with-Shift-Registers-74hc5/
You may want to charlieplex your cube, this will probably reduce the number of pins to where you can control it with a mega. By my calculations you will need a minimum of 24 pins to control 512 LEDs using charlieplexing. Charlieplexing is a bit difficult because it requires that some LEDs face one way, while others need to face another way, so building is a little more difficult. It also takes advantage of tri-state micro-controllers, so programming is a bit more difficult too.
Besides Persistance of Vision, and Multiplexing, you also need to think about duty cycle. If you have a 4x4x4 cube, you will have a 25% duty cycle (no LEDs will be on longer than 1/4 of the time), with an 8x8x8 you usually have a 12.5% duty cycle which may make things dramatically dimmer than you think. If you split your planes into 2 planes of 32 LED, then you will have a 6.25% duty cycle, pretty low! That may not work out too well, it would be best to test that before building 500 LED cube.
The other real problem with spliting the plane is that each plane creates dimensional stability, if you split the plane, you are splitting the cube into 2 rectangles that may not be as dimensionally stable.
There are many ways to skin that cat, and I've just mentioned the more common ways that I have seen.
Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
You might want to look at the MAX7219 chip. That multiplexes 64 LEDs:
http://www.gammon.com.au/forum/?id=11516
It's not particularly cheap, from memory, but it could save you buying a lot of transistors and current-limiting resistors.
The chip does its own current limiting, and its own multiplexing. Since it uses SPI you could add additional chips, using only one extra SS line for each additional chip.
My personal advice would be to start smaller initially, just get comfortable with coding on this platform, using LEDs, resistors, current flows etc.
Logged
Offline Offline
Full Member
View Profile
WWW
Hi Guys!
First of all, thank you for your replies!
I've read the suggested articles. The one that has really caught my attention is this one:
It's a very good explanation of how the MAX7219 chip can be used to drive a 8x8 LED matrix relatively easily. This is not the first time I've read about the MAX72XX chips, but the articles I have found in the past were not as friendly as this one and they did not explain how to program the MAX72XX chips, so I just threw that information away because I did not really understand it. Now, on the other hand, I think I do understand it. The wiring diagram is pretty clear and also the programming examples are easy to understand.
I did a quick search on eBay and found that you can buy 10 pieces of MAX7219 for about 5$, which is quite cheap. I'm very tempted to go for this approach.
Starting out with a smaller LED cube (3x3x3 to 5x5x5) is probably good for practice and I'll probably regret not taking your advice and doing it, but somehow I feel that 'll go straight for the 8x8x8. First of all, creating a bigger LED cube (just the LED cube, not the additional electronics) is just a matter of exponentially more soldering, right? Second of all, the MAX7219 is designed to drive exactly 8x8 LEDs which are exactly the number of LEDs needed in one layer of my 8x8x8 cube, so why not go for the real thing from start? If at this point you feel that I'm making a huge mistake and that there are a lot of problems with a big cube and that I need to experience some failures with a smaller cube first, please outline a few of those, maybe I'm not seeing something important here after all...
OK, so let's assume for a second that I'll build that 8x8x8 cube (sooner or later I will, I hope smiley ). Let's also assume that I'll use MAX7219 chips to drive the LEDs and to make my life easier smiley I have a few questions related to this solution:
1. What would you recommend to consider a layer in the cube? Would you drive each horizontal plane of the cube (8x8) with a MAX7219 or would you drive each vertical plane which faces the "front" of the cube with one MAX7219. In other words, would you divide the cube into layers horizontally or vertically? This is an important question. If one would like to display text (letters) in the cube, which face the "front" side of the cube, programming would become a lot easier if the layers were vertical. On the other hand, for generic animations, I get the feeling that dividing the cube into horizontal layers would be more practical...
2. The following wiring diagram: http://www.gammon.com.au/images/BL-M12A881_e.png shows that 3 pins are used from the Arduino to communicate with the MAX7219: MOSI (D11), SCK (D13) and SS (D10). Now this is great if you only have one layer of 8x8 LEDs. But I need 8. Which additional pins would I use in this case? I get the feeling that pins D11, D13 and D10 are part of some special group on the Arduino and that they are used for some special protocol. If so, how could I use 8 groups of 3 pins to communicate with 8 MAX7219 chips?
3. Again, using 8 layers (8 MAX7219 chips), how would I need to modify the code from the article to talk to each of the MAX7219 chips? When you have only one layer (one chip), the code looks like this:
Code:
void sendByte (const byte reg, const byte data)
  digitalWrite (SS, LOW);
  SPI.transfer (reg);
  SPI.transfer (data);
  digitalWrite (SS, HIGH);
  }  // end of sendByte
How would I modify this to be able to talk to the layer (MAX7219) of my choice?
I'm also thinking about whether I should use standard clear white LEDs or diffused ones. retrolefty pointed out that diffused ones look much better when turned on. I've never actually seen a diffused LED until now, but I believe you smiley However, clear LEDs are brighter (is that good or bad?) and look a lot more elegant when turned off. Also, I'm thinking that the luminous flux of standard clear LEDs is usually higher, so maybe I can drive them with less current (as I wrote, in my experience 1 mA is more than enough when continuously lit, but multiplexing might make a difference). Luckily the MAX7219 chips need a single resistor to specify the current running through all the 64 LEDs, so I'll only need a total of 8 resistors for this purpose in the entire cube. I'll add lower value resistors calculated for 20 mA through the LEDs and I'll add variable resistors in series with the regular ones, to be able to modify the LED currents and turn them down to 1 mA. How the resistor value can be calculated for a given current value, I don't know. I've seen some tables somewhere, but those tables  were only considering current values of 20 mA and 10 mA, they never went down to 1 mA...
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Quote
Can't you just turn the cube? If not, I would probably have a layer be one letter (depending which way the letters are going to face). It's probably not critical.
Quote
You parallel up MOSI and SCK for all 8 chips. Then you use one SS line for each chip (ie. pins 10, 9, 8, 7, 6, 5, 4, 3). However looking at the datasheet the chip has a DOUT pin (pin 24) which is for daisy-chaining.
What you could possibly do (although I haven't tested this) is to parallel up SCK and SS, and then feed DOUT from the first chip to DIN on the second (and so on for second to third, etc.). Then you could use just 3 wires for the entire lot.
You would then bring SS low, clock out all the bytes and bring SS high to latch the lot. The datasheet says "The last 16 bits of serial data are latched on CS’s rising edge.".
So, you send out 16 bits (2 bytes). It goes into the first chip. Keeping SS low, you send another 16 bits. The first 16 leave the first chip and get clocked into the second. Then you do the third 16 bits. Now the bits end up in the third chip. And so on. So 16 bytes later (16 x SPI.transfer) you have set up one row for each of the 8 chips. Then you latch, and that row gets committed. Repeat for the next row, and so on.
I haven't tried that (I don't have enough patience) but clearly the design is supposed to allow for that. Effectively you could set up any number of chips in sequence like that, but only need 3 data lines from the processor, no doubt which is what they intended.
Quote
As I described above.
« Last Edit: December 26, 2012, 09:00:09 pm by Nick Gammon » Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Quote
You probably set up in memory the bit pattern for all 512 bits anyway in an array. How they are physically wired is not critical, it would just be whether you go through the array X direction first or Y direction first.
Logged
Offline Offline
Full Member
View Profile
WWW
Thank you for this information! smiley
I have found another article somewhere (http://playground.arduino.cc/Main/MAX72XXHardware) which seems to confirm what you just mentioned:
- Parallel the CLK and CS(Load) for all the MAX7219 chips (I guess we also call these two SLK and SS)
- Take the DOUT from one chip to the DLN of the next chip
And using just 3 wires to communicate with the whole thing? Wow, that's impressive!
There's one thing I'm not sure I understand in your explanation about how to program the whole batch of chips. You say that if I send packages of 16 bits multiple times, the bits are pushed from the nearest chip to the next one every time a new package is sent while SS is kept low. This is clear and wonderful. But you also wrote "Then you latch and that row gets committed". What does it mean to latch?
Sorry if I ask such beginner questions, but as I wrote, my knowledge in this area is merely starting to develop and I'm having a hard time understanding some of the basics...
As for how to divide the cube into layers, I guess you are right, it doesn't really matter that much, the software can handle it either way.
I don't really where to buy the MAX7219 chips from. As I wrote earlier, I found them on eBay, where you can buy 10 pieces for 5$. That would be nice, but I've read that they are not original and that must be true because Maxim is selling them for a lot more. I've also checked them in a local electronics parts store and here I could buy original ones, 10 pieces for 40$... I wonder if it's worth buying the original ones...
Thank you!
Logged
Offline Offline
Full Member
View Profile
WWW
I've juts realized that the fact that driving the LEDs with MAX7219 chips in such a simple and elegant fashion has a price to be paid during construction of the LED cube. If I drive each horizontal plane of 8x8 LEDs with one MAX7219, I'll need to have 16 wires go to each horizontal plane, I no longer have the advantage of connecting the vertical legs of each column together and sending signals through that... It's going to get ugly... smiley-sad
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
When you bring CS (chip select) high the data is latched. That is, it is transferred from internal holding registers to the actual chip outputs, connected to the LEDs. Until it is latched you don't see it, so you don't notice the data being pushed from one chip to the next one, it is all internal.
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
I don't see how you can individually control 64 LEDs with less than 16 wires unless you use Charliplexing maybe, but that could be a bit difficult for 512 LEDs. Plus you need the 512 resistors then.
On this diagram for the 8x8 LED:
On the right, notice how 8 anodes are connected together and 8 cathodes? It will be tedious wiring 512 LEDs whatever way you look at it, but only 16 wires isn't too bad.
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
So why not stick with your original plan:
64 cathode drivers, and 8 anode drivers.
Can be done with 9 TPIC6B595 shift registers and 8 PNP or p-channel MOSFETs.
8 of the 6B595's will drive the cathodes.
Each bit of the 9th 6B595 will be used to pull the Base/Gate of the Anode transistor low to turn the part on, pullup resistor pulls it high to turn it off.
83 cents each at avnet.com
Have to play with the timing, see if 9 SPI transfers will do it, or if need to turn the anode off, drive the cathodes, and then turn the next anode on to prevent ghosting. 9 SPI tranfers or 11, quick either way.
Lots of time available while watching millis() go by to update the 64  bytes that hold the array information.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
This board I sell will hold all the shift registers, you can not populate the '328 part of it and feed in your SPI controls signals from  your Mega if you wanted to.
They're all daisy chained, so you couldn't easily split the transistor driver from the other drives.
I used 2 of them, 10 shift registers each card, just passing power and the control signals along to the 2nd card, to drive this 5x20 display with no multiplexing:
http://www.crossroadsfencing.com/BobuinoRev17/Prototype_in_action.MOV
Logged
Offline Offline
Full Member
View Profile
WWW
Thank you again for your replies!
Nick Gammon, in a theoretical sense you are right that 16 wires to drive 64 LEDs is pretty good. However, the LED cube is all about being able to see through it, about being elegant, about not seeing wires... I was thinking that I could cheat out half of the wires by dividing the cube not into horizontal, but vertical planes. Each MAX7219 would drive a vertical plane. This way 8 legs (all anodes or all cathodes) would go directly into the PCB beneath the cube, so only an additional 8 wires would have to crawl up along the edges of the plane. Dividing it equally, I could manage with 4+4 wires. Maybe I can buy some very thin wires and it would look nice. I wonder how thin is not too thin. I'm thinking that the resistance of the wires might matter...
CrossRoads, your idea is also tempting because I could create a cleaner (wire-free) and more robust cube. It also has the advantage that the cube would be made only by soldering LED legs together, as opposed to the MAX7219-based solution where I would have to find a way to make the cube more rigid by adding some non-conducting sticks between the planes, to hold them together. That would probably mean glueing.
What did you mean by "Lots of time available while watching millis() go by to update the 64  bytes that hold the array information." Were you suggesting that in the MAX7219-based approach needs a lot of time to fill up the registers?
You also wrote this:
"64 cathode drivers, and 8 anode drivers.
Each bit of the 9th 6B595 will be used to pull the Base/Gate of the Anode transistor low to turn the part on, pullup resistor pulls it high to turn it off."
Is there a place I could find an exact wiring diagram for this? What about an example on how to program it?
As I wrote, I really am an amateur with high aspirations (the 8x8x8 LED cube). I'm struggling really hard to understand the answers you guys give me smiley Because of this the MAX7219-based solution is more appealing to me. The chip takes care of LED currents, of multiplexing the LEDs. Also less components, less room for error. The only two problems with it are the price and the wires that would make the cube look less aesthetic... Because of this I'd like to try to understand the other solution too, with TPIC6B595 shift registers, but I need some diagrams and some programming example to see if I can work with it.
I really do appreciate your answers. Thank you!
Andras
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
How's this for a start?
Logged
Pages: [1] 2 3 ... 18   Go Up
Print
Jump to:
