Loading...
Pages: [1]   Go Down
Author Topic: wood boiler control system  (Read 310 times)
Offline Offline
Newbie
View Profile
I have a complicated wood boiler system that is currently using two Honeywell controllers to control many relays and pumps throughout the system. It seems to work to a point but needs to be a little smarter than it is. Someone told me about Arduino and though it might be capable of being programed to do what I need and much more.
Is there anyone out there that has used Arduino in this way and is willing to help guide me through this process? I'm not even sure which Arduino board to be looking at.
Not only would I like it to control the system but monitor and chart itself too.
Thank you for any and all help.
Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
The first step will be figuring out what inputs and outputs you need.  Inputs would be temperature sensors, pressure sensors, switches, etc.  Outputs would be valves and knobs.
Logged
Offline Offline
Newbie
View Profile
Right now it relies on 4 temperature sensors and two controllers with four relays each. Only six of those eight are being used. Those controllers handle multiple RIP relays which in turn shuts pumps on or off.
A few more input sensors might be nice and at least the eight outputs I have maybe more.
A couple years ago I bought the Arduino Duemilanove to play with and see if it was something I could use but I got busy and never got back to it. Now I see the Duemilanove is not produced anymore.
Any advice would be greatly appreciated.
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
The Duemilanove is still supported by the current arduino IDE and will run all the same sketches and library code that the current Uno board does that is based on the identical 328p micro chip. So your Duem... board is as relevant and useful as the day your bought it.
As far as your boiler controls go, there are very significant safety aspects that go along with boilers, many are defined and enforced by law. You need to clearly understand what sensors and controls are safety related and that should be independent from any controller you use to run the boiler. This in not a trivial or simple project to take on and dependent on your specific knowledge and experience may not be a good arduino project to take on. If the boiler is operational already maybe just have the arduino be a boiler monitor and data collection device, rather then actually controlling the boiler?
Lefty
Logged
Pages: [1]   Go Up
Print
Jump to:
