Loading...
Pages: [1]   Go Down
Author Topic: Is it possible to display an Analog meter with Arduino?  (Read 383 times)
Alemania
Offline Offline
Newbie
View Profile
Hello,
is it possible to create an analog Panel meter with Arduino, using  a grapics display?
I need it as a replacement panel meter in this machine:
http://digilander.libero.it/pasqua49/COLLEZIONE%20HI-FI/AVO%20MKIV/MKIV%20ok.jpg
A similar product is offered by Panelpilot,  but this graphics is too primitive, it doesn't get close to what is needed.
http://www.panelpilot.com
I was hoping this can be done with Arduino, and build a good copy of the original.
Thanks for your comments smiley
Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
Can be done, better find a graphic lib that supports lines and text and with some sin/cos you can get the coordinates right.
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Offline Offline
Edison Member
View Profile
Quote
Yes - in principle. No - in practicality.
The programming is reasonably involved, especially if you want to code to a logic graphics interface, for portability reasons.
However, if you are willing to use a faster / cheaper chip, NXP offers emWin, completely free of charge and without any limitations, for its line of mcus. My experience with emWin (both on lpc and other chips) has been nothing but outstanding.
Logged
Offline Offline
Jr. Member
View Profile
Please.  PLEASE!!!  Do not ruin that beautiful vintage gear by jamming a digital meter into it.  Have a little respect for the little beastie.
(OK, overly dramatic, I know.  But I just hate to see that sort of thing done, especially to such well preserved tube-era hardware.)
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Quote
That 'machine' appears to be a vacuum tube tester? If so you might want to do a little research on it's market value as the audiophile people have bought into vacuum tube amps and pre-amps in a very big way, making the value of many of the old tube testers quite valuable. And the unit in the picture you posted seems like quite a piece of high end test equipment from a past era.
 So yea, don't modify the unit until you find out if someone might want such a device and be willing to pay nicely for it. Is it functional?
Lefty
Logged
Western New York, USA
Offline Offline
Faraday Member
View Profile
Quote
No - it's a valve tester!!!
Quote
I suspect that your tube tester is not in the same condition as the one in the photograph but I wouldn't modify it in any case.
Do you have the original meter?  Even if it is not working you might be able to salvage the meter face and body.  The underlying mechanism is most likely a basic milliammeter and you could possibly fabricate a replacement meter by grafting an ordinary milliammeter to your original body.
Don
Logged
Offline Offline
Brattain Member
View Profile
Quote
That's a rather 'coloured' response to make.  smiley-wink
Lefty
Logged
Offline Offline
Faraday Member
View Profile
This link --> http://frank.pocnet.net/instruments/AVO/MF/AVO_CT160A_Working_Instructions_and_Service_Manual_and_Inner_Workings-TIFF.pdf <-- has all kinds of information including the characteristics of the meter (it's actually a microammeter).
Don
« Last Edit: February 01, 2013, 08:36:42 pm by floresta » Logged
Montreal
Offline Offline
Edison Member
Per aspera ad astra.
View Profile
WWW
To OP: Depends on detalization level you need. I'm doubt arduino is up to 3 - 4 scales shown on picture, except memory demand, it also would require sophisticated rendering algorithm.
1 pseudo-graphic http://coolarduino.wordpress.com/2013/01/09/audio-vu-meter/    or
http://www.sparkfun.com/tutorials/120
Logged
Anaheim CA.
Offline Offline
Edison Member
Experienced old Whitebeard with a Full head of Hair...
View Profile
Or you could use a 4D Systems:http://www.4dsystems.com.au/products.php and look at the 3.2 PT and 4.3 PT serial displays. ave33 has a library for it listed somewhere here... The display is capable of some amazing things, SD card, Speaker 16 I/O organized as an 8 bit bi directional bus or 16 individual digt oital I/O, serial port in the display... The list of features is best read from the website...I own 2 of the 3.2 PT SGC modules and they work well.
Bob
Logged
“The solution of every problem is another problem.” -Johann Wolfgang von Goethe
Pages: [1]   Go Up
Print
Jump to:
